Tube Bumpers
Tube Bumpers
How would I build a set of Tube bumpers for a 92 ford ranger??
I planned to have strait piping accross the front then go off onto a 90 degree elbow or bend, but the elbows are 45 bucks a peice and the pipe is 156 for all of it
this is not including flat iron to mount them
Curtis
Curtis
Guest
Posts: n/a
I say take the 45 degree elbows, twist them 90 degrees on the z-axis, then tac um. Then turn them 65 degrees on the y-axis and tac um again. At that point, turn the straits into swooping 35 degree arches, opposing arches that is...and tac um to the 115 degree ZY-axis elbows. Put some frilly lace wrought iron in between the arches and tac it. Paint type-R on there and call it good. Just my .02 cents.
All I can say is It will "ROCK"!
check out www.jamesduff.com for ideas.... also head on over to www.explorer4x4.com i belong to that message board and there is tons there.... any front end part that will fit a 89-92 ford ranger will also fit a 91-94 ford explorer
1uzRunner
63
11-10-2018 03:58 PM
justdifferentials
14
06-11-2017 08:36 PM
