YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-05-2008, 07:57 AM   #1 (permalink)
plumo57's Avatar
GM 15" wheels
Okay, just spent 50 bucks on a set of 5 steel GM wheels. I know i need to open up the center hole (from 3.5 to 4 inches as i understand it) Someone posted that a holesaw would work, but it seems like i'd need to fab up a really good jig to ensure it was centered right. otherwise, i could use a die grinder although it wouldnt be as nice and round. Any suggestions or opinions (i know, you all have opinions) on this?
I have pictures, but am not smart enough to figure out how to put em on here... if its important enough to anyone, feel free to explain in to me.
Thanks all.
__________________
'86 Pickup
2 inch body lift, 31X10.5s, Diff breather mod, NC homebuilt bumpers, pacesetter header
"People sleep peaceably in their beds at night only because rough men
stand ready to do violence on their behalf."
George Orwell
plumo57 is offline
Sponsored Links
To remove this ad, register today!
Old 08-05-2008, 09:11 AM   #2 (permalink)
kampgnar's Avatar
Recently picked up some GM rally wheels on a whim. Haven't got around to enlarging the hole yet, but I was planning on outlining the diameter of the hole that would be enlarged and just grinding it out to the line.
I've heard of people torching the material out. Was thinking of possibly finding someone with a plasma cutter to make it super easy.
Not too worried about the roundness of the hole as long as it is structurally sound. The centercaps would cover it up...unless you don't have the centercaps.
kampgnar is offline
Old 08-05-2008, 11:59 AM   #3 (permalink)
RobD's Avatar
A coarse cylinder hone and a big drill!
Or find someone with a lathe.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Old 08-05-2008, 08:00 PM   #4 (permalink)
If you were closer I could hook you up with some nice 4" holes. It just so happens that i did the same thing with some alum. chevy wheels. But I program and run cnc mills so all i did was take em to work clamp them down on the table of the mill, indicate the center hole and write me a little program to come down with an end mill and bam the holes were enlarged.
__________________
Go big or go home.....
jeremyfx4 is offline
Old 08-05-2008, 08:09 PM   #5 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
It doesnt have to be absolutly perfect. The wheels on toyotas are lug centric, not hub centric.
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is online now
Old 08-06-2008, 06:35 AM   #6 (permalink)
plumo57's Avatar
Looks like i'll be using the grinder. i appreciate the advice. i got center caps with the wheels but wasn't sure if theyd fit. guess i'll find out.
__________________
'86 Pickup
George Orwell
plumo57 is offline
Old 08-06-2008, 05:56 PM   #7 (permalink)
SKULLYOTA's Avatar
you can use a hole saw the same size as the original hole as a pilot to help you drill it out. just put both hole saws on one chuck if you can. thats what my dad did a few years ago.
oh yeah and hold on tight!
SKULLYOTA is offline
Old 08-07-2008, 06:09 AM   #8 (permalink)
plumo57's Avatar
that actually sounds like a damn good plan....
__________________
'86 Pickup
George Orwell
plumo57 is offline
Old 08-07-2008, 06:27 AM   #9 (permalink)
massyota's Avatar
put a backing plate behind rim and bolt it up thru the lug holes the you can use that to get a center for the hole saw with a piolt hoe for the hole saw that way it wont walk
massyota is offline
Old 08-07-2008, 03:53 PM   #10 (permalink)
SKULLYOTA's Avatar
that oughta work too, using a holesaw that big can give you a ride if you're a lightwieght guy (like me) and i think after the 4th rim the drill blew when we did it.
those GM wheels are goodlooking rims, and 50 bucks sounds like a great deal
__________________
1987 Truck, tube frame flatbed, homemade bumpers, stockish running gear, bronco tire carrier, 33" MTRs on junkyard wheels, 1.5" BJ spacers, rear lowered 1" with u-bolt flip, Summit racing seats, 4.88s, 1" aluminum body lift. and lots of skulls.
check out my truck
Old 08-08-2008, 05:56 AM   #11 (permalink)
plumo57's Avatar
yeah, God Bless Craigslist. for five of em too... and it turns out the guy worked at teh desk next to my little brother, so i didnt even have to drive to go pick em up. They need a little TLC and a repaint, but they're straight n true. I'm gonna give the holesaw idea a shot.
__________________
'86 Pickup
George Orwell
plumo57 is offline
Old 08-08-2008, 08:19 PM   #12 (permalink)
SKULLYOTA's Avatar
good luck, the trim rings and caps for those rims are readily available through jcwhitney, if you are into that look and don't have them...
__________________
check out my truck
Old 08-09-2008, 05:56 AM   #13 (permalink)
plumo57's Avatar
I'm into the fewer parts you have, the less stuff you have to break. Reliability is king.
__________________
'86 Pickup
George Orwell
plumo57 is offline
Old 08-10-2008, 08:13 PM   #14 (permalink)
SKULLYOTA's Avatar
how'd it turn out? i used to run the trim rings back when my truck was clean and nice, but now i also have no use for them.
i just (today) bought the front 4.88 carrier out of a 4runna' and i'm getting a matching rear soon.. ... i'm stoked!
__________________
check out my truck
Old 08-12-2008, 04:57 PM   #15 (permalink)
plumo57's Avatar
Congrats on the 4.88s. I haven't had time or money to buy holesaws of that size yet, so the project is on hold for now. biggest i got is a 2 inch.
__________________
'86 Pickup
George Orwell
plumo57 is offline
Old 08-14-2008, 07:56 PM   #16 (permalink)
SKULLYOTA's Avatar
well i got a complete front off of a automatic 4runner, 150 bucks.
i don't own the rear yet, hopefully i won't have to spend the time to do my own gears. there aren't that many toyota gurus in west montana, so good parts like that are hard to find.
hope your wheels turn out,
__________________
check out my truck
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
new wheels: 16"x8" TRD Ivan Stewarts w/ 285/75/16 BFG AT's Nolan 95.5-2004 Tacomas & 96-2002 4Runners 23 02-16-2008 07:04 AM
WTT: 33" Mud Terrains + wheels for stock wheels/tires + cash madmaxx Axles/Suspensions/Tires/Wheels 8 10-14-2007 02:02 PM
Tundra Brakes - 17" wheels vs 16" wheels KZN185W Maintenance & Repair Archives 0 04-07-2005 05:01 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
