YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-01-2008, 02:36 PM   #1 (permalink)
hross14's Avatar
Uses of Titanium and Water Jets and MISC
So i have been thinking for quite some time now about how to lighten the load on the 4runner.
A lighter rig would mean less breakage and better mileage.
So in my demented little brain and spare time-i have been thinking about Axles, Driveshafts, Bumpers, and MISC parts. Why not Ti axles and the such? Stuff would cost more but it would but more could be used for the same weight.
I know if it broke then you really couldnt fix it in the field without proper sheilding--but couldnt you just turn up the gas some--delay the before and after shielding. Also, as an axle, Ti can bend/twist more without being affected structurally.
So we go back to cost$$. I have been looking at machine hours rates and water jets run about $100 and cut anything. If you copy the part and just tell them--this is what i want out of Ti it shouildnt cost much more than buying it from 4wheel parts supplier (i am saying copy the original part--not somebody elses design.
Bottom line--i am really interested in this metal for certain applications.
Think about it--drop a rigs weight by 500lbs--and you have that much less stress on your parts.
SO WHAT SAYS YOU--do i have any machinist/Ti welders out there that will chime in? Metallergists (Spell check)....
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is offline
Sponsored Links
To remove this ad, register today!
Old 04-01-2008, 03:04 PM   #2 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
First, you need to figure out the cost of titanium. There is a reason they dont use it in metal fab, its far too cost prohibitive.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by 1972TLC View Post
DC, you're always #1, don't worry ;)
DeathCougar is online now
Old 04-01-2008, 03:08 PM   #3 (permalink)
hross14's Avatar
The costs are more--but if you do the design and yourself and take out the middle man--it get significantly cheaper.
for all intents and purposes let say you TIG the stuff yourself and buy machine/water jet hours.
You will see price come down quite a bit. I have priced rod and plate--and it is pricey--but doable.
__________________
hross14 is offline
Old 04-01-2008, 03:08 PM   #4 (permalink)
Second, you need to explicitly decide which parts you're interested in replacing. It will be very hard to gain a significant weight savings without replacing major parts such as major cross members, or even the frame itself.
Titanium probably isn't as good an option as aluminum, but aluminum might not really gain you much weight savings after you engineer the part to be just as strong or stonger.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 04-01-2008, 03:18 PM   #5 (permalink)
olharleyman's Avatar
I agree that the cost vs. weight saving is not going to be all that great and you will end up with a lighter weight 4runner worth a rediculious amount of money.
It is a good idea to try and find a way to lighten it up with stronger lighter parts maybe billet aluminum but that would still cost a assload after the milling and buying it.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 04-01-2008, 03:23 PM   #6 (permalink)
Erich_870's Avatar
What are the cost comparisons? Lets see some prices.
Also, the cost of cutting, machining or metal forming is still going to be very high. I agree that you will save money if you do the welding yourself, if you don't count your time as having any monitary value.
Erich
__________________
99' Black 4Runner with Highlander Package
16x8 black ProComp 1069 alloy wheels, Thule MOAB rack
My Profile
My Hobbies
Erich_870 is offline
Old 04-01-2008, 03:27 PM   #7 (permalink)
hross14's Avatar
[quote=hross14;50794537]
So in my demented little brain and spare time-i have been thinking about Axles, Driveshafts, Bumpers, and MISC parts. Why not Ti axles and the such? Stuff would cost more but it would but more could be used for the same weight.[quote]
These are the explicit parts-But let say for instance you made axle shafts--those are heavey--weight cut in half now---take my 115 lbs skid plate--cut that weight in half--lower links (that wont bend) cut that weight in half. Clockable T case member--cut that weight in half.....TJM at 105lbs--cut that in half, A-arms....drive shaft...brakets..... you get the picture
Axle housing--you can buy the tube already at the right size and then get to welding....
You dont have to think exactly when you are reducing the weight by 50%.
Problems i think about are--can it be splined like regular axles? If yes--i may be running Ti axles sometime in relatively near future.
__________________
hross14 is offline
Old 04-01-2008, 03:39 PM   #8 (permalink)
There are a lot of problems that you are not considering, not the least of which I doubt you can reduce the weight by 50% using budget minded titanium shopping. What alloy of Titanium are you looking at? Because just plain titanium doesn't have particurally good material properties...
You have to look at the material's stiffness as well as its yield strength to really decide how well it will handle as a replacement.
Sound like an etremely expensive operation to replace all of the little stuff on your 4Runner with Titanium... Axle shafts are small-time, not even worth the effort IMO. You might be on to something with your t-case x-member and front bumper, but it's doubtful you'll get a 50% weight reduction while retaining the same strength characteristics.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 04-01-2008, 03:41 PM   #9 (permalink)
titanium prices are going through the roof right now. we waterjet and laserjet all sorts of metals and alloys. titanium is a pain to work with. first it's not just the bar stock that gets costly . it's the additives to the water the can be expensive. just water doesn't work to well. welding with titanium isn't too easy . it warps pretty quick. so anything you make will have to be 1 piece . axle for instance will need to start out as a rod 7 inches thick and the shaped down so you can include the flange . all in all that will take a couple of hours and the cost for materials would be astronomical . kinda like a diamond toilet seat. looks nice and functional but can buy a normal one for $20. if your gonna spend money on axles just go dana 60's . for the price of one axle shaft you can get poison spider 9's front and rear. just my .02
4bytruckin is offline
Old 04-02-2008, 07:50 AM   #10 (permalink)
hross14's Avatar
4By--these are the items i really wanted to hear about. Didnt know axles were machined as one part.
