Not seeing images, using IE8
It seems that my laptop won't download any images with a url that starts with "http://images.ibsrv.net/ibsrv/res/src:www.yotatech.com......." There are little white boxes with a red 'X' whereever images should be.
I'm using IE8. Does anyone know how to correct this?
I'm now on my home PC, which is running Vista & Chrome, and it looks fine (fast too). I switch over to IE8 on my home PC; the site is much slower but all the images load. Could it be a security setting? Or maybe something has changed with the site? dunno, I'll check again on my work laptop in an hour or so.
Can you check your security settings, make sure you don't have ibsrv.net blocked. Otherwise, please try clearing your cache from your browser, as that should fix it. I am not able to replicate the problem.
if you open one of the images in a new window, what happens?
I'll try those suggestions, hopefully that'll work. I was thinking it might have been a server problem on the other side, but then I guess you would have been flooded with posts...
I turned off my employer's VPN and everything is fine (superfast too!). I'm connecting via Verizon Wireless. Apparently the 'people' are blocking ****.ibsrv.net
bryan34w
12
09-30-2015 02:50 PM
