YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-09-2008, 09:55 AM   #1 (permalink)
Skid Plates??
Hey everyone, this is my first post and i'd just like to say that this is a great site with a lot of knowledgeable people (or at least it seems that way). But, my question is what thickness of metal do you all think would be appropriate for some skid plates? I ripped one off today and figured that i would just make some new ones. I have a '00 Taco, so if anyone has any advice or words of wisdom, i'd appreciate them. Thanks.
Mikeyb is offline
Sponsored Links
To remove this ad, register today!
Old 05-09-2008, 09:58 AM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
Welcome
Ide say dont go less than 1/8". Its plenty strong for some mild abuse and if you want over kill go with 3/16" I use both on my rock crawler
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 05-09-2008, 10:05 AM   #3 (permalink)
wow, that actually seems awful thin, i was thinking around 3/16" with some banding for support running laterally across it. do you think that'd be overkill? and also, would it be extremely hard to bend, or would i just add a little heat and i'd be on my merry way?
Mikeyb is offline
Old 05-09-2008, 10:11 AM   #4 (permalink)
What skid plate are you building? 1/8" is pretty strong. With some cross banding your talking about the 1/8" should be fine enough but it would never hurt to add a thiker piece in if your really worried or plan on having really hard impacts. My tranny skid I built uses 3/16" and my gas tank skid is 1/8".
__________________
Old 05-09-2008, 10:11 AM   #5 (permalink)
hurley842002's Avatar
Honestly I don't think there is such thing as overkill when your talking skids, now of course weight becomes a factor, and since yotas aren't known for frame twisting horse power you would have to take that into consideration. 3/16" should be adequate.
__________________
1986 4runner
31" mt's
aftermarket shackles
Custom front bumper/winch
Light bar/auxilary lighting
Rear Detroit
future mods:
33's maybe 35's, 5.29's, Rear bumper with tire/jerry can,highlift mounts, sliders. Conquer with the IFS until I can't conquer anymore and then do an SAS.
hurley842002 is offline
Old 05-09-2008, 10:17 AM   #6 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
remember that 1/4 inch thick plate steel will weigh about 11-12 pounds/square foot. 1/8th inch thick plate steel weighs about 5.5 pounds/square foot. 3/16 will be just under 8.
i would go with engineering over more material, and strategically brace the plate, build in fail points, etc.
the idea of a skid is to protect vital components and to reduce the likelihood of being hung up on something. mine stockers are toast, and this summer will see some carefully designed 1/8 inch thick plates underneath.
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, 1" 4crawler body lift, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Old 05-09-2008, 10:43 AM   #7 (permalink)
tc
tc's Avatar
Mine are 3/16" and they're bent pretty good in places.
With steel prices and availability today, unless you are buying big quantities and have the equipment, I would highly recommend just buying some from an experienced vendor like www.budbuilt.com
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 05-09-2008, 08:28 PM   #8 (permalink)
thanks for the advice guys
Mikeyb is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
skid plates Mikestang Offroad Tech 1 07-05-2006 07:32 PM
Skid Plates crisis 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 10 06-09-2005 01:28 PM
Skid Plates Outback 95.5-2004 Tacomas & 96-2002 4Runners 4 09-19-2004 07:35 PM
Skid plates fooddude 95.5-2004 Tacomas & 96-2002 4Runners 5 07-04-2003 08:57 PM
How much are Skid plates going for? dre 95.5-2004 Tacomas & 96-2002 4Runners 4 09-19-2002 12:52 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
