Need help with complicated sound system
So a long time ago I was given a good sound system with crossovers, equalizer ect. and I decided to install it in my truck, the problem is I don't have the manual.
I decided to install only the front speakers. I have everything figured out as far as the head unit plug and which wire goes to the speakers, ignition, battery and ground. The problem is I have 6 spade connectors and two wires on my speakers, where do they all go or plug to?
And how do you wire the crossover, is it necessary?
It has 6 ''ports''
IN +-
MID +-
HIGH +-
I don't have an amplifier or a subwoofer, maybe it is intergrated in the speakers like the tweeters?
Right now the head unit works and the speakers are connected to it by the two wires coming out of them but nothing works.
Thanks fo the help!
It has 6 ''ports''
IN +-
MID +-
HIGH +-
Thanks fo the help!
For starters, don't connect the front and rear channels from the head unit together. Use only the front channels if you're only installing the two speakers. You use one passive crossover per speaker. They can be placed wherever you want. The channel from the head unit connects to the "in" on the crossover. "High" connects to the tweeter(the wire coming out from the center). "Mid" connects to the spade terminals. Use the spade terminals that are connected to the tinsel leads( the one with only 2 connectors). From the pics I don't think the connector with 4 spade terminals is connected to anything. I assume they intend you to wire the tweeter to two of the terminals and then use spade connectors to connect to the crossover. Basically reducing any accidental tension on the tweeter wire.
If any of this doesnt make sense then let me know. It's been a long day.
Staff
For as much equipment that you are wanting to install, there may not be preassembled kits, but even Wal-Mart sells some kits for the basic part. Wiring a stereo is beyond my ability even though the local third grader can do it and I cant, but those kits make it so much easier. One problem I see alot of is where people hard wire stereos and trailer light kits. Any time I have an electrical issue those are the first two things I look for. Wiring kits are very reasonable if they have them for what you are wanting to do.
Thanks terry everything is installed and working good. As for the head unit it's pretty straight forward, red wire to ignition, yellow to battery, black to ground, then you connect the speaker wires which isn't much harder. As long as you have good connections there shouldn't be a problem. I'm starting to have too many things running off my battery so this winter I will do a big clean up with a power block or something. The only thing that was bothering me was all the speaker connections a really had no idea.
theking11863
03-19-2016 09:36 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
