Mig welder regulator question
I am kind of a newb to MIG welding with gas and finally got my hobart 140 today. I got a 5lb bottle of co2 and a small bottle of argon. Question is, what kind of regulator or splitter or ?? should I use to do a 25/75 mix going into the welder?
I would of gotten the a tank of mixed but I am planning on doing some 100% co2 welding at times. Would the output of a regulator on each bottle going to some form of Y coupler to the welder work?
I'd rather not ghetto rig this.
Just curious what are you gonna weld with pure Co2?
They do make electronic mixers to combine gases but I think it might be cheaper to get two seperate bottles. I doubt combining bottles like you state with a "Y" adapter will get you the right mixture.
Take those bottles back to the retard that sold them to you and get your money back. Then go to another welding supply store where they have competent employees and get a 25/75 to 10/90 mix bottle and a normal MIG regulator. I have an 84 cubic bottle on my Lincoln Pro 135 and it gives me about 4 hours of weld time...give or take. I have less than $500 in my whole setup brand new, accessories and all and I own the bottle.
I'm sure you can split them like you've done and for some reason, but I don't know why you'd want to...more trouble than it needs to be.
Keep us posted.
Keep us posted.
I'm going off what I have read cause I have not tried it yet. But supposedly you can get more penetration using 100% co2. At least thats what miller says. I figure when I go to weld my receiver stock it would be helpfull.
http://www.millerwelds.com/education...tips/MIG_tips/
Guess I will see if I can swap out my small argon bottle for a larger bottle of mix. Unless anyone else has an idea.
Thanks for the advice wabbit, they only sold me the argon bottle today. I already had the co2 bottle. I carry it in the truck for air tools and such. I'll head back there in the morning.
Welding gas goes in a hurry...like I said, I have a 84 cubic mix bottle and it lasts about 4 hours, but it fits on my little cart nicely. When I get a bigger welder, I'll get a bigger bottle.
From the link you posted:
4. Use the proper shielding gas. CO2 is good for penetrating welds on steel, but may be too hot for thin metal. Use 75% Argon/25% CO2 for thinner steels. Use only Argon for aluminum. You can use a triple-mix for stainless steels (Helium + Argon + CO2). (Refer to Diagram 2. Penetration Patterns for Steel)
Generally, you'll be welding 1/4" plate and under (thin metal) if you are welding on a rig, so the mix would be your best "general" purpose gas IMO.
Good luck.
Jcrawl94
10
10-24-2015 04:34 PM
