Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
metal care
So I just bought all this yesterday for $30
that's 10 - 2"x4"x39" .120 2 - 2.5" angle iron 3/8 thickness 1 - 4"x4"x45" Anyway, some of it will hopefully be my new bumper by the end of the summer. As you can see though, there is some surface rust. The picture makes it look worse than it is. What is the best way to take care of this? Will a grinder with flap wheel take care of it? Should this be done before or after welding is complete? Any help would be appreciated, thanks.
__________________
'92 pickup, xtra cab, manual 3.0, 4x4, 31x10.5 |
| Sponsored Links |
#2 (permalink) |
Usually just grind down the area to be welded just before welding. A little surface rust makes for easier painting as it'll pit the surface and make it accept paint better. just clean it with something like CLR or other phosphoric acid based rust cleaner before painting. You could always wipe down the steel w/ some old motor oil or something if the rust bothers you.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
Dont worry about it...just keep it indoors and dry
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. I'm the yota junk man......PM me for ALL your parts needs NEW or USED Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#4 (permalink) | |
Quote:
__________________
#5 (permalink) | |
Quote:
I usually dont worry about it...its just surface rust.....you need to prep the metal anyways before fabbing or painting.
__________________
#6 (permalink) |
Sponsoring Member
Just leave it alone until you start then prep the area for welding and then clean up the rest if you want to paint.
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab FOR SALE: 1987 4Runner GRAY FOR SALE: 1987 4Runner RED 6th Annual South East 4Runner Jamboree, May 22-25, 2009 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to take care of a baby... | Mason Dixon | Off Topic Talk | 8 | 01-28-2008 08:00 PM |
| I don't care who gets elected | dlbrunner | Off Topic Talk | 20 | 12-18-2007 09:42 AM |
| High pitch 'metal on metal' squeel | Tun2k | Newbie Tech Section | 4 | 10-24-2006 08:24 AM |
| I don't care what they say | calrockx | Off Topic Talk | 27 | 08-26-2006 09:42 PM |
| Did you know....Do you care.... | CanDo | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 02-07-2005 05:20 PM |
