| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
the pictures
![]() ![]() ![]() ![]() tell me if i did anything wrong.. it could be the ground, but i dont think so. it goes to the frame of the car under the bolt. i was gona take pics of the antenna. but its too dark. and my next door neighbor was lookin at me funny like i was crazy
#3 (permalink) | ||
You need to match the radio to your antenna. Go to radio shack, ask for an SWR meter. Read the instructions on how to match your antenna. Takes about 5-10 min.
__________________
Quote:
Quote:
------------------------------------------------------ 1991 Toyota 4Runner SR5 4x4, 3.0 V6, Auto, Alpine CDA-9807, 31x10.5's, 4.56's, 1" RB lift, 2" SDORI Coil spacers, Optima RedTop, Aisin manual hub conversion, and the all important FSM's |
#4 (permalink) |
Errgg, Shoddy to say the least, Run the wires straight to the battery, You CB will thank you with Great and CLEAN performance, That ground isnt much of one..
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#5 (permalink) |
yeah.that SWR meter tuner.i was thinkin of that. ima go pick 1 up when i get some money. none of my friends have one.
is it normal for radios 2 always make fuzz sound? mines treeiblee .. it clicks and squeels 2 the poin u dont want 2 use it.. i hope a tuning will fix that. i still think i need a new antenna to. its soo bad .aha thanks man ![]() thanks
#6 (permalink) |
No its not normal, That ground isnt a good ground..
__________________
#7 (permalink) |
i just read a big article and found out the best way for power is through the fuse pannel in a empty slot. and puting a spade connector on it 2 fit in in the fuse connector . plus you can pick switched or unswitched power ( so if you leave it on it dosent kill your battery) it will only work when the car is on.. but if you car ignition breaks, you can move it 2 a unswitched connector.
it said to put the ground wire on a crimp connector skrewe it on to chassis its self in a hidden spot. then you tune the antenna. this sounds good prittey good 2 me. that way i have proper power, proper ground, and a proper antenna tune... now i just need 2 learn what fuse 2 put it in ...crap....i know nothin on the fuse pannel... aha need 2 go resherch! thank 4 the help guys. |
#8 (permalink) |
never mind guys.. instead of buyin that cigarette lighter adapter that i couldent find, i made one for 1.99 $
,,,walmartits perfectttt.and its nice because my cb had no fuse in the wire.. so the adapter has one in it. no more fuzz or sounds at all... and the antenna works actually pretty good.. talked with some one south about 30-40 miles away,,, i like how i can take it out easy too. this has 2 be the easiest way 2 install one.. 5 minuet installation. thanks for all your help and ideas guys
| Tags |
| 4runner, 4th, antenna, antennas, big, car, cars, cb, cb radio, gen, kind, pictures, put, radio, radios |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 4th Gen cb antenna mounting? | Bobby | GPS & Communication | 7 | 04-16-2009 11:03 PM |
| cb antenna for fm radio | CGOULET | Vehicle Audio & Home Entertainment | 2 | 10-26-2007 04:19 PM |
| Does anyone know how to make a TV or AM/FM Radio Antenna | Spanky | Off Topic Talk | 8 | 10-01-2006 10:36 PM |
| 4th Gen Radio changes channel on its own? | Duc Hunter | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 07-26-2004 04:23 PM |
