89 SR5 audio wiring harness
I've looked through and searched what I can but I can't see anyone with this same problem. I cannot find the right wiring harness for my truck. The stock one they have at all audio places comes with two pieces but on my truck there's only one thing to plug into. The wires that don't connect so happen to be my back speakers. I'm under the impression that I have the harness for the regular cab but mine is an ext. I can splice the wires to make it all work but I wanted to make sure I wasn't missing something before I started cutting. Any help is appreciated
Staff
As far as I am aware of, I think standard or extended cab wiring is the same? I too would rather just plug and play instead of cutting. I am curious to see what you make out on this.
Wiring is the same I believe - I know on my deluxe xcab there were only front speakers in the dash, nothing in the rear. I also had a double-din stereo - is this what you're referring to as the "double" wiring harness?
In the end I just cut/spliced to the new stereo's wiring harness since I wanted rear speakers.
MudWaspSR5
02-09-2016 11:28 AM
