Taking Welding Class - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Old 08-21-2007, 09:01 PM   #1 (permalink)
Shoua's Avatar
I'm taking a TIG welding class at my local community college. I want to know: what kind of welding do you do? Why do you choose that style? And lastly, can you post pictures up of what you do? Thanks.
Shoua is offline
Old 08-21-2007, 10:10 PM   #2 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
i use MIG because it's cheaper, easier, and i never need to use TIG with the materials i work with. i would love to get good at TIG someday though. MIG is just a little more practical IMO.
everything done on my 4Runner was done with MIG... http://www.yotatech.com/f88/93-4runn...uild-up-82675/
__________________
-Mikey-
1993 4Runner ~ TG 5" HD/RUF front | All Pro ~4" rear | 37" Krawlers | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo
Polygoats 4-Wheel Drive Club -> check it yo
4RunnerKid is offline
Old 08-21-2007, 10:19 PM   #3 (permalink)
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
Send a message via AIM to drguitarum2005
i took a class that was stick and mig. we spent the first two weeks cutting with oxyacetylene then we moved on to stick welding for a few weeks and once we perfected that we went to MIG. MIG was MUCH easier IMO, but im glad I learned stick first. TIG isn't practical for me because everything i need to do doesnt require precision and just needs brute-force strength, which stick and usually MIG can give me.
__________________
-David
2000 Taco TRD Access Cab
v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights
Pictures
drguitarum2005 is offline
Old 08-22-2007, 05:20 AM   #4 (permalink)
amgraham's Avatar
Send a message via AIM to amgraham
I do mostly MIG also. I would like to learn TIG sometime but MIG works well for the general purpose welding I do. Here's a bumper and tire carrier I made for an Xterra this past weekend:
Lots more pics of the build here: http://s63.photobucket.com/albums/h1...ire%20Carrier/
__________________
1987 Toyota 4Runner
Specs Here: 4Runner Page
Member VAXC, RVA-OR
amgraham is offline
Old 08-22-2007, 10:01 AM   #5 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
I learnt to weld with a cheap stick welder at home. Then a friend left me practice with a +4000$ TIG welder and now I want one hahaha
It's so nice to weld things without adding material... And if you need to add metal it's something like wire soldering, you've liquid metal drops that you can move and let them where you want, very nice.
I've used also MIG and it's way easier than stick, but as David says, it's a very useful learning method.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 08-22-2007, 06:30 PM   #6 (permalink)
I use a mig too because it is cheaper. Very little stick unless I need to weld something very thick. I would love to have a tig but not in budget.
__________________
92 ex-cab straight axle swap 9.5 suspension and 2 in body lift, 350 V8, V6 trans 4cyl transfer case with 4.71 crawl kit, 5.29 gears, 39.5 Irocks
99 Taco 2'' suspension 3'' body lift with 33's.
V8pickup is offline
Old 08-22-2007, 07:23 PM   #7 (permalink)
4Crawler's Avatar
I took stick, gas, TIG and MIG welding in about 2 years of classes at my local adult ed center. We learned in that order to gradually work into TIG. With stick you learn the arc control w/ one hand along with the various welding positions. With gas you pick up using both hands, one for the torch and one for the filler. Then TIG, you combine stick and gas and add the foot control as well. Makes for great welds on alum. and stainless steel for sure. I found it took me ~30 minutes of practice each night after work to get into the swing of TIG every class. After that, MIG was a piece of cake.
I started with a stick welder at home, then picked up a wire feeder and also a TIG machine and finally a MIG for production use since it is faster. I do want to get back into TIG, as I have some aluminum welding projects planned.
But did a lot of stick welding, which I find more "satisfying" than MIG., since it takes more finess than "pointing and shooting" with the MIG gun:
Hydralic-assist ram mount:
Sliders:
http://www.4crawler.com/4x4/ForSale/...it_HowTo.shtml
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-22-2007, 07:25 PM   #8 (permalink)
Shoua's Avatar
I was told that I could TIG weld more different metals than MIG welding. I also have heard that MIG is easier to learn. So is MIG stronger than TIG? I want to hopefully create some parts for my pickup in this class. Will TIG hold up to 4-wheeling?
By the way, those are some nice welds on that tire carrier, amgraham.
