| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
New panhard bar
__________________
--Brian '94 4Runner SR5 4WD 285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line Stereo CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q |
#2 (permalink) |
The S has no functionality for a panhard. The only reasons a panhard would absolutely need an S are for clearance or so that the rod ends are angled correctly and are free to rotate within the range of motion of the suspension.
The effective length of a S panhard is the straight line distance from eye to eye. If you make a straight panhard bar the same length, eye to eye, there will be no difference in the two. Since a panhard bar is designed to be in pure compression or tension, putting a bend in it makes it weaker than a straight bar of same diameter and wall thickness. What was once in tension or compression is now stressed in bending also. For example, try to compress or pull apart a toothpick. Now try to bend it in half. Which is easier to break? So, you will want to lengthen your panhard enough so that the drive shaft clears the gas tank, but also centers your axle. Remember high school geometry? Well that's going to come in handy now.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#3 (permalink) |
Lucky for me being young! HS was only a few years ago
I'll keep everyone updated. Anyone know if heims or jjs would be better?
__________________
#4 (permalink) |
If you go Heims, don't buy the cheap ones, get them with the teflon lining.
For a panhard bar, the heims will work just fine and should last a long time. |
#5 (permalink) |
Any recommendations on places to buy them from?
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| panhard bar? | roadking8633 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 06-09-2007 09:11 AM |
| Panhard Bar | Thrillbilly | Offroad Tech | 4 | 10-02-2005 02:57 PM |
| panhard bar HELP! | Y2Krunner | Offroad Tech | 14 | 08-11-2005 09:47 PM |
| 2nd gen trac bar/ panhard bar removal | Y2Krunner | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 08-04-2005 02:05 PM |
