Divorced T-case
Divorced T-case
Is there a fab company that can make a T-case plate and flange the input shaft? My swap is coming to fruition and if I can just divorce the t-case, all my problems will be solved expect building motor mounts! 😁
Any thing can be built if you want to spend the$$$$
A drawing of just what you want is a big help
The F250`s of the seventies had the transmission and transfer case separate with a drive shaft between them.
What you want should be pretty easy to design and build.
I also need to ask Just Why ????
I've seen this done on an older K5 blazer, for equal length drive shafts and to reduce the angle on the front shaft. different truck and case I know but same concept.
jasonty
41
12-23-2018 01:00 PM
priest16
15
08-06-2015 07:43 AM
