How to wire accessories to come on with the ignition. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-19-2009, 11:06 AM   #1 (permalink)
deathrunner's Avatar
I'm trying to clean up my wiring and am trying to figure out how to get accessories to turn on and off with the ignition. There are several that I have in mind so I would just like to power a whole fuse block via ignition.
Do I just tap into a fuse on the stock block and power my accessories fuse block with it? Do I use the ignition to activate a realy to turn on my accessory block?
Here is what I want turned on with ignition:
-inline noise filter for cb
-aux headlamps
-aux rear light
-air compressor
-aux cig lighter
-subwoofer
Any suggestions?
__________________
IFS IS FOR LOSERS
deathrunner is offline
Old 08-19-2009, 11:36 AM   #2 (permalink)
seanmearse's Avatar
The subwoofer should turn on with the cd player and amp. One positive fused to battery, one remote and a ground, then the amp should cut on and off with the sub.
__________________
The Internet, where men are men, women are men, and children are FBI agents.
Proud sponsor of the re-poster thread.
http://www.yotatech.com/f5/you-re-poster-193103/
84 SR5 pickup, Mostly stock 22R, K&N air filter, Mobil 1 oil filter, Cherry Bomb, Mobil 1 engine, Royal Purple diff and trans fluid, 15X8 street locks, 3 inch procomp front springs, waiting to buy rears, rancho RS9000XL's up front.
2003 Vstar 650, straight pipe, loud and fast baby!
seanmearse is offline
Old 08-19-2009, 02:12 PM   #3 (permalink)
eric-the-red's Avatar
I would use the ignition to turn on a relay to power the auxiliary fuse block. I used one of these fuse blocks from Painless, it has constant hot and ignition hot circuits
http://www.painlessperformance.com/w...&SearchAll=4x4 OffRoad
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 08-21-2009, 09:09 AM   #4 (permalink)
Of Course! Duh! I should have thought of that. Thanks Eric.
The sub is already on the remote. good call, Sean.
__________________
IFS IS FOR LOSERS
Old 08-22-2009, 01:47 AM   #5 (permalink)
seanmearse's Avatar
Now if I could only figure out my internal regulator conversion.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
