Spare Tire Area Gas Tank Ideas!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-15-2004, 12:32 PM   #1 (permalink)
Send a message via AIM to ravencr Send a message via Yahoo to ravencr
This thread is splitting off my thread about my rear bumper, because there obviously needs to be some discussion about it separately. Here's some recent information regarding the rear tank http://www.yotatech.com/showthread.p...&page=7&pp=25:
Here's some pics of the tank:
well, with your design you may not need to. your tank is wider than it is long, so you probably wont feel the effects of moving fluid when you start and stop as much. on sidehills though, a sudden change in motion could easily throw all of that gas to one side of the tank very quickly. its low enough it probably wont cause a roll, but to be safe i would divide the tank into 5 sections.
_____________
| | x | | 'x' marks your fuel pump
|____|___|___|
| | | <---this is the tapered rear part of your tank
|______|_____|
picture this as a top view of your tank. at the bottom of your baffles you only need a 1/2" hole to let the gas flow through.
__________________
-Peter
1986 4Runner SR5, 31's, EZ locker out back, truetrac in front,
Capital City Crawlers of Central Missouri
Quote:
_____________
|____|___|___|
|______|_____|
Man, I'm really having a hard time picturing that, but it could just be me. Let's move this gas tank discussion to another thread, okay, and let's keep this focused on the rear bumper for now.
Chris
ravencr is offline
Old 02-15-2004, 01:04 PM   #2 (permalink)
Napoleon047's Avatar
the BB wont hold my spaces, so here is what i was trying to illustrate, hope it is clearer
__________________
-Peter
86 4runner SAS - Trail Rig
94 FZJ80 - DD
the dirt cheap SAS
Marko Customs
Napoleon047 is offline
Old 02-15-2004, 01:11 PM   #3 (permalink)
I gotcha! I'm pretty sure though that my stock fuel pump assembly won't work, because the 8" depth isn't enough. Do you have any other recommendations for fuel pump assembly? I was thinking a simple inline fuel pump and filter, but what do you think? If I did that, where would I put the fuel and return lines?
Chris
ravencr is offline
Old 02-15-2004, 01:11 PM   #4 (permalink)
here is a higher res version that i hosted
__________________
-Peter
94 FZJ80 - DD
the dirt cheap SAS
Marko Customs
Old 02-15-2004, 01:30 PM   #5 (permalink)
i would go ahead and use either a round or square bolt on plate to mount the fuel and return lines, that way, if you ever need to remove the tank, you could unbolt it, and you have an easy way to look inside the tank.
what are you doing for a sending unit? i think your best bet its a GM style like summit racing #SUM-290180. it is a 0-90ohm unit, toyotas use a 90-0ohm unit. your guage will read backward, but it will work and be accurate, you could always change your guage letters around and such if it really matters
edit: the sending unit has an 8.5" depth which is the closest i could find for your tank specs, so you could either make a raised mount in the top of the tank, or you could increase the depth by .5"
__________________
-Peter
94 FZJ80 - DD
the dirt cheap SAS
Marko Customs
Old 02-16-2004, 07:37 PM   #6 (permalink)
btw: i read about several guys on PBB who, as soon as they either moved the tank or put it flush with the framerails, subsequently destroyed their rear driveshaft. something to keep in mind though: look how dented up your gas tank skid is and imagine if those were to happen to the thin wall tube of your d-shaft!! the best solution is have it retubed with 3/16" (.188") wall
__________________
-Peter
94 FZJ80 - DD
the dirt cheap SAS
Marko Customs
Old 02-16-2004, 07:59 PM   #7 (permalink)
Awesome information man! I really appreciate all that.
Chris
ravencr is offline
Tags
4runner, area, fuel, gas, ideas, mold, mustang, offroad, raising, road, round, spare, tank, tanks, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Air to spare with a Power Tank Robinhood150 Off Road Enhancements 0 01-07-2006 07:56 PM
Spare tire mounted gas can...? Compass Creek Offroad Tech 1 08-25-2005 07:02 PM
Fitting a 285 in the spare tire area on a 3rd gen? amorphous 95.5-2004 Tacomas & 96-2002 4Runners 8 04-22-2005 08:03 AM
Ideas for where to mount an air tank in a Taco?? pat317az 95.5-2004 Tacomas & 96-2002 4Runners 2 06-21-2004 08:16 AM
spare tire carier broke and someone took my spare!!!!!! Ilovemountains 95.5-2004 Tacomas & 96-2002 4Runners 3 06-17-2004 07:00 PM
2009 InternetBrands, Inc.
