| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#76 (permalink) | |||||
__________________
Ben Garland 90 4runner How can you possibly talk so much with your head so far up your ass? |
#77 (permalink) |
Yeah the tie rod is awful close, but doesn't touch even under full compression, so its going to work fine. We're probably going to add braces to the shock towers as some others have suggested. Thanks for the compliments! We're sort of looking at doing the rear either while I'm off for spring break, or next summer. That project could easily be done in a weekend, so we may do it earlier, but I don't know.
#78 (permalink) |
I would brace those shock hoops ASAP
Truck looks good! |
#79 (permalink) |
good looking rig. clean work....id ditch the shock boots, they will just collect junk in them...
__________________
'86 Toy Flatbed with a few modifications |
#80 (permalink) | |
Quote:
BTW please tell me youve got body lift on that thing, bc my goal is to stay as low as possible, and you are freaking tall.
__________________
poop 1988 stock 4runner, v6, 5spd, soft top. 1990 fj62 stock and mint! 1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system. The build up...http://www.yotatech.com/showthread.php?t=74915 |
#81 (permalink) |
Yea she has a three inch body lift. As for the driveshaft, we have it working fine now. Ours is the exact same setup as yours is: auto with one transfer and manual hubs. The driveshaft uses the stock CV up top, and a regular U-joint at the bottom. A CV off of an 84 or 85 has more clearance and will work better, but ours seems to be working. It may need some help from the dremel, but it's not going to bind up unless the front end is completely off the ground. It doesn't vibrate in 4WD on the road. Ohe thing that helped is that the axle is moved 1-1/2 inches forward from stock. You can mount the front hanger to run the axle in stock or forward location. Anyway, good luck with your build! The driveshaft is the hardest part...
#82 (permalink) |
BTW...at one point we had a U-joint at both ends and it provided less clearance than the CV up top. It wouldn't even angle enough for us to get it on! So we had to punt again and put the CV back on. Also, our front axle is shimmed about 1/4", so that helped tremendously without messing up the alignment.
#83 (permalink) |
HMM I guess ill just have to throw it togeather and see what happens. I have a noncv front shaft and a cv front shaft off a 97 runner. This is lame I just want a drive shaft to mainly be used for just offroad.
__________________
#84 (permalink) |
I know what you mean. Ours was a real headache. You never know exactly how it will work until you slap it on and then go twisting the front end around. When we had U-joints put on at both ends we were sure it was going to work fine and you couldn't even put it on. Good luck with it!
| Tags |
| 1991, 2000, 4x4, 89, axle, build, front, kits, pickup, school, solid, straight, swap, toyota, tundra, washington |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| what kind of axles for a solid axle swap? | KODE | Newbie Tech Section | 5 | 03-26-2006 11:18 PM |
| Solid Axle Swap | 4Runner92sr5 | The Fab Shop | 23 | 07-04-2005 06:48 PM |
| Tacoma Solid Axle Swap | WATRD | The Fab Shop | 459 | 12-24-2003 06:21 AM |
| Cheaper Solid Axle Swap? | jsrusse11 | The Fab Shop | 30 | 12-17-2003 08:29 PM |
| solid axle swap questions | SteveO | Offroad Tech | 56 | 09-29-2003 11:04 PM |
