Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
current problem with amp
Old Apr 29, 2006 | 09:00 AM
knemo77's Avatar
I have a mrd- m605 alpine mono amp and i am getting a flashing cur warning on the display of the amp. This mean that I have too much current going to the amp. Does anybody know what could cause this or how I could possible fix it. If you need more info I will check back often and thanks in advance for any help.
Old Apr 29, 2006 | 10:14 AM
lookmomnobrains's Avatar
id be willing to bet its not enough current. id be running a 4g power cable AND ground to it. what size wiring do you have now? are the connections on the terminals clean and tight?
Old Apr 29, 2006 | 12:41 PM
knemo77's Avatar
ive got monster cable on both. everything is clean and tight
Old Apr 29, 2006 | 12:51 PM
midiwall's Avatar
The owner's manual says:
  • The amplifier has been shutdown due to excessive current.
  • Find and eliminate the cause of the excessive current, then turn the power off.
Not much help, but it sounds like the sub may be drawing too much current.
What's the rating of the sub? Did this just start happening? How long had it been working "fine"? When does it start happening? Immediately after power-up or after you've been cranking the tunes for a while?
The amp claims it can handle a 4 or 2 ohm load, it may be that you toasted the sub, or the sub has an intermittent short in the voice coil.
Old Apr 29, 2006 | 05:12 PM
if the sub is drawing excessive current, its impedence is lower than it is supposed to be. (blown or damaged) run a multi meter across the subs + & - and see what the ohms reading is. it can vary slightly from what it is rated at but a big difference means its time for a new sub.
Old May 1, 2006 | 07:18 AM
knemo77's Avatar
i did have a fuse blow and after I replaced the fuse I got the error.
The sub has been working fine for about 6 months and never pushed. the fuse blew when i was moving stuff and had a blanket over the amp for a while. Maybe it overheated.
Old May 1, 2006 | 09:31 AM
midiwall's Avatar
VERY possible... does the error still come up now? I had asked some other questions above...
What's the rating of the sub? When does it start happening? Immediately after power-up or after you've been cranking the tunes for a while?
Old May 1, 2006 | 09:47 AM
knemo77's Avatar
600w Sub Does Not Fire At All At Start Up
Old May 1, 2006 | 10:04 AM
midiwall's Avatar
Do you have a DMM (multimeter)? Check the impedence of the sub - disconnect the sub from the amp, set the DMM to the lowest OHMS range, place the meter leads across the sub terminals (doesn't matter which to which), read the value.
If it's higher than the rated impedence of the sub (2, 4, 8 ohms?) or LOWER (like, zero) then the sub's cooked.
Sleaker
Aug 26, 2020 06:03 AM
1996Taco
Jul 20, 2015 12:02 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
Vargntucson
Jul 4, 2015 12:15 PM
