YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-18-2008, 07:04 PM   #1 (permalink)
Team420's Avatar
Stick Welding??? WTF???
Ok...Someone please tell me what im doing wrong. I know how to mig and tig weld, I learned tig welding with aluminum, supposedly its the hardest to learn.
I cant for the life of me lay a bead with this stick welder! It is a pro-arc 1150, yes a tiny one... something like 115 amp, and it runs off a regular 110 outlet.
I am only trying to practice on an old rotor I had kickin around, I have an assortment of different rods.. the one that works best so far is a 6011, I cant read the #'s on the others, but the 6011 are about 1/4" diameter. and I have others that are much bigger, and a box of thin rods.
I guess my question is...am I wasting my time? Is this welder powerfull enough?
TIA....sorry for the newb question, but I have never used one of these before.
Ya...btw, now I know why its called stick welding...cuz your rod always sticks to the metal...lol
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock.
It's becoming an addiction.
Team420 is offline
Sponsored Links
To remove this ad, register today!
Old 07-18-2008, 07:08 PM   #2 (permalink)
76ANTHONY's Avatar
does it have heat settings. and do you have some thin stick to practice with? its a tad easier....
76ANTHONY is offline
Old 07-18-2008, 07:25 PM   #3 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Never seen a stick welder worth a damn that didn't run on 220.
I would imagine with a 115 you'd want a very thin rod.
waskillywabbit is offline
Old 07-18-2008, 08:28 PM   #4 (permalink)
you need pretty thin rods for that stuff, even 1/4" is pushing it. You're not passing enough current to fully melt the stick. I'd imagine you're getting pretty cold, spotty, splattery welds?
Why are you stick welding anyway? Just use your MIG with fluxcore and no gas if you really want to
NicCantDecide is offline
Old 07-18-2008, 08:28 PM   #5 (permalink)
4Crawler's Avatar
Yes, you would want 1/8" or even thinner rod for that, I carry some 3/32" rod for use on the trail with either batteries or my on board welder (also have the 1/8"). 6011 is a good easy to use rod, you need to run it with the electrode positive (work grounded):
- http://www.4crawler.com/4x4/CheapTri....shtml#Welding
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-18-2008, 09:57 PM   #6 (permalink)
Team420's Avatar
Quote:
Yes, It goes from 10a to 100a, the thiner rod gets real hot real fast, and if it is on full blast, it actually drips.
yes.. cold splattery, lumps. I do not have any other welders... I just know how to use them...I worked in a metal shop for a couple years.
Work is grounded(actually bought a new clamp, cuz it didnt seem like it was grounding well) the 6011 is by far giving me the best "bead", but it is not consistent. Thanks for the link... I will check it out, and keep trying.
I got this welder from a friend, found another for $250 that runs on 220 and uses up tp 350 amps... maybe that is the solution.
__________________
DD:
Project:
Team420 is offline
Old 07-19-2008, 12:15 AM   #7 (permalink)
scuba's Avatar
Location: Selling turnips on a flatbed truck, I 15N @ 79S
I mean, if you know how to weld on the others, just keep practicing with that 6011 and youll get it.
In High school i started with stick, then went to mig then tig,
stick was the hardest i think.
If you have some cash lying around i would pick up that other welder.
Just my 2 cents
__________________
^Say GO DJ..Uh thats my DJ
The Blue Biche
91 4x4 p/u 22re--elbow mod, 500ff's. BFG A/T ta KO's. Smokey the Bear
I Work on my gas tank while smoking a cig...Sue me
Dad- 1999 4runner base 2x4, 2.7, 5speed, 52k, cherry.
Chat with meeee
Quote:
Originally Posted by 904_runner
Im still waiting for obama to redistribute the truck parts
Quote:
Originally Posted by Sin91
Technically I would have to share it with everyone who didn't have a beer if I was Obama
Pacific Crawlers
UltimateYota
scuba is offline
Old 07-19-2008, 06:41 AM   #8 (permalink)
4Crawler's Avatar
I have a 220 volt stick welder, I think it does 230 amps/AC and 140amps/DC and that works great with 1/8" rod. I think I paid around $200 for it with a boat load of extras.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-19-2008, 07:17 AM   #9 (permalink)
algranger's Avatar
i started learning a month ago and at first i was SO pissed cause i couldnt get the arc going, i had to take a bunch of brakes cause i was so frustrated. its like striking a match but instead of just swiping you swipe the stick on the metal and then stop half way and hold it a little bit away, i know its frustrating to say the least but youll get it. just keep trying. thinner electrodes are generally easier to weld with although i had the easiest time with a 6011 but i was at 160 amps. as for a welder id go pick up a little lincoln theyre not too expensive but theyre one of the top names in with hobart and miller.
