| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
chevy spring swap question
#2 (permalink) |
the head of that center pin is larger than 9/16's should fit in the perches fine at least it did for mine
__________________
99 xcb 2.7, enough said 02 trans am ws6 |
#3 (permalink) |
You have to make, or buy special hangers for the chevy springs. The holes in the chevy springs are 9/16", and the holes in the shackle mounts on the toyotas are 19mm or 3/4". I made my own hangers and shackles, but if I was to do it again, I would have spent the money, and bought http://www.sky-manufacturing.com/ chevy swap kit. This link will tell you everything you ever wanted to know about the chevy swap.
http://www.pirate4x4.com/forum/showt...threadid=20665 Heres a picture of my shackles, and I also used sky's ubolt flip kit, if you want some more pics, I can get you some monday
__________________
89 SR5 p/u 3.0 5 speed, doa cams, downey headers, jacobs igniton, self made isr pipe, electric fan, 14"flowmaster, allpro rear spool, 63"chevys, 4crawler 2"bl, bj spacers, skymanufacturing u-bolt flip & shock tower, ranchos, 1 1/2 square tube bed, aisin hubs, 35x10.5x15 super swamper boggers.....For ever a work in progress 2000 Tundra SR5 V8 4x4 Bone stock DD/Tow Rig |
#4 (permalink) |
i did buy skys kit. the problem was with the spring perch on the axle. toyota uses some gay setup. the hole on the spring perch is 7/8". the chevy center pin on the spring is 9/16". if i put the chevy spring into the toyota perch it leaves 5/16 extra for the spring to move around on top of the perch.
#5 (permalink) |
Did you buy sky's ubolt flip kit? The hole on the spring perch really doesn't matter, it should sit down in there. It will be held tight by the upper plate of the flip kit, I actually had to drill the one I got from sky, to fit the chevy pin through.
__________________
#6 (permalink) |
You need a little play in there in order to get the springs centered on top of the perches. Toyota center pins are about 9/16" head too (3/8" or 10mm bolts) and the perch hole is a bit over 5/8". You may have one of the late model rear axles that uses a clamp around the springs with a rubber-surrounded center pin (probably to make things quieter). One option would be to weld a plate atop the perch with a smaller center hole, or cut off the perches and weld on a different set w/ smaller hole. Another option would be to use a hex head center bolt (larger head than a round center pin head). Or find some tubing to fit inside the big hole and drill it out to a smaller size to fit the center bolt head.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#7 (permalink) |
the truck is a 93. and the springs were clamped. there was a small metal sleeve molded into the rubber of the stock setup that i ripped out and dropped it in the perch it fit perfect.
#8 (permalink) |
not to take over the thread but i just got some year 2000 chevy 1500 springs and they measure 62" they have 2 leafs and a bottom out. I think they are rated the same as the older springs. Will these work for the swap or is it a must for them to be from year 88-98? Thanks
| Tags |
| 51, 56, 85, axle, bolts, chevy, conversion, flip, kit, perch, pics, put, rear, skymanufacturing, spring, springs, swap, toyota, toyotas |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 63" Chevy spring swap | getitdone | The Fab Shop | 24 | 08-20-2006 08:20 PM |
| Chevy spring swap question | drguitarum2005 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-30-2006 09:10 AM |
| 89 Chevy spring swap Question & Request. | dwh91102 | 86-95 Trucks & 4Runners | 4 | 01-15-2006 06:24 AM |
| First Gen runner chevy spring questions | Extremesolo | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-05-2005 08:35 AM |
| Chevy rear swap question | roktoy84 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 02-23-2004 04:30 PM |
