Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Criticize my winch mount idea
I'm going to be finishing my winch mount tomorrow morning so I wanted to get some opinions on what im doing before I finish.
Heres the only pic I have that shows the winch mount as it is now. ![]() Its only held on by a couple of bolts going through the stock crossmember up front. I picked up the winch (Warn 9.5Ti) from a buddy for $100. Just needed one $8 part. So last night I got the part and put it in. So now it works and I need to finish the mount. All it is now is a piece of 8"x5" square with the top cut out sitting on top of the crossmember. My plan is to take a piece of 2.5" square tubing and cut the bottom out and that will go over the crossmember with the open end on the bottom. Then weld that to my existing mount. I will then bolt the 2.5" tubing to the crossmember with 2 or 3 3/4" bolts. My only concern is im only mounting it to the middle 18" of the crossmember and not directly to the frame. My front crossmember will not allow me to go all the way to the frame rails as it is. Will this be enough? What do you guys suggest? |
| Sponsored Links |
#2 (permalink) |
should be just weld really good
__________________
dont make me flex |
#3 (permalink) |
Front range off road...check it out....
You really need this item or make something like it yourself.... http://frontrangeoffroadfab.com/nfos...d8453392d232e0 The front crossmember is .090....super weak... You need to build a bumper that connects to the winch plate, crossmember and stock bumper locations....and possibly a couple more places (to be safe) Look at Marlins bumper.....it has something like 6 or 8 mounting points to the truck (depending on model)
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#4 (permalink) |
Thanks Dirtoyboy
My crossmember is a little different than that, I dont have those tabs on top. Well I welded everything up yesterday. I think it turned out pretty good. Ill try to post some pics up later. I am definatly going to tie it down to some more mounting points. One being the 2 bolts on either side just above the factory tow hooks. The other being the side bumper mounts, but that will be tied into the bumper. I think if I were to do this over I would not have made my spring hanger/crossmember bolt on. That is keeping me from using those bolt holes. |
#5 (permalink) |
Ok heres a pic. I know, my welds look crappy. Im using a stick welder.
![]() I still need to drill for the 2 3/4" bolts to go through the crossmember. And I might end up adding a brace towards the front. What do you all think? |
#6 (permalink) |
Location: Vacaville/Sierra Nevada Mountains, California/ Las Vegas, NV
Is your front spring hanger only being held on by 4 Bolts?
__________________
89 pickup, 22re 5spd manual, 31's, K&N with Deckplate mod, Flowmaster 40, Bestop super top, Hella 500's, CB, MC rear bumper, Sliders, ext. diff. breathers, half doors, 60" high lift, smashed in right side of truck bed mod... "Finish your beer, there are sober kids in Africa" |
#7 (permalink) |
that U bolt is going to fall off!
#8 (permalink) |
#9 (permalink) |
it's not that anyone want's 2 be a ass it's we don't want anyone 2 get hurt/dead enjoying a sport.
so you have bolts holding the spring crossmember 2 the truck crossmember ??? ( they should be welded 2 geather no gap ) U-bolts go under the tube. thats why they make flat and round u-bolts. please fix it befor you losses the axle ![]()
__________________
J.E.E.P Japanese Engineering Eventually Prevails Don't touch that please, your primitive intellect wouldn't understand things with alloys and compositions and things with... molecular structures. Last edited by unclejstoy : 03-16-2008 at 09:37 AM. |
#10 (permalink) |
You do know the ubolts go under the axle tube right?
__________________
#11 (permalink) | |
Quote:
I appreciate everyone commenting on it. The U bolts. I originaly had round U bolts on it but could not get them to line up right. The Ubolt on the inside was tilted towards the front at the top, nowhere close to being perpendicular to the spring plate. So I opted for the square Ubolts. How is everyone else using round ubolts there? I had one bolt holding the winch mount to the crossmember (not planning on using this til its secure) It goes from the plate to the bottom of the xmember -vertical. Now I have 2 - 3/4" bolts running through the crossmember-horizontal. Im thinking I want to put another bolt or 2 vertical so im not relying on my welds as much. What is the question with the 4 bolts you circled? |
#12 (permalink) |
You need to fix that u-bolt right away....if you cant figure out how to put a u-bolt on then you should NOT be doing work like this....sorry, if I sound like an ass.....I just dont want you to die (which is imminent with the way they are set up)
When you apply the proper torque to the ubolts they will conform around the axle tube. ![]()
__________________
#13 (permalink) |
OK man you really need to listen to DTB he is trying to save you and your rig from serious injury.. the bolted on hanger / winch mount should be welded and you need to go put the round u-bolts around the tube right now... do not I repeat do not operate that truck with the u-bolts that way. Stay alive dont be stupud and dont get near me on the road / trail if you dont fix that crap...
__________________
If you don't stand behind our Troops... You can stand in front of them... |
#14 (permalink) |
I would suggest more trianglelation to your mount. There are multiple places to mount to.
__________________
Custom painter and Toyota Stripe and decall supplier. http://jamesdeancreations.com Custom Safari and Crawlin accessories. http://www.jamesdeancreations.com/4runner_project.htm |
#15 (permalink) |
I would push the hanger flush and weld the whole thing......
Autozone has the ubolts you need..... As you can see in dirtoyboy's pis When tires turn it torques the axle front to back and the ubolts WILL pop off of that lip then weld your winch mount to the hanger
__________________
94 4Runner Truggy 60/14B, 3Link w/18" Air Shox Chopped & Exo'd 42's on H1 Beadlocks Pirate4x4 Build Thread 03 Tundra Crawler Hauler/Baja DD 3" Lift, Fiberglass Fenders Prerunner Bumper, (3) 9" Lights |
#16 (permalink) |
Alright I will pull those Ubolts tonight and see if I can get my round ones to work again. Not sure why they were so far off when I tried before. When I tried the round ones before there was no way they were going to line up, applying proper tourqe or not.
I think im gonna ditch the whole front crossmember and spring mount. Cut out the factory crossmember and replace it with 1/4" wall tubing so I can build off that. Weld up the spring mount crossmember directly to that and continue the winch mount as planned. Anything else? |
#17 (permalink) |
sounds good
__________________
J.E.E.P Japanese Engineering Eventually Prevails Don't touch that please, your primitive intellect wouldn't understand things with alloys and compositions and things with... molecular structures. |
#18 (permalink) |
Just use what you got, no point in cutting off the stock x-member and starting over with your leaf hanger....
I just cut mine off built a new hanger and its basically yours but mounted flush to stock x-member and for full widths. ![]()
__________________
#19 (permalink) |
looks good to me i have the am setup for the winch on my 85 except i made a wider spring hanger and than mounted the winch to that
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s 1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold) |
#20 (permalink) |
Yeah.....LEARN TO WELD!
Seriously, "because it was done with a stick welder" is NOT an excuse for a crappy looking weld. If you are welding on suspension components you need to know what you are doing and by the looks of things, you don't. Also do you have pics of this cross member from the side. It looks like those 2 pieces of plate are the only things holding the cross member on. I hope that is not the case. First sharp impact and that thing folds over. Cut that plate off and weld the cross member to the bottom of the frame. The u-bolts leave me speachless. I mean I don't even know what to say. I don't have words to express that level of OMG/WTF. How are you even able to think to yourself, yeah, this is a good idea? I have many friends that live up there in your town and I'd appreciated it if you wouldn't kill them... </tough love>
__________________
Buggy in progress - 22RE on pane, A340, 4.7, 8"s, 4Ds 1989 4Runner 3.slow 5spd and big plans... 2005 Ram 2500 4x4 CTD 6spd QC SWB |
