Sign in using an external account
| The Fab Shop Tube buggies, armor protection and anything else that requires cutting, welding, or custom fab work |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
this could get a little out of hand...
#2 (permalink) |
Personal
Sales Rating: (0)
The engine/tranny is $5000 on it's own? That's a lot of coin, I'd suggest looking around some more. It's also a hell of a lot of engine, I'd go for one of the more common swaps like a 4.3 v6 or a supra I6 engine.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" |
#3 (permalink) |
Personal
Sales Rating: (0)
i agree, if you are going to change out the ecu and what not you might as well get supra motor and put in it, go toyota all the way. you can defintely get enough power out of it.
__________________
anything other than a toyota, would be uncivilized. 91 4runner, 4" tuff country lift, with a 2" tuff country body lift, k&n intake, 2.5 inch high flow cat and flowmaster exhaust, 33x12.5 thornbird's and a loud system, future mod's:: lower gears and lockers. |
#4 (permalink) |
Personal
Sales Rating: (0)
For $5K you could build up a p-pumped cummins 4bt that would be pushing arround 275 hp and well over 400ft lbs(closer to 450-475) of torque(mind you the "4" in 4bt stands for pistons, its a 3.9L I-4). Run a NV4500 behind it with a np205. You could crawl with the best of them, or drop it in 3rd gear and spin the tires through the slop with ease. This is what i would do. But then again i love diesels.
Or, with $5K you could wow everyone and put in a 2jze. if i was to stick with a gasser i would swap in a 4.3 cheby. It would be easier to do, you can always hop it up more, (or You could get a GM 4.3 crate motor that is rated at 260hp), plus it is still a reliable motor.. Lightweight rigs dont always need fire breathing v-8's, we can get away with less than the bigger guys. Plus if you were to be running a LS1, dana 44 breakage would appear real quick.
__________________
-Joe Z Chicago 4x4 My Webshots 1985 Toyota 4Runner, 3" Trail Gear rear/ All-Pro front springs, 42x14 IROK's, Allied Rockathons, spool rear/detroit front, 30 spline longs, Dual cases w/4.7, Marlin High steer, lots of other stuff.. 1997 Dodge 2500 4x4, 12valve CTD, not stock. |
#5 (permalink) |
Personal
Sales Rating: (0)
I'm working on getting all the parts together for the 4.3/NV4500 swap. The engine can be built very strong (almost V8 strong) and is very reliable. Most parts are interchangable with the 350. You can get adapters to run the toyota t-case or just about anyother case you can think of. Advance Adapters makes almost anything and everything you could need, there are a bunch more companies out there with conversion stuff. Just do a yahoo search. For $5k you could do this swap and probably still change for dual cases.
__________________
1989 pickup, 4x4, 22re 4" superlift (full rear springs, skidplate), dual steering stabilizer, downey 26mm torstion bars, 1.5" rear shackles, low profile bumpstops, 5.29's w/ V6 3rd, 35x12.5 BFG MT's on AR Outlaw II 15x10's, 2" wheel spacers, custom exhaust (pacesetter header, 2.25" single in/dual out flowmaster delta 40) custom built 3" intake with stock replacement K&N, LCE water pump, flex-a-lite fan, optima red top My truck site |
#6 (permalink) |
Personal
Sales Rating: (0)
I just recently swapped a Ford 3.8 into my bro's CJ5 and it has all the power he will ever need. Mated a T18 tranny behind it. Those bolted right up. And it's pretty light too. Seems like the engine is lighter than the tranny/t-case combo. The whole Jeep weighs in at around 3600 pounds.
IMHO, I would stay away from a V8. they are just too heavy for me. A good running V6 will be just as powerful. And tons lighter. Which means less breakage.
__________________
83 shortbed. lowerd 6 inches, full hydros (16 switches), Altezza style tail lights, 4 15in. Rockford's, Autozone Edition fartpipe for the exhaust, And some 17 inch 100 spoke Daytons. |
#7 (permalink) |
Personal
Sales Rating: (0)
i'd say a v6 would be the way to go for a toyota if you have to put a domestic engine in.
how hard was it to hook up that 3.8? was it an engine out of something like a taurus? they have the same transmission pattern as a small block ford, right?
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#8 (permalink) | |
Personal
Sales Rating: (0)
Quote:
#9 (permalink) |
Personal
Sales Rating: (0)
can't remember the model it came from. but it was a pretty easy swap.
the hard part was figuring the driver's side exhaust. very tight between the frame and engine. Then again, his jeep isn't a DD. So, half the wiring wasn't used.
__________________
#10 (permalink) |
Personal
Sales Rating: (0)
I'd go 2jz, people have gotten crazy horsepower out of that motor. Like 900 hp with stock internals.
__________________
--Brian '94 4Runner SR5 4WD 285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line Stereo CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q |
#11 (permalink) |
Personal
Sales Rating: (0)
That 2jz would be a real tight fit wouldn't it, with it being a long straight 6? But yeah you can pull a crapload hp out of that motor.
__________________
#12 (permalink) |
Personal
Sales Rating: (0)
Have you thought about installing a late model 3.4L Toyota V6(190hp)? They can be found fairly easily and the wiring harness kit can be bought from Off Road Solutions. That is what we plan to do to our '89 4Runner. Add a TRD SC(265hp) and you will have plenty of power. Add some URD upgrades and well over 300hp is attained reliabley. Keep it Toyota! I'm sure you could do most of this for around $5K.
-Sean |
#13 (permalink) |
Personal
Sales Rating: (0)
I don't remember where I saw it, but somebody had a first gen Runner with an LS1.
If I ever have enough money(and know how, ability, etc) I would love to put in an LS1. The LS1 is one of my favorite engines. I've also seen Ford's 302 swapped into a 3rd gen. Also very cool.
__________________
'99 4Runner SR5 4WD - Black OEM hood w/ scoop, 20% tint on front windows, 5% sunshield, Burtman Clear Corners, Hella Micro DE Fogs, PIAA H3's and H4's, NR EL GLO Gauges http://community.webshots.com/user/zach34 |
#14 (permalink) |
Vendor
Sales Rating: (0)
there's also a guy in australia that put a ford 302 into a second gen. i'll see if i can find his page...
Here it is: http://members.ozemail.com.au/~jonhel5/
| Tags |
| 2jze, 34l, 39i, 4runner, conversion, crate, cummins, engine, mated, nv4500, toyota, tranny |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Speed hand | Robrt32 | 86-95 Trucks & 4Runners | 6 | 04-25-2007 01:25 PM |
| Hand throttle | heckler | Offroad Tech | 5 | 03-26-2005 11:43 AM |
| Give me hand, will you? | WATRD | Computer Talk | 50 | 12-20-2004 07:25 AM |
