Traction Bar Fab - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-18-2007, 12:16 AM   #1 (permalink)
Elvota's Avatar
Traction Bar Fab
Goal: try and keep my axle from wrapping and add protection for the rear driveshaft while I was at it, all the while not limiting flex or articulation.
Decided to go with the shackle style instead of a "slip and twist". Seemed simple, more bullet proof and wouldn't bind if I ever had the misfortune of bending.
I had an old pair of Marlin shackles laying around, so I shortened them a bit. Designed and built the front pivot to mount on the factory horseshoe crossmember. Then picked up a set of shackle mounts from TG for the shackle to pivot through.
Side pic (still working on the whole "welding as art" thing ):
3/4 view:
Pic of it mounted with shackle installed (driveshaft removed):
Now I needed brackets for the axle. I mocked them up with cardboard first, then hit a friend of mine who had a plasma cutter and wasn't afraid to use it... plus knew how.
Pulled apart the axle, removed the housing and welded the brackets on. The main brackets are 1/4" plate, other gussets and reinforcements were cut from some 3/16" plate I had laying around. Pic of brackets on the axle:
For the bar itself, I knew I wanted bushings for the rear mounts, and they had to be stout. So I got these from Rubicon Express (Part #RE3765):
The front of the bar needed to be able to twist with the axle, and also be as bulletproof as possible. Back to Rubicon Express (Part #RE3792):
Both parts where quality, huge, and used 9/16" hardware. As mentioned before, I wanted the bar to double as a bash guard, so not only did it have to fight axle torque, but defend against the rocks as well.
The lower section of bar had to be the toughest, as that would take the brunt of any impact. I sleeved some 1.75" DOM with some scrap HREW I found at the local yard that happened to be a perfect fit. Probably ended up to greater than 1/4" wall thickness when I was done.
4 plug welds, plus internally welded at the tail and around the front seam. What once was two will now act as one... thank you sensei.
As an added benefit of this design, I was able to lengthen or shorten the lower bar ever so slightly for a perfect fit when I began final assembly: (pic before welding)
So now I had to get all the parts welded together, add a cross support... then another plate support. This is what I came up with. It's upside down in this pic. I had the top bar bent 15 degrees in order to clear my muffler:
Then of course I had to paint it... GREEN... and mount it as so:
From the rear:
I tested it around the block, then out on the trail. Does seem to have lessened the hop I was getting off road, but time will tell. Generally a more solid feel overall. Took the 4Runner out on one of my favorite known trails in an attempt to get a non-biased seat of the pants opinion. No binding. No clearance issues. I must have done a few things right.
Found this guy in a creek bed while I was out doing R&D. Probably as big as a a basketball!! Don't see the desert tortoise very often, especially that size. He just needed a Marlin Crawler sticker and he would have been good to go:
I had been tossing some ideas to my fellow YT'rs during the build which helped a lot. Maybe this thread will return the favor and give others ideas to go on.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Old 08-18-2007, 12:36 AM   #2 (permalink)
111db's Avatar
Send a message via MSN to 111db
looks cool, great write up Steve. Let me know when you're looking to test it out. I got some new goodies too.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 08-18-2007, 03:27 AM   #3 (permalink)
tortis's Avatar
nice write up. i noticed you exited your exhaust in front of your rear tire. has that given you any problems, like over heating your tire on long highway trips/ i was thinking about doing the same thing is the reason i am asking.
__________________
89 Truck X-tra Cab
LCE Timing Chain
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
tortis is offline
Old 08-18-2007, 09:12 AM   #4 (permalink)
Elvota's Avatar
Quote:
I am heading up to Utah for some siteseeing/ hiking the week of 8/26... but maybe after I get back. Would be nice to get another AZ run going.
Quote:
I have never really been happy with the way my exhaust turns out on this vehicle. I have reworked it several times. I have no issue yet with the way it currently is, but may end up extending or turning down the end. It's hard to tell from the pic, but it's close to a foot away from the tire.
__________________
Elvota is offline
Old 08-18-2007, 02:40 PM   #5 (permalink)
SteveO's Avatar
Send a message via Yahoo to SteveO
Great write up and great job on the workmanship. Looks like you have a solid setup there that should last you quite a while.
SteveO is offline
Old 08-18-2007, 07:28 PM   #6 (permalink)
westy44runner's Avatar
the color is the best part.
__________________
'86 Toy Flatbed with a few modifications
westy44runner is offline
Old 08-18-2007, 07:39 PM   #7 (permalink)
Send a message via AIM to the_gunslinger
looks excellent.
why doesn't my truck have rear disc brakes?
the_gunslinger is offline
Old 08-18-2007, 11:05 PM   #8 (permalink)
Elvota's Avatar
Quote:
The best part will be leaving that color behind on the rocks.
Quote:
Because you probably have better things to do than crawl under your truck and mess with stuff all the time.
http://www.yotatech.com/f116/rear-disc-swap-107749/
__________________
Elvota is offline
Old 08-19-2007, 07:12 PM   #9 (permalink)
TachedOutOffRoad's Avatar
Nice fab work If you spend that much time on everything on your truck, it must be clean! People dont appreciated the time it takes for good fabwork
We usually make the lower mount not lower than the axle tube though rock magnet
__________________
Cant be scared of the skinny pedal.
www.tachedoutoffroad.com
"If you think that your IFS is better than my solid axle, then your opinion is no longer valid."
-Eric Jones, T.O.O.R. Vice President
TachedOutOffRoad is offline
Old 08-19-2007, 10:32 PM   #10 (permalink)
Elvota's Avatar
Thanks for all the compliments guys. To be honest, I still have a ways to go with my welding, but getting better. You'll notice I don't have any really close shots showing off my amazing bead. Practice, practice.
I had thought about lowering my clearance as I did. Realizing more ground clearance is better, I tried to split the difference. Figured if I am going to drag something, it may as well be something that has been made to be drug. I am hoping the flat angle of the bar will ramp over most hangups... but I guess we'll have to see.
Part of the fun. Design, fab, test... repeat.
__________________
Elvota is offline
Old 08-24-2009, 10:22 PM   #11 (permalink)
xyzalvarez's Avatar
back from the dead and booked!
xyzalvarez is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
spring swap and traction bar questions. wimpywade94 The Fab Shop 5 11-11-2008 05:40 AM
Strigth Axle Traction Bar corvettelvr73 84-85 Trucks & 4Runners 1 05-02-2007 09:51 AM
Traction Bar Yota1 95.5-2004 Tacomas & 96-2002 4Runners 7 10-10-2006 12:29 PM
Traction Bar For 02 DoubleCab dhsavage 95.5-2004 Tacomas & 96-2002 4Runners 3 09-11-2006 04:23 AM
Traction bar designs? MDNT TOY 95.5-2004 Tacomas & 96-2002 4Runners 3 05-13-2005 12:34 PM
2009 InternetBrands, Inc.