Would it be possible to weld a flange to the bar and then machine afterwards to get it straight again? Or does that significantly weaken the axle..i.e. it really needs to be one piece? Alot of the Ti i have purchased thus far has only been waste sheet metal so it was actually pretty cheap. but i havent done anything with it yet. was going to try and weld on it....
The Question from other--Assume that due diligence would be done prior to taking on this venture concerning type of alloy, yeild strength......THIS WOULD CERTAINLY BE A SEMI kinda novelty. I would rather have this stuffs than a Rolex..get my drift
More expensive than buy quite a bit yes--look on some ones face when they ask why your stuff never breaks, rusts or why you get great MPG--Priceless....IMHO
__________________
hross14 is offline
Old 04-02-2008, 08:33 AM   #11 (permalink)
dirtoyboy's Avatar
you do know titanium is sold by the gram/ounce right? probably not the most cost effective material.....
Increases in aerospace building and industrialization in China have been driving the price up recently
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 04-02-2008, 11:15 AM   #12 (permalink)
hross14's Avatar
Yeah i have noticed the price jump--the Chinesse are driving up everything......Metal is getting crazy--there was time there for a bit when structual steel was about the same price as alum.
These are the kind of things i waste my money on though....dont drive a new car, can afford my house...NO WIFE OR KIDS Have two room mates and understand that it is cheaper to buy the tool and DIY on most projects.
I like to try something and see it fail then not to try it at all--
I wish we had more of these discussions here on the board.
My other idea(s) is to use UHMW for parts that hit rocks often--make mini skids out of them and when they need to be replaced--just cut a new piece.
__________________
hross14 is offline
Old 04-02-2008, 08:52 PM   #13 (permalink)
Tylerars24's Avatar
Send a message via AIM to Tylerars24
titanium is harder then aluminum but significantly softer than steel
titanium splines would have to be huge to handle the same torques as their steel counterparts.
that rules out: transmission internals, driveshafts, axles, what else?
cost is the next factor.
__________________
pickup, sas, 63s, custom high-steer
Tylerars24 is offline
Old 04-02-2008, 09:22 PM   #14 (permalink)
tc
tc's Avatar
OK - let's stop with the speculation and misinformation now.
I am a metallurgist with about 10 yrs of working for the nation's #1 and #2 manufacturers of titanium (www.timet.com www.allvac.com)
The graph above is modulus of elasticity, not strength or hardness. Think of modulus as "stiffness". Titanium is VERY springy stuff.
Strength-to-weight of titanium alloys is better than most anything out there. As a matter of fact, for our applications, it may indeed be the ultimate material if other factors were the same. The strength of alloyed titanium is higher than low alloy steel, and the density is lower. Weight savings of 70% are typical for properly designed parts.
Unfortunately, the other factors aren't the same - not even close:
FIRST
You may be finding scraps for a reaonable price, but just a forged billet goes for $10/pound - we had some thinner sheet that was over $100/lb! Tubing is even higher due to the fabrication issues. This project is going to be seriously spendy!
SECOND
Welding titanium is more difficult than you can imagine. It NEEDS to be done in a vacuum or a totally inert atmosphere. Titanium is VERY reactive, especially with oxygen and nitrogen at elevated temperatures. If there is even 1 molecule of O2 or N2, your weld is crap.
THIRD
Machining of titanium is not technically any more difficult than steel, nickel alloys, or aluminum, but it is a helluva lot less forgiving. Your feeds and speeds have to be dead on or you will never hold any kind of tolerance due to the low modulus. The chips are flammable (think magnesium, only worse) so care has to be taken in shops where they do it - Joe Machinist on the corner has no business trying to do titanium.
(To illustrate how reactive titanium is, if we had a cooling water leak in our melting furnaces, the shop had to be evacuated IMMEDIATELY as the Ti would steal the O atom off the water molecule - you would get a steam explosion, then a hydrogen explosion)
SO, titanium could maybe make sense for simple sheet metal parts that could be fabricated by shearing and braking, like skid plates, but for anything truly fabricated, the costs rise so sharply that it would be insane.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 04-03-2008, 07:23 AM   #15 (permalink)
hross14's Avatar
And now I know--and knowing is half the battle
I have read alot about Ti, but getting first hand expereince is certainly more useful...
I knew Ti was reactive--just not that reactive. Was thinking more along the lines that when you welded it (using Argon right) you have to have long shielding times before and after the start of a weld.
Like i have said before...Like seeing if something can be done and then being told it cant versus just not trying new stuff at all.
So stamped parts and sheet metal stuffs is what we are left with then.
If i may ask--How Do y'all weld the stuff? It can be tig welded right as long as you have the right inert gas? What is used as a cooling fluid when machining--oil?
Thanks for the info
__________________
hross14 is offline
Old 04-03-2008, 11:09 AM   #16 (permalink)
Erich_870's Avatar
FIRST
SECOND
THIRD
Talk about a buzz kill!!
Thanks for sharing such good info! I've always wondered and it's great to see Yotatech's diverse and well educated membership step up with top industry knowledge.
Erich
__________________
My Profile
My Hobbies
Old 04-03-2008, 11:47 AM   #17 (permalink)
tc
tc's Avatar
Can be TIG or MIG.
Standard cutting oil fluids are used, generally high lubricity versions, with TONS of flow as machining Ti generates quite a bit of heat.
http://www.timet.com/pdfs/ti-handbook.pdf
__________________
tc is offline
Old 04-03-2008, 12:19 PM   #18 (permalink)
hross14's Avatar
Thanks for that read TC--i think i just might try some Ti projects and see what happens. That pamphlet had some of the best info i have read as of yet. to the point--common sense and the little things you need to know about doing it.
I think my first project will probably be a skid plate and the T-case mount so i can flatten my belly-
you dont have a small time supplier you recommend do ya?
