Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Need more lift in fron 4x4 04 tacoma spacers?
Hi i have a *4X4" 04 tacoma and have a 1.5" spacer above the coilover. How much actual lift would this give to the truck?
When i see people saying 2.5" spacer or 3" spacer is that the actual size" of the spacer or is that the over all lift it will give the truck? I want to lift the front of my truck higher because i have 33.2"bfg a/t tires and it rubbs when I turn.(also have a 3"wheel spacer installed) How can i go higher? I also have a 1" diff drop instaled. remember its 4x4 so im limited with the axel angles... All your help will be appreciated! Thanks!!! |
| Sponsored Links |
#2 (permalink) |
coil spacers are bad, get some new springs and struts or some adjustable coilovers to lift you up. Usually the recommended max lift is 2.5" for cv angles.
__________________
97 4runner, 2.7 5speed 4wd, 4.556, 255/85/16 Maxxis Bighorns rear diff breather, 4 hella 500's driving, sliders, wilderness rack custom bumper arb locked rear toytec adjustables, ome 891's, bilstein 5125 manual hubs broken front and rear swaybars My Profile |
#3 (permalink) |
max lift is 2.5 inches but i do have a 1 inch diff drop so would that maby let me go to 3"?
#4 (permalink) |
Most suggest 2-2.5" but many have gone above that and have had no problems, and some have. I am currently running a tad over 2" and originally i had around 2.75" and my cv angle wasnt the best, but wasnt too bad. I have manual hubs sitting in my room and when those go on I am gonna crank the front up a little more.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Questions re 3" lift on '04 tacoma 4x4 access cab v6 | D Barrette | Newbie Tech Section | 13 | 05-22-2006 09:53 AM |
| Just finished my suspension lift!! 2002 Tacoma 4x4 | P. Bauer | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 12-02-2004 02:31 PM |
| 98 Tacoma 4x4 Lift ?'s | Turtle_Toy98 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 09-24-2004 09:33 PM |
