YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-01-2008, 09:13 PM   #1 (permalink)
Foolonastool's Avatar
Exhaust Welding
I'm pretty new to this stuff. My dad gave me his '85 pickup when I got my license and I realized the potential badassness of it. Unfortunately, I know little to nothing about anything automotive other than what my dad taught me or what I have discovered from tinkering around. The current matter at hand would be welding. I know it's pretty much necessary for developing a decent rig. My muffler has some holes in it and I know it's going to fall off soon, but the bolts are totally rusted on with no hopes of being removed. I would like to put a glasspack on it (call me an idiot if you'd like, I'm only 17) and I know I can't achieve this without doing some welding. What kind of welder would I want to use to just do some general exhaust welding or maybe even some minor body work? Keep in mind that I'm totally new to all of this
Foolonastool is offline
Sponsored Links
To remove this ad, register today!
Old 06-01-2008, 10:30 PM   #2 (permalink)
norcalsvx's Avatar
buy a glasspack and take it to a local guy for him to weld on
__________________
1994 toy 22re-
http://www.yotatech.com/f86/nocalsvx-s-94-toy-104593/
2006 Subaru Forester XT -some mods/awd 5spd
1994 Subaru SVX- hwy runner
84 RX7- drag car build
norcalsvx is offline
Old 06-01-2008, 11:04 PM   #3 (permalink)
abj27's Avatar
Quote:
x2
glasspacks are fine. I've run them on a previous truck and I liked it okay. Certainly cheaper, although a little louder. But still not bad. You shouldn't try welding it yourself if you are new to this stuff though. Kind of tricky to get the airtight welds up on the top of the exhaust. You should be able to get a local guy to do it for pretty cheap.
__________________
'92 pickup, xtra cab, manual 3.0, 4x4, 31x10.5
abj27 is offline
Old 06-04-2008, 03:15 PM   #4 (permalink)
hellfire's Avatar
i tried to stick weld a crack in the end of my header and i just burnt a hole through it.
hellfire is offline
Old 06-04-2008, 03:35 PM   #5 (permalink)
85toy's Avatar
Quote:
either too hot or your pipe is rusted thin.
__________________
1984 toyota pickup extended cab 4x4
couple of mods
85toy is offline
Old 06-28-2008, 07:15 PM   #6 (permalink)
91YotaExcab's Avatar
I just bought a little 100$ stick welder from wal-mart and it worked just fine to do my exhaust with. just go find some crappy pipe to get in some practice first. mainly getting airtight welds in areas you cant see.
__________________
31x10.5 treadwright m/t's. blacked out frontend. and more to come
91YotaExcab is offline
Old 07-04-2008, 06:30 PM   #7 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
If its just the muffler your replacing, you can just use exhaust clamps. They bolt on. And you can use the hangers that hook to the clamps too. Really no need for welding.
Adam F is offline
Old 07-07-2008, 06:11 PM   #8 (permalink)
stockyotadriver's Avatar
i run a header and glassback. nothing wrong with it.
i needed a flange to bolt the glass back to the header flange, so i traced out the shape on a peice of diamond plate. Cut it out and welded a 8 inch peice of 2.5" pipe to it, stuck it inside the cherrybomb glassback. (it slid right in and it was tight) and walla it bolted right up.
stockyotadriver is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Welding stainless steel exhaust pipe <96 Runner> The Fab Shop 11 05-24-2008 05:46 AM
is there a way around welding? pandaman Offroad Tech 13 05-23-2008 05:00 PM
Welding a V6 third WFO Offroad Tech 8 10-31-2007 06:15 AM
Welding price for exhaust? crbocaj125 95.5-2004 Tacomas & 96-2002 4Runners 4 03-18-2007 04:00 PM
Welding help? Sbrut95 The Fab Shop 11 04-16-2005 06:38 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
