YotaTech Forums
Go Back   YotaTech Forums > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 09-04-2006, 03:07 PM   #1 (permalink)
Personal Sales Rating: (0)
86toyotakid's Avatar
sas options
ok i just broke some parts on my 86 and it was the last straw iv have had it its time to build a nice rig. so for my dd i have a 98 4runner 4cyl 5spd, perfect.
whats the best way to do a sas i want leafs so its cheeper and i was looking at the trail gear kit but idk if it will work. r there any kits designed for the 4runner?? and im planing on running a yota axel weather the 79-85 axel or the early 90s land cruse axel if i can do that.
for the rear should i keep the coils or do a 63" chevy swap??
i searched and found some info but am still curieous. thanks, josh
86toyotakid is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 09-04-2006, 04:12 PM   #2 (permalink)
Threadstarter [OP]
so what axel should i run help please
Old 09-04-2006, 04:38 PM   #3 (permalink)
Vendor Sales Rating: (10)
EDIT: I just read your other thread...which truck are you going to SAS. You are parting the 86 out right?
waskillywabbit is offline
Old 09-04-2006, 05:07 PM   #4 (permalink)
Threadstarter [OP]
yea i dont want to deal with it anymore but theres tons of good parts and most of my buddies want them the others ill prob keep. i going to sas my 98 4runner hopefuly if i get all of my funds together and sell some toys.
Old 09-05-2006, 01:00 AM   #5 (permalink)
AxleIke's Avatar
Okay. No, the trail gear kit will not work for the 98. It will need to be a custom job, and you really should do a ton of bracing and plating on the frame to make it strong enough. If you are a good welder fabricator, it would be doable, do some research, and figure out everything you need to do. I don't think its going to be all that cheap, if you do it right, and build a good truck.
Leafs are cheap on the early trucks, cuz they are easy and quick. Not so much on the later trucks. I would swap the 86 long before i tried to swap the 98.
__________________
Supercharged 1999 4Runner- Baby Beast 2, the mild mannered build-Link
1987 Mutant 4runner|Slightly Modified|Lacking general build direction|Now on 35's-Parts truck-SOLD
1989 Project 4runner-The Redo-SOLD
-Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail.
-Internet Nice Guy
AxleIke is offline
Old 09-05-2006, 06:21 AM   #6 (permalink)
ORS
ORS's Avatar
We will be selling a system in Oct. for the front of your 98 that would help you out immensely. It's a coilover system that is designed to take the guess-work and headache out of a multi-link setup. Check out this link for more info: http://www.offroadsolutions.com/tech...ion_system.htm
You are welcome to call or email with any ?'s... Good luck!
PS You will need to run an axle with a driver side differential to match your transfer case configuration. If you change the transfer case to an older style (there are adapters), you can run a passenger side diff.
__________________
Off Road Solutions
Offering offroad products, engine conversions & custom fab work for your Toyota (& much more...)
ORS is offline
Old 09-05-2006, 11:53 AM   #7 (permalink)
JGM
JGM's Avatar
Doing a swap on a 3rd gen is very complicated and expensive. The ORS kit sounds pretty cool, but you need to know that in addition to the driver side drop, you need to think through the steering (literally from the steering wheel down), crossmember, brakes, and how to match it with the rear suspension - not to mention the "basics" like Lockers? wheels? Tires? Regearing? Then there are the electronics to deal with like ABS, speed senders, etc. Certainly not to be taken lightly.
If I had a mini-truck, I would have swapped that instead of my 96, even though my 96 is a super cool truck. Good luck.
__________________
1996 4Runner & 1971 FJ40
JGM is offline
Old 09-05-2006, 02:24 PM   #8 (permalink)
Threadstarter [OP]
ill probably have to custom make it because i want leafs and i can run a axel out of a land cruser. no abs, only have to regear the front, and eather keep the rear how it is and just lift it or do a 63" chevy spring convershion.
Old 09-05-2006, 02:35 PM   #9 (permalink)
AxleIke's Avatar
Which land cruiser would that be?
__________________
-Internet Nice Guy
AxleIke is offline
Old 09-05-2006, 03:11 PM   #10 (permalink)
JGM
JGM's Avatar
I don't know of any landcruiser with a driver diff. Check out SonoranSteel for good axle information.
Keep talking about your ideas, though. I like seeing more and more 3rd gen SAS projects.
__________________
JGM is offline
Old 09-05-2006, 03:19 PM   #11 (permalink)
881stGenRunner's Avatar
Brandon Rutledge getbent2nite
Send a message via Skype™ to 881stGenRunner
Sounds like a sweet build. You should really talk to SteveO about his. He kept coilovers in the front and did the all-pro 5.5 leaves in the rear. I think SteveO will be your best source of info as far as this is concerned
__________________
-Brandon
1988 4Runner SR5 4x4 V6 5 Speed Swap (R150F) 242k mi (blown)~SDORI 1.5" BJ Spacers~Downey 26MM TBs~63" Chevy Springs~Downey Shackles~ES3000s~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~35x12.5 BFG A/T KOs~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~Marlin Crawler Rear~Addicted Offroad Front Bumper~4X Innovations Sliders~Smittybilt XRC8~Optima Yellow Top~SS IFS Truss.
My 4Runner and Other Stuff
881stGenRunner is offline
Old 09-05-2006, 04:36 PM   #12 (permalink)
Threadstarter [OP]
sry i was thinking the early 90s crusers did but im wrong. the swap wont be for a whyle though im kind of haveing trouble saveing money and im going off to school next fall so if it happens it will be next summer or the next im mainly just seing how much i need to save and what are the best options.
Old 09-05-2006, 04:52 PM   #13 (permalink)
Threadstarter [OP]
heres a q
what have people been doing with there gas tanks cause u cant put a fuel cell in the bed sooooooo..... i the trunk???
Old 09-05-2006, 06:22 PM   #14 (permalink)
AxleIke's Avatar
They have been leaving them where they were for the most part, a few have moved them to the spare location.
__________________
-Internet Nice Guy
AxleIke is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
4runner, sas
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What are my options? offroad4x4yota 86-95 Trucks & 4Runners 6 05-21-2007 09:46 AM
What Options would you go for? Chainlink FJ Cruiser 2 09-05-2006 06:04 AM
SAS and Front bumper options AH64ID The Fab Shop 25 08-29-2006 07:35 AM
need help w/options FJ40 FJ Cruiser 6 04-04-2006 12:27 PM
Need help on some Limited options williemon 95.5-2004 Tacomas & 96-2002 4Runners 2 08-27-2003 07:16 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
