| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Engine puller- Winch vs. electric hoist?????
#2 (permalink) |
something like this work just fine
http://www.northerntool.com/webapp/w..._420551_420551 |
#3 (permalink) |
i would say yes...a 3500lb winch can pull a Sportsman 800cc 4x4 4wheeler on asphalt with all 4 tires locked up..or spinning in reverse..so i would say a 1ton winch can lift a little motor
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#4 (permalink) |
The Warn Power PUll is a great little Hoist for this application. A 1 ton winch has 2000lb lifting/pulling force so I think the 500-800lb Motor would not be a problem for it.
http://www.gowarn.com/prodDetail.aspx?partNo=WAR685000 Last edited by Pikeman; 11-04-2009 at 06:50 PM. |
#5 (permalink) |
Your normal winch is not really made to be used as a hoist it is not set up to pull in that direction .
I suppose with the proper mounting it could be done . I myself would use a hoist if at all possible. |
#6 (permalink) |
just curious, but what would be wrong with a cherry picker??
__________________
1987 runner, sas, built housing, rebuilt motor, swapped from auto to manual with dual cases and a twin stick, detroit rear, locked front, home brew front bumper w/ winch, sliders, tg dual crossmember skid plate, 4.88s, 35" km2s, and way too much lift! |
| Tags |
| hoist, vs, winch |