Shoua is offline
Old 08-22-2007, 07:39 PM   #9 (permalink)
4Crawler's Avatar
Quote:
TIG is probably the most flexible welding process, you can weld most anything with it, l like steel alloys, stainless steel, aluminum, titanium, etc. MIG can do a pretty good job on steel and alum. Given a good weld/penetration, all processes can yield an equally strong weld, basically as strong as the base metal. TIG will probably give the cleanest welds (and it is also the most sensitive to outside contamination in the weld area) and probably has the best heat control. That could make it a little "stronger" in that you can minimize heating of the surrounding metal. If you can make a good looking TIG weld, it'll likely be a good weld. With MIG, it is like my instructor said the first night of MIG class:
Quote:
What do the letters "MIG" stand for? Maybe Its Good!
With MIG, you can lay down a nice looking bead but have a poor weld joint.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-22-2007, 07:44 PM   #10 (permalink)
95SASMudRunner's Avatar
yea i mainly do mig because of its cost, i just picked up a stick welder and am in the process of learning i would kill to be able to take a class i just cant find any locally
__________________
1995 sas 4runner worked on by Cornfed... blew up week later
1993 SAS 4Runner, 4.88s, locked front, TRD e-locker rear with Inchworm kit, 35x12.5 BFG MT's, rock crawling rear bumper, All Pro front tubular bumper with Mile Marker SE12000 winch, Hella 500's, front & rear hitches, sliders, k&n drop in with ARB snorkel, custom duals, Federal Signal siren with whelen red strobes! custom front spring mounts rear susp. added another 2" of susp lift totaling at about 9"
95SASMudRunner is offline
Old 08-22-2007, 07:50 PM   #11 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
Metal Inert Gas
i am learing with a mig welder that i bought years ago and just finally got hooked up.
you can weld with flux core wire, but its horrible. dont do it. go get a gas cylinder and weld with a co2/Ar mix.
i dont have pictures of actual welds with it. but this is my first project for the truck, besides lots and lots of scrap material that i practiced on.
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, 1" 4crawler body lift, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Old 08-22-2007, 08:15 PM   #12 (permalink)
amgraham's Avatar
Thanks! I still haven't gotten around to taking classes yet but knock on wood, I haven't broken a weld yet
__________________
1987 Toyota 4Runner
Member VAXC, RVA-OR
amgraham is offline
Old 08-22-2007, 10:21 PM   #13 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
I just started my welding class monday. It covers mig,tig,arc,plasma. Im hoping to learn alot from this class. Ive heard tig is great to learn and if you get good at it then you got some job security.
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs and 3" rear downey springs
D-tech Shocks
33x12.5 M/T , 15 inch weld rims
Hella 550/ Hella h4 conversions with HID
Home made On-board air system
deserttoy84 is offline
Old 08-22-2007, 11:07 PM   #14 (permalink)
Shoua's Avatar
4Crawler, those are some nice welds too.
The class I'm taking only covers TIG. There are other classes at different times though, that cover MIG and ARC. I just chose begin with TIG. Next semester if I don't take another welding class, I just might take machine shop. Then, if I'm good at both, I could make anything I want.
Shoua is offline
Old 08-22-2007, 11:46 PM   #15 (permalink)
2KTacoma's Avatar
The ultimate TIG setup would be an airtight chamber you can fill with argon and have the parts in it, that would result in 100% clean welds.
alot of people use argon jets when welding Ti they just have a nozzle aimed at the area they are welding.
__________________
Silver 2000 Toyota Tacoma Extended Cab V6 5spd SR5
Now with URD short shifter and
Milled polyurethane shifter seat
Hella FF1000 Driving Lights
2KTacoma is offline
Old 08-29-2007, 07:44 PM   #16 (permalink)
Anubiscougar's Avatar
anyone know of any classes around/in the orlando florida area??
Anubiscougar is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Motorcycle class Tacoma Dude Off Topic Talk 29 08-23-2007 11:36 AM
Denver welding class MellamoPOUND Off Topic Talk 3 10-27-2005 01:50 AM
Did I Miss Anything in Class? msw0085 Off Topic Talk 1 09-30-2005 07:56 PM
Welding Class MellamoPOUND Off Topic Talk 1 04-14-2004 12:18 PM
Class of Hitch?? dlotoy4runner 95.5-2004 Tacomas & 96-2002 4Runners 7 10-28-2002 01:58 PM
2009 InternetBrands, Inc.
