Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
vehicle: 1995 ext. cab pickup 3.0L 5-speed 4X4
I'm in the planing stages of installing Marlin's 5" SAS and 5" rear lift. I won't be putting a spare under the truck. Would it be a wise idea to remove the crossmember that the spare hangs from and replacing it with a "C" shaped peice of steel? This will be welded at the very back of the frame. I'll have to relocate the rear shacle hangers, so this should add some strenght back there. Where can I get a crossmember to mount the tops of the rear shocks to? I saw this one: http://www.offroadsolutions.com/imag...s/DCP_1138.jpg any other sources? |
| Sponsored Links |
#2 (permalink) |
Do you have a bender? Make your own shock hoop. Heres how I made mine...
![]() ![]() The crossmember in the back you can replace with a piece of 2x3" (?) rectangle steel.....
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#3 (permalink) |
Thanks for the pics. I like how you tied it in to the factory fuel tank crossmember.
No, I don't have a bender or know how to weld. I'm going to find a pic of the 2X3" rear crossmember and have the person that is doing the welding copy it. (A picture is worth a thousand words, right?). |
#4 (permalink) |
It should fit right inside the frame rails. I cut mine out for a reciever hitch in the middle
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| removing bed from frame | PCE91V64x4 | 86-95 Trucks & 4Runners | 12 | 07-02-2008 06:47 PM |
| Options on Transfercase Crossmembers | AxleIke | Offroad Tech | 21 | 11-30-2007 01:50 PM |
| 87 2wd Frame and 86 4wd Frame (rear only) | ndg | 86-95 Trucks & 4Runners | 3 | 10-29-2007 06:05 AM |
| Crossmembers for 95 runner roof racks | keithguts | Items Wanted | 0 | 09-10-2006 06:13 PM |
| 3" Drivetrain/Body Lift + New Crossmembers = ... | ravencr | Offroad Tech | 59 | 03-21-2006 04:01 PM |
