| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Solid Axle Swap Has Begun!!!!!
#2 (permalink) |
What gears are you running in that diff?
Keep the pictures coming
__________________
Big Country Customs |
#3 (permalink) |
Nice. Are you gonna use your IFS driveshaft for now or going to a square tube one?
Here's how to modify a IFS front shaft to use on a SFA: http://www.4x4wire.com/toyota/tech/cvmod/
__________________
86 Toyota 4 runner Soild front axle, 35x12.5 BFG KM2's, winch, blah blah blah.... http://www.yotatech.com/f116/my-new-red-snappah-152938/ My cardomain page |
#4 (permalink) |
Looks like you have a nice project there. Keep the pics coming!
__________________
Will WabFab Off-Road, LLC Toyota 4x4 Parts and Custom Fabrication updated website with lots of new products 87 runner with every bolt on available |
#5 (permalink) |
Right now we have 4.88s in the diffs. Works perfect for 33s, but with the 37s we have on there now its pretty sluggish. We ordered some 5.29s to go in the axles. It has a Detroit Locker in the back, and the new axle gets a TruTrac in the front. We already have a guy who's going to be making us a driveshaft, but I'll have to check out that link for using the IFS one instead. Taking it to the shop as soon as I finish this to get it welded up (don't trust my welding on something that if it fails, you're in big trouble.) More pics tonight!
#6 (permalink) | |
keep the pics coming.
__________________
Eric 88 4runner Quote:
#7 (permalink) |
Man, that's nice. Did you rebuild the front axel before starting this swap? Wouldn't want something in there to fail after you have everything buttoned up. Keep up the pics.
__________________
Drew 99 4Runner SR5, auto, 3.4 V6, factory rear locker, 265/75 Yokohama Geolander AT+II Stock for now, but hopefully not for long. |
#8 (permalink) |
Front axle rebuild kit is sitting on the workbench
. It gets rebuilt tonight or tomorrow.
#9 (permalink) |
Very interested in where/how you move the tranny cooler, mine is just wired tied out of the way right now. Any details on hose/fittings would be greatly appreciated.
Just a note, the IFS driveshaft (with clearancing) may not work without a low lift and/or a high pinion front. That is a very nice looking truck before the swap, should look even better soon.
__________________
'93 4runner 4WD/V6/5spd Last edited by RobG; 12-08-2005 at 02:27 PM. |
#10 (permalink) |
nice build dude
__________________
'94 4runner : soon-ish to be V8'd, SAS'd, lock'd and bumper'd '04 Xcab Tacoma 4x4 TRD : Stock |
#11 (permalink) |
Just a heads up.
You may want to check the Fit of the High Steer Rod ends in the steering and pitman arm. The rod ends I got with my Marlin kit had the wrong taper and wouldn't go into the arms far enough to allow the cotter pins to engage. They had to send me new rod ends. The ones that didn't work had the zerk fittings like in your picture.
__________________
'93 4runner 4WD/V6/5spd |
#12 (permalink) |
I am going to second the interest in what you do with the tranny cooler.
__________________
94 4runner, v6, auto, 4WD, optima red top, headers and exaust,K&N fipk, 3 in downey lift, manual hubs, 33x12.50 bfg mud terrains, 10lb power tank |
#13 (permalink) |
looking good dude. what did you use to cut the holes for the shackle tubes? the cuts look super clean.
__________________
-Mikey- 1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club Poly Performance |
#14 (permalink) |
Thanks for the heads up RobG. I need to check that. Well...half the IFS is off. What a pain in the a$$. Now its back out to do the rest of it. Once we determine where the tranny cooler is going to go, I'll let you guys know. BTW...the holes in the frame for the shackle tubes were cut using a $10 hole saw that goes on the end of a drill. It did amazingly well. Drilled all the way through. Now...back to the shop to get the rest of this crap off....pics tonight!
#15 (permalink) |
Lock it up front now. You wont regret it.