__________________
Hi-Tech Redneck
algranger is offline
Old 07-19-2008, 08:03 AM   #10 (permalink)
Team420's Avatar
Thanks for the tips guys. Im thinking that if I do buy a welder, ill prob get a mig, dont see much sense in spending $ on something I dont know how to use.
Just curious... but why would anyone use a stick over mig any way? I guess I heard that stick is easier to use(though I would never have guessed), and more versatile. Is stick really that usefull? Or do u need stick to weld real thick metal?
Sorry...I know...newb questions again.
__________________
DD:
Project:
Team420 is offline
Old 07-19-2008, 08:11 AM   #11 (permalink)
Sponsoring Member
A stick welder is more versatile as it doesn't require a separate shielding gas to lug around and you can weld in a wider variety of environments. Try MIG/TIG welding outside in a breeze.
When I learned to weld you were taught oxy/ac torch stuff first, then stick in all positions before you even got to touch a MIG/TIG.
I have a Millermatic 251 MIG machine that will weld 1/2" one pass.
Stick makes a lot more splatter, but it is more versatile than MIG, but you have to clean up the welds from the slag (as the flux is on the rod) with stick too.
I prefer MIG when working on vehicles, but stick is great for outside applications like repairing farm equipment (and you don't have to prep the metal as much with stick).
HTH
Old 07-19-2008, 08:23 AM   #12 (permalink)
hurley842002's Avatar
HTH
x2 and I hated oxy/ac, I was too eager to get on the arc and always burned holes with the oxy/ac.
__________________
1986 4runner
31" mt's
aftermarket shackles
Custom front bumper/winch
Light bar/auxilary lighting
Rear Detroit
future mods:
33's maybe 35's, 5.29's, Rear bumper with tire/jerry can,highlift mounts, sliders. Conquer with the IFS until I can't conquer anymore and then do an SAS.
hurley842002 is offline
Old 07-19-2008, 08:24 AM   #13 (permalink)
For all my big projects I use a stick. I liked it because it is cheaper and much simpler than the mig (not many moving parts) It does require alot more cleanup of the slag on the weld and th shop floor But for the price it is great and you can do fine welds with it if you have enoguh practice. It is kind of daunting to use it at first, but once you do it, it is handy to know especialyl if you have to put a few batterys together in the field. You can get cutting electrodes and use the welder to blast throguh some metal, but it makes a hell of a mess. I have a small MIG for sheetmetal and small brackets. Stick welding gets alot of flack. It is perfectly fine to use for projects. I get the impression alot of peopel hate stick welders just because it is harder and they havnt gotten to use it proficently.
__________________
Dan Stewart
1952 CJ3a
1989 4Runner
DanStew is offline
Old 07-19-2008, 10:19 AM   #14 (permalink)
Team420's Avatar
Try MIG/TIG welding outside in a breeze. Ya I know.
I think thats my problem... I learned by tig welding thin aluminum.
Thats what I'm talkin about.
I dont mind all that...just wanna learn to lay a bead... so far, all I can manage, is a 1" long slug.
This is what I thought.
HTH
Yes it did...thanks
Quote:
This is also what I thought... and even if after I learn decide to go back to mig, I still wanna know how.
__________________
DD:
Project:
Team420 is offline
Old 07-19-2008, 10:23 AM   #15 (permalink)
It is good to know. I have been wanting to learn to torch weld so i can have that knowledge, unfortunately i have nobody that i know locally to show me. I dont have the time right now to take classes.
__________________
Dan Stewart
1952 CJ3a
1989 4Runner
DanStew is offline
Old 07-19-2008, 10:44 AM   #16 (permalink)
texcat101's Avatar
Look in the pawn shops swap shops etc. I have bought 2 small migs for under 150.00 in the last couple of years. One was a Lincoln 120 amp flux core wire setup it lays a pretty bead. IMO If you weld in a shop out of the wind thats all you need for auto work.
__________________
85 4runner, 22re, 3" spring lift, Precision Gear 5.29's w/power brute posi frt & rear, Mickey Thompson Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors '94 calipers and booster.
4.3 / 700r4 swap in progress - MORE POWER
http://i304.photobucket.com/albums/n...01/43v6007.jpg
texcat101 is offline
Old 07-19-2008, 10:58 AM   #17 (permalink)
rhah's Avatar
delete
rhah is offline
Old 07-19-2008, 10
