Lower Control Arm is Bent!! - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 12-29-2003, 06:19 PM   #1
I noticed after my trip this weekend, I bent my lower control arm on the driver's side in addition to breaking the top urethane bushing on my OMEN86 firm shock, so now it makes all kinds of racket back there.
I've heard about the spidertrax arms, but I don't know where to get them, what the benefits are, what length, etc. Can someone help me out?
Chris
ravencr is offline   Reply With Quote
Old 12-29-2003, 06:42 PM   #2
Bighead's Avatar
Jeff the Marmot runs the rear lower control arms from Spidertrax. His post on this ODW thread talks about them a little bit. I seem to remember a lot of discussion about them at ODW late last year, early this year. Hope this helps.
Bighead is offline   Reply With Quote
Old 12-29-2003, 06:50 PM   #3
Awesome man! I'll read them tomorrow when I get some more time. I'm wondering about when I relocate my tank if I could cut off the locations on the frame to provide more clearance, make the control arms longer, and mount them to the frame either on the outside or inside of the frame rail??
Chris
Old 01-02-2004, 02:53 AM   #4
I've decided that temporarily I'm going to bend it back to normal, so hopefully this will buy me enough time to design my rear 4-link.
Chris
Old 01-02-2004, 09:05 AM   #5
RTdawgs's Avatar
my control arm mount is bent, slammed it pretty hard, it squeaks when i flex that side, but nothing major.
if youre gonna change your setup (ie 4-link) dont put the money into the spidertrax arms.
RTdawgs is offline   Reply With Quote
Old 01-02-2004, 03:16 PM   #6
Yeah, that's what I was thinking too. I've going to bend it back to as close to stock as possible, and then save money for a 4-link rear setup in future. The next big mod, though, is probably going to the ARB RD90.
Chris
Old 01-09-2004, 08:44 PM   #7
dragr1's Avatar
Quote:
Chris
And a $500 Honda to get you to work when you break!
dragr1 is offline   Reply With Quote
Old 01-10-2004, 07:14 AM   #8
Here after a while I'll have a car from work, which will be helpful, but it will be a while before that happens.
Chris
Old 01-13-2004, 06:47 PM   #9
Napoleon047's Avatar
if your control arm is bent, you will get uneven tire wear in addition to other problems in the rear.
if i were you, i would find another stock control arm, and have both lower arms half sleeved with some .250" wall DOM tubing by a fab shop
Napoleon047 is offline   Reply With Quote
Old 01-13-2004, 06:52 PM   #10
I'm actually thinking along those same lines, and if everything goes as planned, I'm going to try to bend it back to normal tomorrow, then I'm planning on using angle iron along the bottom side of each lower control arm not only for strength but for sliding the the right or left rather than hitting it bluntly on the bar. Does that make any sense?
Chris
Old 02-03-2004, 06:14 PM   #11
Well today I got my angle iron I'm going to use to reinforce the lower control arms. I'll have pictures soon. I'm using 1"x1"x3/16" angle iron, which fits nicely around the control arm leaving a nice area for a solid bead of weld. It should reall beef things up down there temporarily until I go with a 4 link rear down the road.
Chris
CV Boot Replacement - 92 Pickup bobjohnson2121 86-95 Trucks & 4Runners 5 08-18-2015 07:17 PM
Torsion bar problem mavenator 86-95 Trucks & 4Runners 0 08-13-2015 02:12 AM
FS[GreatLakes]: Toyota collection part out 88sasturbotoy Axles - Suspensions - Tires - Wheels 2 08-11-2015 02:56 AM
Adjustable Upper rear control arms or links kirkrunner 86-95 Trucks & 4Runners 2 07-27-2015 08:59 PM
LCA replacement 1994toyota 86-95 Trucks & 4Runners 5 07-17-2015 04:03 AM
Tags
97, arm, arms, back, bend, bent, control, cruiser, fj, land, lower, pics, problems, rr, spidertrax
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
