Hidden antennae - YotaTech Forums
Go Back   >
Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Hidden antennae
LinkBack Thread Tools Search this Thread
Old 03-26-2013, 03:19 PM   #1
swerks's Avatar
Hidden antennae
Any one using a hidden antennae
swerks is offline   Reply With Quote
Old 04-03-2013, 07:38 AM   #2
hoghead420's Avatar
I am . I have a 98 4runner that the power antenna died long ago . Found a second antenna built into the rear passenger window . I still don't understand why they have 2 installed ? Used it instead. I had to get an adapter from Walmart. Works like a champ . I got the power mast down and unhooked power to it . Then just painted it black , can't even really see the old power antenna spot. Cost like 6 bucks to do . P.s. I'm on the mobile version so I can't tell what kind of truck you have , 3rd Gen runners seem to have the extra antenna . Not sure about other models. You can tell if it has it by looking in the rear passenger side window, it will look like a defroster outline around the window , the drivers side doesn't have it .
hoghead420 is offline   Reply With Quote
Old 04-03-2013, 09:20 AM   #3
Outsane's Avatar
I used on one when I had a CRX... worked well
Outsane is offline   Reply With Quote
Old 04-03-2013, 05:21 PM   #4
\\i have installed several hidden antennas in several vehicles, both my own and ones i have just worked on. They work fine from FM, but will do little to nothing for the AM stations. I have installed them in several different locations. on the top of the windshield, above the sunroof liner, several in the upper cavity of the dash, behind the radio etc and didnt have any issues with them
drpdmazda is offline   Reply With Quote
Old 04-03-2013, 05:51 PM   #5
Yep, I'm using one in my '89 pickup. Ran the wire up the RH A-pillar, removed the passenger sunvisor, & poked it up above the headliner. Works perfy!
(of course, I'm the retard that cut the coax to my power ant. in the 1st. place). Ha!
G0TW00D is offline   Reply With Quote
Old 09-07-2014, 11:47 AM   #6
RAD4Runner's Avatar
Hi guys,
Exactly what kind have you used?
mast antenna gets in the way of loading kayaks, and it's another thing to worry about in the car wash, so I'm also considering a hidden one.
I wonder if you have any experience with
this"><font color=this" /> this">this
Good experience. Bad experience? I plan to stick in on upper portion of winshield glass where it would not interfere with visibility and where I would want to put a dark tint, anyway.
TIA
RAD4Runner is offline   Reply With Quote
Old 09-07-2014, 12:03 PM   #7
Outsane's Avatar
I would suggest you get a powered unit..
Just Differentials Toyota Tundra Crewmax w/ 6.5' bed justdifferentials Vendors Build-Ups (Build-Up Section) 13 01-18-2017 04:04 PM
1999 4runner Won't Start zombie_barbarossa 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2015 11:54 PM
Ignition off: Power windows and radio work tazman1972 General Electrical & Lighting Related Topics 11 09-28-2015 11:32 PM
Factory power antenna install on a 2001 double cab? Ilovemountains 95.5-2004 Tacomas & 96-2002 4Runners 0 09-15-2015 05:17 AM
So I thought I would try it..... msged2007 GPS & Communication 0 08-22-2015 08:46 PM
Tags
20024runnerfactorystereoextraantenna
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
