YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-21-2007, 12:52 AM   #176 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
out with the old....
also picked up a few goodies recently... something along the lines of 217:1
__________________
-Mikey-
1993 4Runner ~ TG 5" HD/RUF front | All Pro ~4" rear | 37" Krawlers | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo
Polygoats 4-Wheel Drive Club -> check it yo
4RunnerKid is offline
Sponsored Links
To remove this ad, register today!
Old 10-21-2007, 02:25 PM   #177 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
Mike, stop modding your truck because I've not started my SAS yet and I'm thinking in duals due to you!!! Hehehe
That setup will be nice, are you replacing the auto with a manual trans?
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 10-21-2007, 02:41 PM   #178 (permalink)
Prophet_MX's Avatar
Nice runner man! If I had a runner I would hook it up that way!
__________________
Live Fast, Bleed Slow
1993 4x4 std cab. 31" Xterrains, Civic Buckets, Rancho's, Eclipse CD8053, Xtant x603, Pioneer GMH-50, Alpine Type-R 6.5 seperates, Boston Accoustics Pro 10.2
1984 4x4 SAS Doner Truck ask about parts!
Prophet_MX is offline
Old 10-21-2007, 06:31 PM   #179 (permalink)
4RunnerKid's Avatar
yeah, the auto is getting replaced with a manual. so far i've picked up two top shift gear-driven cases, the marlin V6 to gear-driven adapter, and a TG 23-spline 4.7 gearset. my goal is to have the duals done by new years for a trip. new trans should be in next weekend.
oh, sorry david... it's just a sickness i guess. looking forward to see your build, for sure.
__________________
-Mikey-
Old 10-21-2007, 07:25 PM   #180 (permalink)
Tylerars24's Avatar
Send a message via AIM to Tylerars24
nice truck
so whos the babe?
__________________
pickup, sas, 63s, custom high-steer
Tylerars24 is offline
Old 10-28-2007, 08:58 PM   #181 (permalink)
4RunnerKid's Avatar
friend's ex...
anyways, update for the day: flywheel and Marlin clutch are in, manual trans is in, starter is in, pedals are mounted, and master is mounted. had to order a new mount from work (Napa) since the first one i got was wrong, so once that's here i can bolt everything up for good. gotta pick up some hardlines and run those, get the wiring sorted out, trim the floor for shifters, bleed the clutch, fill up the trans and t-case, and possibly pull the axle forward an inch on the perches. later on i'll get the console all figured out and looking nice again, not really an issue right now. only took a few pics... gotta get my camera working and i'll post them up.
by the way, here are few sites i used for info on the swap... might help others in the future.
http://bbs.off-road.com/ubbthreads/s...ue#Post1262965
http://www.yotatech.com/f116/2nd-gen...on-swap-79842/
http://www.yotatech.com/f116/so-begi...-runner-82939/
__________________
-Mikey-
Old 10-29-2007, 11:46 PM   #182 (permalink)
Blizzard's Avatar
Nice! Those duals must be sex... But I think they'll be overkill in my diesel hehe, maybe two stock cases...
I'm starting my SAS in 5 days! Will look for sure to this thread when I'm in doubt hehe
David
__________________
Blizzard is offline
Old 10-30-2007, 01:44 PM   #183 (permalink)
bigarms23's Avatar
looks good you can still keep your auto trans and still run dual cases just get the adapter from inchworm.
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s
1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold)
bigarms23 is offline
Old 10-30-2007, 05:51 PM   #184 (permalink)
LTrunner's Avatar
i'n gonna keep wacthing as i'm hoping to do a 5spd swap on my runner next year. i'm planing on using a turbo trans, with t-case and 4.7s as it would be cheaper than using a v6 trans with the adapter,t-case and cross member...but anyway keep up the good work
__________________
89 4runner 3.0L, 5spd swaped, lifted, locked, armored, and ready for fun
my build
http://www.yotatech.com/f116/my-very...runner-143762/
LTrunner is offline
Old 10-31-2007, 11:32 AM   #185 (permalink)
4RunnerKid's Avatar
well the new tranny mount worked, and everything is solid finally. gonna measure for the hardline tonight, pick that up at work tomorrow, and get as much done tomorrow after work as i can... ran into a little bit of a problem though. driveshaft is way too short, like 3+" too short... so that's gotta be taken care ASAP. i'll keep you guys posted on what i do.
__________________
-Mikey-
Old 11-03-2007, 11:09 AM   #186 (permalink)
4RunnerKid's Avatar
swap is done, for the most part. waiting on my driveshaft still... but once i get that it's test drive time. still need to put the dash back together today, and figure out the console. can't wait to drive this thing.
__________________
-Mikey-
Old 11-03-2007, 04:47 PM   #187 (permalink)
LTrunner's Avatar
so what did you do for wiring to make the reverse lights work, also so that it idlos right???
__________________
my build
LTrunner is offline
Old 11-03-2007, 06:12 PM   #188 (permalink)
Spinnbait's Avatar
wiring
There are only three wiring issues that MUST be accounted for in an auto to manual swap. The neutral/start, ADD, and reverse lights. The neutral/start is the most straight forward. To get it running, connect the two biggest wires that run into the lever select on the auto wiring harness. The reverse lights are as simple as putting the tranny in reverse and touching the wires together until they come on. I still have not figured out the ADD, so I bypassed the ADD sylenoid/vacuum system and have my ADD flange constantly connected. This is fine for me because I have manual hubs.
__________________
Cannondale Rush 3 carbon (my new baby)
Surly 1x1 (my D/D)
1973 Schwinn cruiser (my shop bike)
Spinnbait is offline
Old 11-03-2007, 06:18 PM   #189 (permalink)
LTrunner's Avatar
what's ADD i don't think my truck has that? is that the auto locking font thing for the newer trucks???
__________________
my build
LTrunner is offline
Old 11-04-2007, 06:10 PM   #190 (permalink)
WCorbett's Avatar
have you gotten any crap about not having mudflaps?
WCorbett is offline
Old 11-04-2007, 06:19 PM   #191 (permalink)
CASTAIC 4RUNNER's Avatar
sweet ride
__________________
1999 Toyota 4runner SR5 4WD V6 5speed
CASTAIC 4RUNNER is offline
Old 11-08-2007, 02:13 PM   #192 (permalink)
4RunnerKid's Avatar
drove it last night...
pics once all the little stuff is done.
__________________
-Mikey-
Old 11-12-2007, 03:42 PM   #193 (permalink)
4RunnerKid's Avatar
a few pics from Hollister... met up with Joey (UKMyers) and checked out his rig, which is awesome by the way. hopefully more pics show up, but these are all i've got for now.
poser shot:
mine and joey's 4Runners (sorry Joey, i stole this pic):
de-bending sliders after my attempt at Squeeze Rock:
__________________
-Mikey-
