| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
HIGH OUTPUT ALTERNTAOR 2008 Tacoma
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- |
#2 (permalink) |
Here's the Truck the HO alt will be going in.
![]() aka bump for myself LOL
__________________
#3 (permalink) |
Damnit. Last time I tried finding ho alt information for my 97 tacoma I came up with nothing. Ended up with a dual alt install on that truck. Argh. So bump to me. Sorry for the selfish post bumps.
__________________
#4 (permalink) |
i know with a 22re you can drop the GM 160 amp alternator in with minor fab work... maybe the same with yours?
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#5 (permalink) |
Anyone ever had one of their stock alts rewound by a reputable shop? If so how many more amps did they get out of your stock alt? How much did it cost?
__________________
#6 (permalink) | ||
Either PM TNRabbit, or search for some of his threads on this subject. He had his re-wound, but I can't think for the life of me, the name of the company who did it.
__________________
Quote:
Quote:
------------------------------------------------------ 1991 Toyota 4Runner SR5 4x4, 3.0 V6, Auto, Alpine CDA-9807, 31x10.5's, 4.56's, 1" RB lift, 2" SDORI Coil spacers, Optima RedTop, Aisin manual hub conversion, and the all important FSM's |
#7 (permalink) |
Right on a4runnerfreak. Thanks fellow yota brethren!
__________________
#8 (permalink) | ||
No problem! And I *think* the company name was Boyd's Alternators.....but search TNRabbit's posts. He mention's the name a couple of times....
__________________
Quote:
#9 (permalink) |
sorry, might be a little late, but many people running big power run big alts -
ohio generator and leece-neville are a couple of companies that are popular. depending on the total current draw of all your electricals, you might be running a fairly large-case alt (like bigger than the GM units). you can only increase output so much by rewinding the stock alt, and even then, heat becomes a big issue (premature failure). also, when rewinding, i've been told that max output comes at a higher rpm than stock (i.e., if it's rated at 180 amps, you might only get those 180 amps at 5K rpm. actual output at idle levels may be LESS than the stock alt after it's rewound. at this point, then you'd be looking at overdrive pullies to get stocks amps at idle and city driving, but at highway speeds you'd really be spinning that alt fast (again, heat may become an issue). also, some big radio folks run more than dual batts... like a whole trunkload of deep cycle batts. |
#10 (permalink) | |
Quote:
were you using two oem alts, or did you go with GM large-case units or some other aftermarket comp. brand? iirc, i did see some write ups on the mods necessary to fit large case alts into the T4Rs of those years (3rd gen, i think). had some cutting/filing/grinding of the case required along with some fabwork for the brackets, iirc. was looking into that myself, but i just didn't have the tools or skills to undertake a project like that. i know the popular domestic vehicles for comps have aftermarket multiple alt. mounting brackets already made, including those that let you keep your a/c, but i don't know how easy it would be to find such things for your truck - these aren't the typical keyup or comp vehicles. |
| Tags |
| green, starter, tacoma |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| high output alternator | rottenagenda | Pre 84 Trucks | 1 | 01-25-2009 05:36 PM |
| High output Alternators | Dave's D.C. Electric | Vendor Advertising | 0 | 08-23-2007 10:09 PM |
| HIGH OUTPUT ALTERNATOR, any problem if runin too high voltage?? | Chief_Yota | 86-95 Trucks & 4Runners | 10 | 08-04-2007 11:55 PM |
| New Alternator... High output... | Ducky | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 12-22-2004 07:05 PM |
| High output alternators | george16 | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 03-24-2004 09:13 PM |
