Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Rear Bumper Fab Underway
After designing this thing months ago, Im finally starting to build it. I used SolidWorks to make a rough 3D model of the rear of my runner, and then I modeled a bumper to fit. Then I spent some quality time at work to make the 2D AutoCAD drawings. So, as long as my 4Runner model is perfect, everything will go together perfectly. Yea right.
Anyways, so as of now I got the 1/4" connection plates tacked onto the main tube (3"x4"x1/8" sqr tubing) and got the holes drilled. I am using the 1/2" stock towing hitch mounting plates to attach my bumper to. I used a friends shop to cut the bottom of the towing hitch plates off and got some holes punched in them. So now the next step is to get the 1/8" side plates welded on. You'll see in the close up pic that I had to redrill my mounting holes. I realized after I punched the original holes that I wouldn't be able to bolt in that location because the 1/2" plate I was mounting to had some steel welded to the back of it there. So, I had to redrill back a couple inches. The bolts are a little cramped and one is too close to the existing hole, but it will get the job done. I'll update with more pics as the works progresses. ![]() ![]() ![]() ![]() ![]() ![]()
__________________
'91 4Runner 3.0 5sp 169k miles. |
| Sponsored Links |
#2 (permalink) | |
interesting idea. how are you planning on bracing the sides by the wheel wheel? triangulate back to the mounts?
__________________
Quote:
#3 (permalink) |
I'll support the sides off the main vehicle frame. Come off perpendicular and angling up to the frame. I didn't inculde the frame in my 3D model so I haven't designed that part yet, but I'll just field measure something in after the bumper is basically done.
__________________
#4 (permalink) | |
Nice, can you please take lots of pictures. I don't really want a tube bumper, but that seems to be all that is offered.
__________________
1990 Toyota 4Runner 22RE 5spd Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* York OBA* pretty much stock. Quote:
Toyota FAQ link More info on 4Runners - awesome resources |
#5 (permalink) | ||
Quote:
I'm asking cause it looks like a good stout design you might be able to market since it looks similar to some of the winch mount fronts I've seen.
__________________
Quote:
#6 (permalink) | |
Quote:
More than anything this is kind of a learning project for me. I've only been welding for a couple months now. This is about my third project, and definately the biggest. It should be fun and hopefully it looks good in the end.
__________________
#7 (permalink) |
I thought you were going to sell your 4runner last year? At least that's what I remember hearing on the one run to 5-Mile pass?
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S Just call me "T" Sold: 1996 Toyota 4runner, auto, 4x4, Bud Built front skid, Stubb Welding Sliders, SS #3, hella 500's and elocked rear axle |
#8 (permalink) |
Well, the plan was only to buy it, do the valve job and sell it, but then I crashed my gold 4runner and never got any money out of the lady that hit me. I hate people from Evanston WY that drive in Utah without car insurance and then get thrown in jail so you can't garnish their wages in order to collect on the judgement you were awarded in small claims court. I'll probably never get my $4000 out of her. So, the blue runner has been good to me and we'll keep her until I decide I can afford something else.
__________________
#9 (permalink) | ||
Quote:
__________________
Quote:
#10 (permalink) |
OK, I've finally got all the main pieces tacked together. I still need to tack on a few final pieces, but you wouldn't even be able to see those from the pics I took, well, except for the trailer hitch and the tow lugs. I had to do a little grinding and have a quarter inch sheared off a few pieces, but overall Im very pleased with how its turning out. I do want to cut out a piece that will fill the gap that you can see in the upper corner of the bumper. Also, the very front upper edge of the sides are rubbing on a tiny spot of the body, so I need to figure out the best way to deal with that. Im thinking maybe epoxy on a piece of plastic or something so that it won't rust right there. I'll get quite a bit better departure angle with this new bumper. The bottom of this bumper sits about 3" higher than the stock bumper. Check out the new gap I have between the exhaust pipe and the bottom of the bumper. I'll have to think about relocating that later. Anyways, here are some pics:
__________________
'91 4Runner 3.0 5sp 169k miles. Last edited by WillRadford : 06-26-2008 at 11:12 PM. |
#11 (permalink) |
Very nice, came out great. I'll be watching out for the finished product.
__________________
1986 4runner 31" mt's aftermarket shackles Custom front bumper/winch Light bar/auxilary lighting Rear Detroit future mods: 33's maybe 35's, 5.29's, Rear bumper with tire/jerry can,highlift mounts, sliders. Conquer with the IFS until I can't conquer anymore and then do an SAS. |
#12 (permalink) |
Very nice Radford! The boxed look is working well.
__________________
'87 4runner: fresh 22RE .020, 261c, OME springs/shocks, SDORI, relaxed Ts, 4.88s, front Lockright, marlin 1200 clutch, 16" Tacos, 255/85 bighorns, LCE header, magnafloW --------------------------------------------------------- "The Federal Reserve pretends to fight inflation but actually creates it. Inflation is the most insidious tax of all." --- ABOLISH THE FED |
#13 (permalink) | ||
Location: Selling turnips on a flatbed truck, I 15N @ 79S
I love it
__________________
^Say GO DJ..Uh thats my DJ The Blue Biche 91 4x4 p/u 22re--elbow mod, 500ff's. BFG A/T ta KO's. Smokey the Bear I Work on my gas tank while smoking a cig...Sue me Dad- 1999 4runner base 2x4, 2.7, 5speed, 52k, cherry. Chat with meeee Quote:
Quote:
UltimateYota |
#14 (permalink) |
That thing looks great. Very clean fabrication. I can't wait to see the finished product.
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks? Idiocracy (edited for family friendly viewing) |
#15 (permalink) |
Not sure if the body and frame flex on a second gen like they do on a third, but if you have any part of the bumper rubbing or quite close to the body now, you may want to re-think that clearance. I would want, at a minimum, an inch clearance away from the bumper and any body part. Otherwise, if you hit the bumper hard, you stand a good chance of getting some body damage. Just a thought.
__________________
-Brian '88 4Runner '00 4Runner |
#16 (permalink) |
looks good! came together great!
__________________
95 4Runner 4x4 - Drilled Air Box, 33x12.50 BFG's, Midland CB/PA, Polk Audio Mid Range Speakers, Stock CD/Tape Deck, Marlin Crawler Rear Bumper, Herculined Tailgate/Rocker Panels, Coleman Safari Roof Rack, All Chrome (Mirrors, Windshield Trim, Door Handles, License Plate Frame, and Grill) painted black, 1" 4Crawler Body Lift, 15x8 Cragar Wheels, 1 Regular Transmission Cooler (in-series with stock AT Cooler), Old Man Emu Rear Lift Coils, Rear Pro Comp Shocks, BJ Spacers, Front SkyJacker Shocks |
#17 (permalink) |
Looks great so far, no plans for a spare tire carrier?
__________________
1988 4runner w/ 5'' SAS Trail Gear Kit, 3'' body lift 5.29 with Detroit Lockers, and 35'' Iroks 2002 Chevy Z71 w/ 6'' ProComp stage two suspension, 3''body lift and 37'' SSR http://bslca.com/ |
#18 (permalink) |
lookin good kinda makes me wanna get rid of the tube bumper and go for the boxed style
__________________
95 4runner, 5 in tg sas and rear leaf swap, chopped, mx6 reservoir shocks, 35x13.50x15 toyo mt's, all pro front bumper, mile marker se9500c, rear tube bumper, hella 500's, rock lights, optima red top, glass fenders, tg 5.29's, lockright rear, detroit hp front |
#19 (permalink) |
That looks great! It looks almost exactly like the one I was planning on building, someday... Very clean, I want one...
#20 ( |
