| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
JBL Audio Overhaul
__________________
The J Man -Yes it is a fish in a blender.. 03 4Runner Limited 4.7L: 20" Mazi rims, altezza tail lights, chrome amber bulbs, etc.. |
#2 (permalink) |
I was thinking about going with components in the rear doors, and just mount the tweeters in the pillars.. But that does not help the replacement of the single dash speaker..
Just trying to maximize on the surround sound technology and the available speaker points..
__________________
#3 (permalink) |
Staff
I looked up the parts on www.toyodiy.com and the rear pillars appear to be stand alone tweets just like you're planning to replace with.
The two dash speakers appear to be standard toyota 4"ers, if you are refering to the centre dash speaker it's the same part # as the other two dash speakers so it would be a standard 4" as well. The after market designation is a 4T which has slightly larger mouting tab then a standard 4" [and is only made by a few mfgs.] but you can use a standard 4" with no trouble provided you trim a couple of the tabs with tin snips and use washers on the two remaining. Hope this helps...
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#4 (permalink) | |
Staff
Quote:
IMO you'd be happier with a coaxial rear door and some stand alone tweets in the pillars albeit at a slightly higher cost... this would probably be the simplest install... don't forget to dynamat or bquiet the doors at least or you won't get half as good a sound...
__________________
#5 (permalink) |
Awesome. Thanks. I never though of stand alone tweeters in the rear.. The cost of coaxial w/ additional tweeter set and a set of components is close.
What are your thoughts on amplifiers? The dash only has room for one speaker. I doubt I could go with a 4 channel, bridge 2 so I am only running 3 (dash and rear pillars). That would require a 2 ohm 4T. I could keep the gain down so I don't burn it up, but are there 2 ohm 4T speakers out there that you have seen? I'm planning on 90watts/channel x4 and 1000 x1 on the sub.
__________________
#6 (permalink) |
Staff
Only 2ohms I've ever heard of are subs...
There should be 3 speakers in the dash the middle one and the two down by your knees in the standard position. If your HU allows for a centre channel why not run it direct of it and skip the amp on that channel? just use a bass blocker...sure you might loose a little power but I don't think it would be that noticeable... there are 5-channel amps avail. that might be an option as well... You should get in touch with member NYChopshop he is a professional audio engineer and is building a kick butt set up in his runner he knows his stuff and can give you much better advice... Texas91Runner is another member you might want to talk to.
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. Last edited by aviator; 07-01-2009 at 10:51 AM. |
