Square tube Sliders
Old 03-07-2013, 04:10 PM
ThatGuy1295's Avatar
Thats a good first try. Id redo them out of something thicker, atleast 3/16'' and either a bigger diameter or add more bars and some gussets as well as plating the frame and you will be happier because you will actually be able to use them against rocks and trees. Rock bars have a tuff job and need to be really strong, otherwise you might as well go with some cheapy smitty built steps if its the look your after.I think those are 1/8'' wall as well. Another thing is you might as well have them go all the way to the front of the door instead of starting so far back. I do like the look of those, so you might aswell make them tuff enough to use.
Old 03-07-2013, 04:49 PM
And cut those u-bolts down,, gees...
Old 03-08-2013, 07:00 AM
courtgordon's Avatar
ok so i went out yesterday and tried to rip the rockers off on some boulders after hearing all of the thoughts of them not working i figured if i succeeded in tearing breaking or bending them ide add at least one more leg. but they held up just as i had thought i actually tried to inflict damage and slammed down with force directly on the slider on a couple different boulders and they just slid me right off. on one rock i actually high centered myself on my slider and got stuck for a couple minutes since i dont have lockers yet the 2 tires on that side were just spinning but i managed to eventually work my way off. so after withstanding the beating with only scratches im sure theyll be fine. and i was wrong about the thickness i checked a scrap peice i had and it is 3/16 and its hard to tell from the pictures but the support bars are plated and braced along the top to prevent any bending upwards with 4 bolts off each leg attaching it to the frame. and ya i guess i never really noticed the u-bolts ill have to hack those down thanks. unfortunantly i didnt get any pictures of my rockers when they were slammed onto the rocks but this is one of the rocks i drove forward off of and let the slider smash down hard instead of tryin to ease it. ill try and get some pictures of the sliders up on a boulder soon but thanks for the tips some of it has been helpful
Old 03-08-2013, 07:05 AM
and OLTOY they held up fine to impact and smashing off of rocks i was harder on them in this test trial than i probly ever will be again. just cuz its not how you would do something dont mean it doesnt work, theres more than one way to skin a cat my friend just like the IFS flex thread just cuz you dont like it cuz your all about SAS doesnt mean its no good.
Old 03-14-2013, 10:42 AM
  #25
SHINE RUNNER's Avatar
i'm proud they work if they suit you for the kind of riding you do thats all that matters.oh and about the ifs thread i was just getting a rise out of em. . that junk won't last and its to weak for the type of riding we do where i'm from. i'm leaving it be.let em flex
Old 03-15-2013, 07:16 PM
  #26
Typically "riding" means your on a motorcycle. Now "driving", "wheeling", "rallying", or in some cases "commuting" is what us Americans do in our toyotas. We dont ride our trucks.
Old 03-16-2013, 07:30 AM
  #27
your not from alabama must be california or up north somewhere.i've never heard anyone say hey lets go wheeling.3 people called this morn and asked me to go on a big ride,you know thats where a bunch of 4x4's get together and go. trailgear sponcered a ride i was in. restricted only for toyotas and it was called only toyotas ride,every year since i can remember the day before easter there is one called the easter ride there is about 1500 people at that one you won't hear anyone saay hey we're wheeling.oh and if your in a vehical or rig or whatever,driving it or not your still riding in it
Old 03-16-2013, 07:41 AM
  #28
never mind
Old 03-28-2013, 04:07 AM
  #29
86toybox's Avatar
I built my sliders on my 86 4runner with 1.5" square tubing the same thickness as you and decided to test them out and when I came down on a rock I heard "BANG SCREECHHH" and they worked perfectly.
Old 05-21-2013, 10:21 AM
  #30
MudRunner92's Avatar
im trying to do this with the running boards on my 4R. is that where they are mounted?
Old 05-21-2013, 12:02 PM
  #31
highonpottery's Avatar
no. rock sliders replace running boards and get either welded or bolted to the frame to provide rigidity.
Old 05-23-2013, 08:12 AM
  #32
^ like highonpottery said they are bolted to the frame for a stirdy mount to give protection and allow sliding or pivoting over rocks, stumps, water bars, etc...
Old 01-01-2015, 12:37 PM
  #33
vexzer's Avatar
Gonna do something similar. Thanks for posting.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
Badlander
10-10-2015 08:05 PM
mreagen
10-05-2015 04:27 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Square tube Sliders
