Pic Request Winch Mounting Plate
Old 04-13-2007, 01:38 PM
4Hummer's Avatar
Requesting Pics from anyone who has built a custom bumper.
How did you attach the winch mounting plate? Tips? Tricks? Suggestions?
Just bought a MileMarker 9000Lbs Winch with Winch Plate. Looking for ideas on how to mount the winch so I can build the bumper around that.
Also Keep in Mind I have a 3" body lift so I'd like the winch plate up a little higher than the stock cross memeber.
Post up your pics
Old 04-13-2007, 04:19 PM
waskillywabbit's Avatar
Look at the winch mount plate on my website under bumper...79-95 4Runners...that should give you a few.
Old 04-14-2007, 11:29 AM
Napoleon047's Avatar
dont try to mount the winch that high, you will have a lot of leverage on the mount and the front of the frame. instead, since you have enough body lift, tuck it under the grill as close to the radiator as you can.
Old 04-14-2007, 11:42 AM
Flygtenstein's Avatar
I would weld it.
Old 04-16-2007, 07:33 AM
4Hummer's Avatar
Originally Posted by Flygtenstein
I would weld it.
Thats funny..... Geez and I was thinking of using glue.
Wabbit Thanks for the direction to your site. Im going to build a plate to enclose the factory cross member and beef that area up. I will than build the bracket to support the winch plate off that.
I only need to raise the winch plate 1.5" Up from the stock cross member in order to tuck it perfectly under the Grill
Old 04-16-2007, 08:38 AM
this is what i was talking about, tucked as far back as possible.
Old 04-16-2007, 08:40 AM
SteveO's Avatar
Here ya go:
http://www.hunt4steve.com/99RunExt_frtbump.html
Old 04-16-2007, 09:41 AM
4Hummer's Avatar
Originally Posted by SteveO
See now thats what I'm talking about. THANKS MAN. thats perfect.
Nice Bumper BTW I may have to "borrow" a few ideas from that.
Old 04-16-2007, 09:46 AM
SteveO's Avatar
I have quite a few more detailed pictures, if you would like to follow this design.
Old 04-16-2007, 11:13 AM
4Hummer's Avatar
My Bumper will be including a stinger. So the design will be a bit differant,
Any close ups up the side supports, (Bolted to the body mount section)
Also any better pics of the Bottom hoop to protect the Rad ?
Old 04-16-2007, 11:21 AM
SteveO's Avatar
Yeah, I have some, but they are at home on my other computer.
Old 04-23-2007, 07:23 PM
Vermejo's Avatar
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
Scotto6591
09-01-2015 03:24 PM
MTLroadierunner
07-20-2015 03:07 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: Pic Request Winch Mounting Plate
