Car to Home stereo conversion
I've been searching for a very cheap way to put in a simple AM/FM radio with a decent set of speakers in my basement that I don't have to worry about getting beat around a bit. I happen to have my old stock radio from my 96' Tacoma (says A56405 on the front) just laying around. I was wondering if anyone knows if it would be possible to get a half dead car battery and simply hook it up through that and a wiring harness to some speakers. Also, I was wondering if anyone knew what sort of wattage this thing has (so I know what sort of speakers to search for).
Thanks for any help in advance.
Most units will have the model number written on either of the top corners, or right above the screen/tuner bar. Put that into Google, and it will tell you the wattage.
just hook the 12V power input into a wall socket. put a power inverter in the middle so if anything blows that will be it not your radio. then run the speaker wires just like normal and try not to blow them out! I dont happen to know if this will work but try it!
I just figured since the thing was sitting here collecting dust, I'd give it a shot just to see how it would work. I was also looking for a little more power than a wally world boombox, that's why I was curious as to the wattage. So if anyone is able to find it (I googled with no luck) that would be great! Also, as far as the batter vs. inverter thing goes, how long would a battery last if it was hooked up to a car stereo only?
A wall socket is 120vac! A car battery is 13.5vdc! You just attempt to "plug in" a 12v appliance to the wall and youll see a nice big explosion of that 12v device and possibly blow a fuze or breaker in your house at best...
Power inverters change the voltage from 120vac into ~14.4vdc
In order to do this you'll also need the toyota OEM wires that plug into the back of that deck. As far as power output, most likely 8 or 9 watts rms.
Getting only 5 hrs out of a battery kinda sucks, but I guess if it were easy I wouldn't have fun trying it. The laptop cable idea interests me, so I guess I'll have to find a spare one somewhere (any suggestions? ebay?). Since there is only 8 watts however, this maybe a lost cause. I was hoping for at least 20 so I could have a little kick out of whatever speakers i ended up with.
A simple 10$ Ac to DC inverter will do the Job from 120V ac to 12V dc.
Speakers will be a differant issues. House speakers wont run well on a stereo (but you can do it) differant ohm rating.
Hmm...didn't think about that. So let's say I have something similar to these:
http://cgi.ebay.com/NEW-PAIR-SONY-SS...QQcmdZViewItem
What can I expect out of them?
goto wallyworld and pickup a $16 trickle charger for the battery...
assuming it lasts 4-5 hours and you dont plan on listening to it for 24 hours...
or go green and pick up a a set of solar panels, at least 45 watts output and is that to charge and power the system at the same time...
Well it is worth it IF you already have all of the stuff lying about and around...then the cost is free!
For instance, I have a few good batteries lying about, a BITCHIN battery charger, 2 good HU's not in any vehicles and a nice set of MB Quart components sitting here.
Only reason I havent hooked any of it up is that im workin on Greg's kickpanels! lol and I dont have space!
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
r3dfish
54
05-16-2016 10:31 PM
theking11863
03-19-2016 09:36 PM
Jcrawl94
10
10-24-2015 04:34 PM
