YotaTech Forums
Go Back   YotaTech Forums > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-22-2005, 08:34 PM   #1 (permalink)
Personal Sales Rating: (0)
what do you think of this? (roll cage advice)
how much strength would i lose if instead of useing bends at the corners of a cage, i welded the pipes together, both at 45 deg. and put a piece between em to make a trianlge in the corners? the reason i'm asking is because i don't have the money to buy a bender, i can weld good, adn the guy i know that has a bender wants $5 a bend plus $10 initial charge (rip off if you ask me) to use his bender.
forty4 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-23-2005, 11:22 AM   #2 (permalink)
If you are not going to do it right, don't do it... Period.
BTW - $5/bend is cheap.
rockota is offline
Old 01-23-2005, 12:30 PM   #3 (permalink)
Threadstarter [OP]
i was asking because i had seen other guys just weld in angles instead of using bends, they said it was about as strong as the bends, adn i wondered how close was "about" to the bent strengths.
forty4 is offline
Old 01-23-2005, 02:20 PM   #4 (permalink)
Depends on a lot of factors -
type and size of tube (including wall thickness)
type of bend
type of weld used (mig/tig/stick) and quality of weld.
If welding was stronger than bending, you'd see it used much more often in professional motor sports. I've never seen a cage built w/ cut-n-weld techniques in place of bends...
Safety is nothing to mess around with. People do a lot of things and get lucky, but I personally don't think safety, especially a cage, is worth saving a single dime on, let alone $100 in bends...
rockota is offline
Old 01-30-2005, 01:11 PM   #5 (permalink)
Trailtoy1993's Avatar
the weld is stronger than the material it is attaching. japanese use alot of cut and weld in motorsports if you look at some of there gt300 jtsc cars and stuff, not on cages but other stuff you will see like thirty cuts and welds to make one bend. Mostly people don't do it because: 1) it is way more time consuming than a bend, 2) more break points every weld there is a potential break point on either side (which gussets would help) 3) It would look like amatuer hour! So, in summary it would be strong enough (with gusseting) but would look like ass and take forever. If those things don't bother you than by all means, go for it, after all it is stronger than no cage at all.
__________________
Trailtoy1993
'93 Xtra cab SR5 V6 Dana 44 SAS
Locked, 33" TXR's or Boggers
(soon to be 36" IROK's)
ICE
Trailtoy1993 is offline
Old 01-30-2005, 01:14 PM   #6 (permalink)
people make cages using weld ells also. the prefab bends you get from the plumbing supply house. after grinding the ell can't be seen.
__________________
Trailtoy1993
ICE
Old 01-30-2005, 05:53 PM   #7 (permalink)
crash's Avatar
I saw a guy doing 100mph hit a brick wall, I think I will try it too ..
Do you like to skimp with your life, and others who might be in your rig?
__________________
STUFF for SALE
crash is offline
Old 01-30-2005, 06:13 PM   #8 (permalink)
Vendor Sales Rating: (10)
waskillywabbit is offline
Old 02-04-2005, 07:05 AM   #9 (permalink)
westy44runner's Avatar
do it right the first time...
my advice is to either purchase all the necessary tools or have a welding shop do the work. Also, a notcher can be a great tool for making those 90 degree welds, and it will make them unbelievably strong. Speaking from experience, a cage isnt something you want to go second best on. If you are putting a cage on your truck then I would assume you will be using it in the future, I never thought mine would save my truck (not so worried about me) but I rolled it on its side on a rock face and as you can see, the only damage the was passenger fender and even that was minimal. Infact, the only thing that moved was the body, the cage didnt budge, its gussetted and tied into my front/rear bumpers and sliders and frame.
Click the image to open in full size.
good luck.
westy44runner is offline
Old 02-04-2005, 07:13 AM   #10 (permalink)
4Hummer's Avatar
Yeah I was going to say Notching the ends and welding them is supposed to be stonger than Bending.
Think about it. when you bend something your Stretching that material, thus causing it to be thinner and weaker in that area.
But this is a debate that has been around for a long time
__________________
Michael
1991 4Runner 22RE.
CHOP
4Hummer is offline
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Bush bumper and roll cage... toyotatom93 86-95 Trucks & 4Runners 3 07-19-2007 04:39 PM
Roll Bar or Cage and Lumber Rack? wrenchmonster The Fab Shop 6 03-31-2006 12:21 AM
3rd Gen. Roll Cage cubuff4runner The Fab Shop 15 12-20-2005 04:57 PM
New roll cage snwbdr Off Topic Talk 13 08-21-2004 09:12 PM
exo-skeleton roll cage joshik 95.5-2004 Tacomas & 96-2002 4Runners 0 11-26-2002 10:44 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