__________________
-Geoff *1991 Toyota Pickup Ext. Cab SR5 4x4 V6 5 spd K&N intake, port & polished heads with OS valves, port & polished intake manifold and plenum, NWOR headers and crossover, NWOR catback, Denso Iridium plugs, Redline Fluids, 4.88s, Rear LockRight, Aisin hubs, Chevy springs, BJ spacers, 2" RB body lift, 34x10.5 Swamper LTBs, WolphisWorks Sliders and bumpers, 400,000 mi. |
#16 (permalink) | |
Quote:
__________________
#17 (permalink) |
The gusseting was a bit of a challenge. We cut it until the saw bottomed out, then took a pry bar and bent the gusset up out of the way and left it in the frame. Once it was bent up, the saw could make it the rest of the way through.
#18 (permalink) |
By the way, the only reason we didn't just come from the other side of the frame to finish the cut was due to clearance issues. Impossible to get a drill in there.
#19 (permalink) |
Time for an update. We got all the IFS crap (minus the bracketry) off. That was a pain.
The last of the IFS comes off... Ready for a straight axle!!! UPS man delivered some more parts today as well... Brand new third member. We got the spring hangers all welded up today. Tomorrow (depending on if its icy or not), we'll either rent a torch and finish up the IFS removal, or we'll be rebuilding that front axle. Should be rolling by Saturday or next week sometime. |
#20 (permalink) | |
Quote:
__________________
Rig Specs '94 4Runner 3.0L V6 4x4, 32" BFG Mud T/A KM, 4" SAS, All-Pro Bumpers and Sliders, Rear Cruiser Coils, Bilstien 5150's all around, Warn M8000, K&N Filtercharger, 300w Power Inverter, Optima Yellow Top, Viair 450C, Cobra 75WXST CB w/ Firestik II, Flowmaster 40 Series, Viper Keyless Entry, Rear-Detroit Soft Locker, Front-Detroit EZ Locker Trail Pics |
#21 (permalink) |
your makin fast work of this project, i like all the pics too, keep it up
#22 (permalink) |
AMAZING progress... keep up the good work, and the pics!
__________________
-Jake 1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-35" BFG M/T-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders-TG Front Bumper SAS Build-Up Old Rigs: '85 4Runner (RIP) '95 4Runner (sold) |
#23 (permalink) |
just curious what your gonna do with your ifs lift? If you want sell send me a pm.
__________________
89 SR5 p/u 3.0 5 speed, doa cams, downey headers, jacobs igniton, self made isr pipe, electric fan, 14"flowmaster, allpro rear spool, 63"chevys, 4crawler 2"bl, bj spacers, skymanufacturing u-bolt flip & shock tower, ranchos, 1 1/2 square tube bed, aisin hubs, 35x10.5x15 super swamper boggers.....For ever a work in progress 2000 Tundra SR5 V8 4x4 Bone stock DD/Tow Rig |
#24 (permalink) |
Was that a manual hub front end?
intrested in selling the entire front? cv shafts, hubs, tube the whole nine yards?
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#25 (permalink) |
We are selling that stuff, but some of it may be already spoken for. And yes, it was a manual hub. I'll let you know in about a week. The guy we got the axle from wants the IFS lift, and he may or may not take the whole front end. I'll keep everyone posted.
| Tags |
| 1991, 2000, 4x4, 89, axle, build, front, kits, pickup, school, solid, straight, swap, toyota, tundra, washington |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| what kind of axles for a solid axle swap? | KODE | Newbie Tech Section | 5 | 03-26-2006 11:18 PM |
| Solid Axle Swap | 4Runner92sr5 | The Fab Shop | 23 | 07-04-2005 06:48 PM |
| Tacoma Solid Axle Swap | WATRD | The Fab Shop | 459 | 12-24-2003 06:21 AM |
| Cheaper Solid Axle Swap? | jsrusse11 | The Fab Shop | 30 | 12-17-2003 08:29 PM |
| solid axle swap questions | SteveO | Offroad Tech | 56 | 09-29-2003 11:04 PM |
