YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-16-2008, 12:45 PM   #1 (permalink)
hross14's Avatar
Custom 3rd Gen Gas Tank
Wellllll Welll Welll--In my quest to go 4 link triagulated rear on my 3rd gen--i knew i needed to move the gas tank. Decided to put spare on bumper and tank where spare used to be....
OK--design tank--It is 33" wide 22" long and Slopes from 6" to 10" on the bottom (Approach Angle). I will reuse the old Pump and sending unit. Taking into account that i may need to do some fabbing to it.
Then found that i couldn't mount the tank until i built me a bumper because some brackets were in the way--Pulling trigger there--BUT I want it to be a Steel/Aluminum hybrid. Figured Steel C-channel to Frame--> Then bolt to aluminum bumper body-->then bolt in Steel Hitch reciever. THe Alum will not be tapped but drilled and bolts will go through.
any input on this? Ideas? Suggestions? Anybody built a rear aluminum bumper?
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is offline
Sponsored Links
To remove this ad, register today!
Old 04-16-2008, 01:08 PM   #2 (permalink)
Man4God's Avatar
Pics or thread is worthless!
__________________
'97 4Runner Limited 4x4 w/Locker
Grey (Red & Blue) Wire Mod
2Lo Mod
Tundra DC Non-TRD front with stock Tundra Tokicos (2.5")
Downey 3" rear lift with Monroe Reflex Shocks (Thanks Chaplain!)
Soldier for Christ.
Man4God is offline
Old 04-16-2008, 01:26 PM   #3 (permalink)
hross14's Avatar
i dont have the tank built yet--it is on its way
But that is not the point-- the bumper issue is the point. I dont have a picture because it hasnt been built yet.
__________________
hross14 is offline
Old 04-16-2008, 01:32 PM   #4 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
something like what this guy did?
http://www.trailseeker.com/4x4/mods/4runner/
or this
http://www.sonoransteel.com/rearbumper.html
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l
TOYOTA TOUR 2008
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 04-16-2008, 02:24 PM   #5 (permalink)
hross14's Avatar
kinda similar--but i think i will fab the brackets connecting to the frame out of steel and have plates at the ends--then fab alum bumper body and sides. Mount the Receiver hitch into the Alum with Steel Plates......
Yep...thats what i am doing. show you guys pics once i am done
__________________
hross14 is offline
Old 04-16-2008, 02:38 PM   #6 (permalink)
4Runner202020's Avatar
you know that one rear spring is taller than the other so your car will probably lean and its going to be way more weight in the rear of you runner so more heavy load springs may be in order...
__________________
96 4Runner, 4in lift (883's w/ top plate spacer, Land Cruiser's 8 coil) Pro Comp Xtreme AT 315/75/16's. rear e-locker
I UNDERSTAND THE WHOLE JEEP THING THATS WHY I HAVE A TOYOTA!!
4Runner202020 is offline
Old 04-16-2008, 03:05 PM   #7 (permalink)
hross14's Avatar
already lifted and the extra weight would be welcomed.
Are you running 35's or something larger?
__________________
hross14 is offline
Old 04-16-2008, 03:08 PM   #8 (permalink)
ya i have 35's but if i remember correctly you have the lc coils which dont hold weight very well right...
__________________
Old 04-17-2008, 08:24 AM   #9 (permalink)
hross14's Avatar
they hold weight fine they are very stiff
__________________
hross14 is offline
Old 04-17-2008, 08:38 AM   #10 (permalink)
o really. i heard that they dont hold weight compared to the ome coils...
__________________
Old 04-17-2008, 08:38 AM   #11 (permalink)
and what does me having 35's or not matter... just wondering. lol
__________________
Old 05-12-2008, 08:21 AM   #12 (permalink)
hross14's Avatar
I will post pics tonight--but the basic tank is complete and has been sealed with POR-15 Tank sealer. I have to tell you that stuff is something else.
Put it on a hammer and banged it againt the concrete--stuff laughed at me.
Anyways here are the Dimensions of the tank (33x22--and then 1 end is at 6" and the other at 10". That gives me 25 gallons.
OK-so needed some 3/16 steel to make my tank sending unit, Filler neck, and expansion valve mounting plates. Go to Lowes--no 3/16" only 1/4"--ok--ok i will get it ---HOLY CRUD--12"x12" ($30 Bones). My bottom hurt a little after that.
bought some Hole saws and started going to town--I bought the wrong ones--they were the wood type--DOH!! Would cut to about an 8th of an inch and then just stop. To top it off i had to go and buy a chop saw to cut the steel plate. I am not to far away from having a complete shop full of tools--just need a bigger garage, welder and drill press and i am there...
I also have to modify the Fuel sending unit/fuel pump holding bracket. going to take off the bracket and twist it so the pickup is at the absolute deepest spot on the tank.
As it stands i am at a little bit of a stand still until I can get my holes drilled or cut in my 1/4 plate.
I will keep y'all posted
__________________
hross14 is offline
Old 05-12-2008, 10:36 AM   #13 (permalink)
hross14's Avatar
didnt see your post 4Runner--i was just curious because your truck looks Sharp. Thats it.
As for the coils--mines are pretty stiff and only after a pretty decent load do they start to smooth out a bit.
__________________
hross14 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Gas Tank Lift on 3rd Gen. 4Runner BoulderFrost Offroad Tech 2 03-14-2008 04:56 PM
Bigger gas tank for 3rd gen? my86yota 95.5-2004 Tacomas & 96-2002 4Runners 4 10-24-2006 08:04 AM
Second gas tank in 3rd Gen. 4Runner rwmorrisonjr 95.5-2004 Tacomas & 96-2002 4Runners 6 09-03-2003 07:45 PM
Custom 3rd Gen 4Runner Gas Tank Skid sschaefer3 95.5-2004 Tacomas & 96-2002 4Runners 20 08-31-2003 11:20 AM
gas tank capacity on 3rd gen 4runner4life 95.5-2004 Tacomas & 96-2002 4Runners 28 02-05-2003 02:53 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
