need help figuring out power of amp!? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-13-2005, 12:19 PM   #1 (permalink)
I bought a sub from a friend and he gave me an amp for free. I already have an amp so I am not using this one, but I thought I might stick it in the boat or something. Except I dont know the power of it and I cant find it anywhere online.
Its a Kingwood (NOT kenwood, yea Kingwood, never heard of it). Model number: KWR-600. 4-Channel, 2-ohm/4 ohm stable, 15A fuse. Ive looked everywhere to find the wattage, but cant find it. Can anyone help?
Mac6135 is offline
Old 05-15-2005, 03:11 AM   #2 (permalink)
4-RUNNIN' FREAK's Avatar
600 in the model number may point to 600 watts peak to 4 channels.
Divide that by 4 for the 4 channels and that is 150 max per channel.
Now divide that by two because the RMS is usually half of the max.
That is for a 4 ohm load. In 2 ohms you can get 150x2 channels.
I notice on lesser amps they rate them at max power to make them sell.
I can be wrong, but it may be a little more or a little less.
Correct me if I am wrong.
My Alpine can push out 170 watts RMS and is rated for 125 per channel RMS.
__________________
'02 4Runner - '06 XRunner
Breakdancing
www.BadgeYourRide.com
Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/
Highest Xmax 6.5" subwoofer made
Total Posts: 32,218 (75.35 posts per day) [/center] [/color]
Still A Neon
4-RUNNIN' FREAK is offline
Old 05-15-2005, 09:35 AM   #3 (permalink)
Metal Wulf's Avatar
Send a message via AIM to Metal Wulf
it's probably a little less as it's only got a 15amp fuse.
It's probably 50watts per channel
__________________
'89 4x4 Pickup SR5
Stock for now...
RIP... '89 4x4 SR5 4" Trailmaster lift w/ 33" BFG MTs
Metal Wulf is offline
Old 05-16-2005, 03:13 PM   #4 (permalink)
Gangus2006's Avatar
Send a message via AIM to Gangus2006
Well, seeing that its a 15A fuse:
15A x 12V = 180W (peak)
180W / 4 Channels = 45W (Peak)
45W / 2 = 22.5W (RMS)
probably less due to inefficiencies in the amp, so figure around 15-20WRMS x4 @ 4ohm
I put in a 50x4 (16-18Wx4) head unit, and it had a 15A fuse...
Gangus2006 is offline
Old 05-16-2005, 04:09 PM   #5 (permalink)
Who knows if it's the right sized fuse.
I know people who run a lesser amp fue just for added protection.
I also know people who run without fuses cause they think it robs them of power. I would just like to hear about a fire one day so I can say "I told ya so".
__________________
Breakdancing
Still A Neon
Tags
amps, figuring, figuringoutwhichfuseamp, total
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
need help figuring out trailer wiring issue wallstrum 95.5-2004 Tacomas & 96-2002 4Runners 11 03-28-2009 10:52 AM
Vacuum Lines Ahoy!!! Need some help figuring what goes where. Kyle95sr5 86-95 Trucks & 4Runners 33 02-10-2007 04:52 PM
formula for figuring out what gears you have BIG RON Newbie Tech Section 14 05-20-2006 08:30 AM
Need some help figuring out if 285's will fit fine... thehoerunner 95.5-2004 Tacomas & 96-2002 4Runners 5 04-17-2006 07:56 PM
2009 InternetBrands, Inc.
