Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
4runner factory radio replacement
Old 01-13-2006, 04:28 AM
alongtheway1's Avatar
i am new to this forum and was wondering if anyone knows if the newer 4runner (2000-2005) are compatible with the older factory setups such as the 93-95 runners. please help ot thanks.
Old 02-07-2006, 10:17 AM
noahrexion's Avatar
nope, the plugs are totally different. I suppose if you wanted to custom mount it, took the plug from the newer 00+ and spliced it into yours you could...
Old 02-07-2006, 10:33 AM
DavidA's Avatar
MUCH better off getting a new radio. Nowadays it is so easy to use adapter plugs and mounting kits to install a non-factory radio.
Old 02-09-2006, 05:45 PM
91_4x4runner's Avatar
Get an Alpine head unit for around 150-200.... then get a $20 wiring harness (plugs into factory plugs and just splice wires together)..... took me about 45 minutes to replace it for the 1st time.... maybe 20 min for wiring
Old 02-11-2006, 05:00 AM
Bumpin' Yota's Avatar
Actually I don't believe that is the case. Reason being we have 3 toyota harnesses in totality. 2 are amplifier integration harnesses, the 3rd is your typical 1761... Meaning on a 00+ all ya gotta do is unplug the amp for the 2 standard toyota harnesses. Now I could be wrong about that, but Ill keep my eyes peeled for this on the next 00+ toyota that rolls in.
Im with the rest of the group, aftermarket deck >> stock deck! I have an alpine 9835, and its an awsome deck, im still going to be switching back to e-skips, err i mean eclpise! lol
Old 12-15-2008, 10:57 AM
Staff
DeathCougar's Avatar
this is incorrect. As long as you have the amp from the 2000 unit, you can use it no problem in the 93-95. Plug and play.
Fwiw, my uncle has a 2001 camry radio in his 83 supra. Toyota even sells the adapter harness to go from the 86-older plug to the 87+ plug
voiddweller
19
05-02-2016 09:10 PM
mtb_taco
06-29-2015 06:21 AM
Niameyrider
06-25-2015 05:50 AM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: 4runner factory radio replacement
