| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
GPS / LapTop Off Road Sturdy-Mount
#3 (permalink) |
It took about 4 hours and about $30 to build. One thing that it needed to cleared all controls and be ajustable up-down and turn back and forth with being easy to remove.
#4 (permalink) |
I decided to see if I could make one after I saw how simple they where made.
In my research I learned a few things that where problems with LapTop mounts when used off road so I needed to make sure this was addressed as I made mine and I had about a $50 buget to get it done. 1. The first thing I made was a simple Base plate and formed it to the floor then mounted it with 3/8" nuts & Bolts. pic#1 2. welded a peice of 3/4" X .120 wall 4" long cut at 60 degree angle (guestamation) to base plate.Pic#2 3. Took a peice of 1" .120 wall tubing (3/4" tube slips into this) and at one end I used a cutting wheel to split a slit about 1-1/2" long that would be used to clamp the 3/4" tubing. Pic#3 Last edited by Scottz; 09-07-2005 at 04:52 PM. |
#5 (permalink) |
I used pinch bolt set up to hold everything tight and welded a rod on a nut to add leverage for locking and unlocking the motion of the arm
#6 (permalink) |
Having the 1 '' tube butt welded a little off center to create a stoping point for the slip fit 3/4" tube. This seemed to work better then just using a longer peice of 1" that would allow the slip tube to go further causing it to bind at the bend making it hard to remove so I did this for a bottom out point.
I also started out using an air fitting to use as the swivel and quick release and this was fine on the street but when I hit the dirt it whoopled to and it had no way to lock it in place so I decided on the clamp lock set-up. |
#7 (permalink) |
So now I have no whoples and it fells solid, and I'm sure there's better way's to do this but for the money and time this works for me now. If I where to do it again I would of used mild steel instead of chromoly for the reason mild steel is softer and would be less effort to clamp where chromoly is stronger and take alittle more effort to clamp.
Anyone need some more info to do one like this let me know and I will do what I can to help you build your own. Good Project for a little welding practice. |
#8 (permalink) |
Fantastic job. What did you use or build for the base/cradle that your laptop sits on? Any pics? Thanks.
__________________
Ian 2001 4Runner SR5 4x4 - An Evolving Expedition and Search and Rescue Response Vehicle TJM, XD-9000 Winch, Badland Sliders, SAW/OME Lift, 33" BFG TA KOs, Homemade CO2 Set-up, Optima Blue Top, Cobra 75 WX ST, Icom V8000, Icom IC-F121, 1.0" 4Crawler BL, Hayden Tranny Cooler, Wilderness Rack w/Hella 550s, Snorkeled and Trail Armor by BudBuilt. TLCA #14,082 SAR Field Team Leader - Shenandoah Mountain Rescue Group |
#9 (permalink) |
I wish i could make one of those
__________________
87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header AISIN Manual Hubs, Marlin Crawler Sliders 190XXX miles |
#10 (permalink) |
Very Cool!
I got into using GPS originally when I was doing a lot of sailing. Then I started using it on my dirtbike when exploring in California and Baja. I've always wanted a laptop in the truck that I can plug my GPS into. Nice work!
#11 (permalink) |
Nice job. You might want to make something that keeps the screen from shaking around so that it doesn't fatigue the hinges and break them. I believe you can add that as an option on some of the good laptop holders.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#12 (permalink) |
I was also thinking you might want to add a little shock absortion somehow. Especially since you say that you do some high speed desert driving.
__________________
- Brad 2000 4Runner SR5 4x4 5spd 3" Revtek spacer, ARB RD-90 front | 3.5" Downey coils, E-locker rear | 285/75 16 BFG M/T | TJM T-17 | RB Sliderz | 1.5" RB BL | BudBuilt skid | 4.30s | SS Rear Bumper onetruth |
#13 (permalink) |
Yeah, shock absorption would be a good thing. I had a RAM mount on my dirt bike. The shock absorption was limited to a rubber coated ball that the holder attached to. I had to wrap electrical tape around the batteries to keep them from rattling and building up carbon on the ends . . . . until I hardwired it to the bike. It's all bike stuff . . . . but maybe you can get some ideas here: http://www.cycoactive.com/default.htm I found this site too: http://www.gpscity.com/toyota/all-mo...hbyvehicle.htm
#14 (permalink) | |
Quote:
#15 (permalink) |
For some shocking I used foam weather strip tape on the tops base and a Velcro strap runs around the LapTop to keep in place. Also when I mounted it to the floor I left the carpet between the floor plate and floor which allows for some shocking (cheesy way) and doesn't cause whooples even though it has a little movment.
On the top I decided not to use a solid peice of material instead I used 1-1/4" X1/8" steel strips (Home Depot). I thought this might work better to help with keeping the LapTop cooler with more air flow. Last edited by Scottz; 09-08-2005 at 06:14 PM. |
#16 (permalink) |
What kind of laptop is it you use?
__________________
Sean <>< 1995 4RUNNER 3.0 5SPEED FIPK, Borla, Stubb's Standard SKOs, 100W Hella 500's,PP Springs, 33x10.50 BFG AT, cute redhead http://community.webshots.com/user/racer944 http://s26.photobucket.com/albums/c119/racer944/ |
#17 (permalink) | |
Quote:
#18 (permalink) |
Not bad, saw this on Ebay and remembered to check here for more info
__________________
#19 (permalink) |
Does the mount interfere with passengers?
I'm looking to do something with my laptop however I have no welding experience or access to such tools. I think I need to change that with the mods I would like to make. |
#20 (permalink) |
No, Not at all, in fact the last couple of trips it's been real handy for the passenger to read the laptop and makes it a little more fun for them as a co-driver / navigator. Also it's adjustable for larger passengers and swivels up-down, tilt and side to side.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| expedition gps laptop | Good Times | GPS & Communication | 19 | 05-16-2007 06:33 PM |
| GPS to Laptop | 4Wheeler | GPS & Communication | 8 | 06-05-2005 07:14 PM |
| Laptop GPS - any recommendations? | HaveBlue | GPS & Communication | 1 | 05-23-2005 04:11 PM |
| Garvin Roof Rack with custom Hi-lift mount and custom RAM GPS Mount Installed | transalper | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 01-17-2003 01:09 PM |
| Laptop for GPS | Corey | Off Topic Talk | 9 | 09-19-2002 07:12 PM |
