| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
toyota rear into jeep?
#2 (permalink) |
A YJ Wrangler or a TJ Wrangler?
A YJ should be no problem, assuming the two axles are about the same width. Just pull the crappy Dana 35 out, cut and reweld the Toyota spring perches to match the spacing of the Jeep's leaf springs, and bolt it on. You would get a pretty big lift by doing this since you'll be going from spring under to spring over. The brake lines would need a little bit of attention 'cause the Jeep stuff is probably SAE and the Toyota lines are metric. I know I've seen where people swapped a Toyota axle into a Cherokee, but haven't heard of doing it in a Wrangler.
__________________
Click here to buy rock crawling stickers and shirts |
#3 (permalink) |
Why not go for broke and put some Unimog axles under the Heep?
#4 (permalink) | |
Quote:
__________________
92 pickup... sold 90 integra- b18b turbo, intercooled, 10 lbs of boost, 240 whp... blown up 79 2wd yota pickup Last edited by Yamaha+Toyota=Fun; 07-02-2005 at 01:15 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| What happens when a Jeep and a Toyota collide? | getitdone | Off Topic Talk | 19 | 07-17-2006 05:21 PM |
| Jeep vs. Toyota | sswearin1 | Off Topic Talk | 3 | 05-10-2006 02:57 AM |
| how can i prove toyota is better than jeep? | Rollindamud | Off Topic Talk | 29 | 01-04-2006 07:24 AM |
| Jeep Rescuing Toyota | 4RocRunner92 | Off Topic Talk | 5 | 12-17-2005 08:45 PM |
| Older Toyota p/u, Toyota 4Runner or Jeep TJ? | HBoss | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 05-31-2003 04:43 PM |
