Dad Needing Help Please!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Vehicle Audio & Home Entertainment
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2004, 06:20 PM   #1 (permalink)
Installed a Sony CDX-F5705 head unit in sons 4Runner. After installing, when unit is playing CD's only getting sound from front speakers. On TUNER setting get sound out of front & rear speakers. Even went out and bought another unit exactly like this one thinking my unit was bad but same thing. I used a plug adapter that plugs right into the Toyota plugs. PLEASE, PLEASE someone have a solution. I will be eternally grateful. THis one stumps me.
Thanks,
DJ
diverjeff200 is offline
Old 10-25-2004, 06:28 PM   #2 (permalink)
SLC Punk's Avatar
Send a message via AIM to SLC Punk Send a message via MSN to SLC Punk
This may sound stupid, but did you make sure the fader was not only on the front in CD mode? I know that my sony's can have a sound setting for AM/FM and another for CD.
__________________
-Travis
1997 4Runner SR5 V6 4X4 Supercharged Desert Dune SOLD :(
1992 Celica All Trac (AWD-Turbo) #223 of 271 US spec for 1992 FOR SALE
2005 Tundra Double Cab Limited 4X4 2.5" lift 265/70R17 Dueler Revo's
4Runner and Celica Webpage
SLC Punk is offline
Old 10-25-2004, 06:35 PM   #3 (permalink)
Travis,
After re-reading your post I got to wondering what you said. Are you saying that there is a bal/fade each for tuner/CD/aux?
Thanks,
DJ
Old 10-25-2004, 06:37 PM   #4 (permalink)
SLC Punk's Avatar
Yes, you can set the fad/balance for each mode: AM/FM, CD, AUX.
Since you are getting sound on AM/FM, the wiring is correct, it has got to do with the settings.
Are you running an amp to power a sub, or is it just powering the stock speakers?
__________________
-Travis
SLC Punk is offline
Old 10-25-2004, 07:51 PM   #5 (permalink)
AW1090's Avatar
I'm with punk...it's gotta do with the settings in cd mode. If it were wiring then you wouldn't get sound no matter what mode you were in
__________________
Andrew
91 4Runner V6 Auto....ISR Mod, Manual Hubs, Flowmaster 50, 15x10 rockcrawlers, extended steel brake lines... Rear: OME 863's and N74L shocks / Front: Superlift front lift kit and N93 shocks w/ swayaway tbars..I'm not done yet. :)
AW1090 is offline
Old 10-25-2004, 08:05 PM   #6 (permalink)
Quote:
Thanks,
DJ
Hi ya -- I just went through this a few weeks ago with my '95 -- it's the wires that go to the power antenna and Toyota's internal amp. Many radio manufacturers design their radios with a single “remote on” wire (blue or blue with a white stripe) also referred to as a power antenna wire. This wire is designed as a multi-function wire that can be used to turn on/off either a power antenna or turn on/off an amplifier in the vehicle. BUT, some new radios have MULTIPLE “remote on” wires. These multiple remote on wires are dedicated specifically to a particular function: one wire is for a power antenna only, whereas a second wire may be used to turn on/off an amplifier only. These wires will be individually labeled noting what each wires function is.
If your new radio has multiple “remote on” wires and only the “power antenna only” wire is connected, then the Toyota amplifier in the vehicle will turn on ONLY when the AM/FM radio is turned on (the radio will only turn on/off the power antenna through the “power antenna only” remote on wire when the AM/FM radio is turned on.) BUT, if you connect the new radio's “amplifier only” wire, then the Toyota amplifier will operate all the time: radio, cassette, CD, etc. This “amplifier only” wire operates during the entire time the new radio is in operation. The “power antenna only” wire only operates while the AM/FM radio is turned on.
Are you using a snap-on wiring harness adapter to go from the Toyota wiring harness to the Sony harness? I had one orginally for mine (but a JVC) and ended up cutting it out and going direct. The problem (for mine anyway) was that the Black/Red and Pink/Blue wires were connected together and attached to the power antenna wire (blue). This left the head unit's blue/white wire essentially stranded (this is what connects to the Toyota's internal amp and drives the rear speaks). :cry:
I apologize that I don't remember which one went was for which, but you can easily test which is which: Connect one of the two Toyota wires in question (black/red for example) to the blue head unit (pwr antenna) wire and connect the head unit. (All other power/grnd/speaker wires are properly attached of course.) Turn on radio -- antenna goes up? Turn to CD -- antenna goes down? If that's what happens, that's the correct connection -- if not, connect the other (pink/blue) wire to the blue wire.
End result is all speakers will work all the time and the antenna will go up only when the radio is on.
Anyway, hope that helps and drop me a PM if you need clarification...
-Paul
__________________
I miss my:
1995 4Runner, 4x4, 3.slow
Bilsteins, JVC HU w/ 12pak CD,
Kenwood speakers, 127k miles
Zonie4Runner is offline
Old 10-26-2004, 11:33 AM   #7 (permalink)
SLC Punk's Avatar
So you went from your deck to the toyota amp? Why did you do that? The tuner's output will be more than the toyota amp will put out...
__________________
-Travis
SLC Punk is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How many of you have read Rich Dad Poor Dad Joshs98Runner Off Topic Talk 15 06-25-2007 09:45 PM
Needing some coilovers... ozarks_Runner The Classifieds GraveYard 1 01-05-2007 10:57 AM
What am I needing to look for in purchasing rims. bamboo89 95.5-2004 Tacomas & 96-2002 4Runners 4 06-21-2005 07:16 PM
ok guys, im needing help on this one.....PLEASE!!! wimpywade94 Off Topic Talk 12 08-09-2004 08:11 PM
Newbie needing answers Mean04Tacoma 95.5-2004 Tacomas & 96-2002 4Runners 3 02-22-2004 01:31 PM
2009 InternetBrands, Inc.
