Sign in using an external account
| The Fab Shop Tube buggies, armor protection and anything else that requires cutting, welding, or custom fab work |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (1)
My 7M-GTE build
__________________
http://www.toyotafiberglass.com check out all of our builds in the VENDOR section 86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE CURRENT PROJECT 83 Trekker SR5 DONE June 2011 2WD fourm I frequent NEW Trekker forum |
#2 (permalink) |
Personal
Sales Rating: (1)
[OP]
__________________
#3 (permalink) |
Personal
Sales Rating: (1)
[OP]
so.. got the short block assembled ;D ..
Crank in installing ARP bolts , rings , and rod bearings I have a short block ;D and front cover more tomorrow .
__________________
#4 (permalink) |
Personal
Sales Rating: (0)
Nice progress! Looking good!
How you going to handle the cooling/radiator? I know that is one LONG motor... |
#5 (permalink) |
Personal
Sales Rating: (1)
[OP]
well so far a supra rad for cooling ...
__________________
#6 (permalink) |
Personal
Sales Rating: (0)
you going to cut out the core support for clearance or move the motor back a little? looking great so far. keep up the good work.
__________________
-Mikey- 1993 4Runner ~ 37" Kevlars | TG Rock Assault front housing | 5.29s | Marlin UM07s | Spartan front | Tacoma E-locker rear | TG HD/RUF front | All Pro rear | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | 5-speed swap | TG duals with 4.7s | Budbuilt | 4xInnovations cage | bumpers | sliders | K&N intake | Flowmaster 40 | Optima yellow top | clear lenses | Hella 4000s | PIAA 1400s | LED rock/party lights Polygoats 4-Wheel Drive Club Poly Performance |
#7 (permalink) |
Personal
Sales Rating: (1)
[OP]
actually its going into a 2wd .. with a full custom frame .
I'm going to move the engine back 2" and cut the fire wall , and tunnel .
__________________
http://www.toyotafiberglass.com check out all of our builds in the VENDOR section 86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE CURRENT PROJECT 83 Trekker SR5 DONE June 2011 2WD fourm I frequent NEW Trekker forum Last edited by slacker; 08-08-2006 at 04:48 PM. |
#8 (permalink) |
Personal
Sales Rating: (1)
[OP]
so a little bit more today ..
got the pan on ... of course it came with a cork gasket that i'll never use . and some of the accessories .. MLS head gasket in place , and new ARP head studs . and the head goes on , and torqued to 80FT lbs back cover and set the valve covers on for effect . and almost done ... so thats it for now ... I had to order the turbo oil pipe gaskets .
__________________
#9 (permalink) |
Personal
Sales Rating: (1)
[OP]
did a little more today ...
got the valves adjusted , and cams in and bolted on the covers , new thermo , cam seals ...... also started on the RC - 550's 400 Horses , here I come
__________________
#10 (permalink) |
Personal
Sales Rating: (1)
[OP]
so .. more .. ;D
fuel rail is buttoned up , and also center gasket timing gears are installed "correctly" and belt installed . also thermo housing . exhaust manifold , and shields . front cover and the upper intake .. just about done .
__________________
#11 (permalink) |
Personal
Sales Rating: (0)
Looking good man!!! Keep up the good pics.
__________________
89 SR5 p/u 3.0 5 speed, doa cams, downey headers, jacobs igniton, self made isr pipe, electric fan, 14"flowmaster, allpro rear spool, 63"chevys, 4crawler 2"bl, bj spacers, skymanufacturing u-bolt flip & shock tower, ranchos, 1 1/2 square tube bed, aisin hubs, 35x10.5x15 super swamper boggers.....For ever a work in progress 2000 Tundra SR5 V8 4x4 Bone stock DD/Tow Rig |
#12 (permalink) |
Personal
Sales Rating: (1)
[OP]
thanks ...
Mostly done .. I just have to add a few of the accessories ..
__________________
#13 (permalink) |
Personal
Sales Rating: (0)
sweet biult....on my dream list is to learn about tearing engines down and biulding them back up so i can get a 7M-GTE and toss it in my lil yota....ahh the look on ppl's faces when i drive by them and they hear a nice "psss"
__________________
2003 Buell Firebolt Trek STP400 Sneakers |
| Tags |
| 7mgte, belt, block, build, built, center, cover, engine, gasket, head, mls, red, sale, short, timing |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 24R-GTE Tech | Bunta Fujiwara | General Vehicle Related Topics (Non Year Related) | 4 | 05-03-2007 10:41 PM |
| Any one ever get a 7m AFM to work on a 3.0 | Ganoid | 86-95 Trucks & 4Runners | 12 | 01-16-2006 10:56 AM |
| 2JZ-GTE in the Tundra | DavidA | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 08-09-2004 04:53 PM |
| fuel economy 7M-GE/3VZE | 4runner4ever | 95.5-2004 Tacomas & 96-2002 4Runners | 26 | 09-21-2003 10:54 AM |
