YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-02-2007, 05:36 AM   #51 (permalink)
-TheBandit-'s Avatar
Quote:
Originally Posted by 4RunnerKid View Post
redid the shims and i haven't had a problem since.
Any tips on setting up the shims? Did you need any special tools? I'll be honest - I haven't looked very hard into rebuilding my axle yet.
__________________
In theory, practice and theory agree. In practice, they don't.
-TheBandit- is offline
Sponsored Links
To remove this ad, register today!
Old 01-02-2007, 08:14 AM   #52 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
You talking about the shims on the knuckle? I used one thick shim and one thin shim top and bottom...both sides...that is what came in the knuckle service kit and it has worked out flawlessly thus far. I read it on Pirate some where that setting it up like that gets you close enough w/o having to have the SST.
__________________
WabFab Off-Road, LLC
www.myspace.com/wabfab
1985 4Runner - Project "Wabbit"
1985 Ext. Cab PickUp - Project "Weasel"
1987 4Runner - Project "Wurton"
1997 4Runner - Project "???"
2007 4Runner
2008 Tundra
waskillywabbit is offline
Old 01-02-2007, 05:02 PM   #53 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
i think i have just a thick one on all but the problem bearing on mine... on that one i added a thin shim too. i have the tool to measure the preload you can borrow if you like. not sure if i'll be in town by friday... if not, i'll mail it to you.
david, i'm somewhere between 74 and 75" at the highest point.
__________________
-Mikey-
1993 4Runner ~ TG 5" HD/RUF front | All Pro 6" rear | 37" MTRs | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo
Polygoats 4-Wheel Drive Club -> check it yo
4RunnerKid is offline
Old 01-07-2007, 11:52 PM   #54 (permalink)
You talkin' about the spring scale? I'll see if I can find one of those locally otherwise I'll let you know.
It looks like my IFS lift is sold and on its way out this week, so I'll be working on hanging the axle pretty soon. I probably wont rebuild yet though. I have a geared third with lockrites on its way, so there aint much else to get other than your inners and a torch.
I am still planning on the hammers in April if I can manage it. You know you want to go. I need someone to show me how it's done.
__________________
Old 01-08-2007, 04:10 PM   #55 (permalink)
4RunnerKid's Avatar
nice clint. glad to see things are coming together. yeah, that scale was like $10 at big 5. i'll drop those inners off once my rear leaf swap is done. hopefully by next week sometime. if you need them sooner let me know. and i'll get you those d-shaft pics ASAP. sorry it's taken so long...
__________________
-Mikey-
Old 01-12-2007, 04:16 PM   #56 (permalink)
4RunnerKid's Avatar
UPDATE 1-12-07
5.29s have been in for a while now, and they are amazing. completely different truck now...
trail-gear HD springs showed up. they'll go in once the rear leaf swap is done and i find some more time...
rear leaf swap has begun. old suspension is off, ready to send off to the buyer. axle is free of brackets and ready for perches. panhard mount is cut, but i'm not sure how exactly to finish that up... kinda trying something out. next up is cutting off the lower control arm brackets and driver side upper link bracket... then i get to put it all back together. it won't be done until the d-shaft is lengthened and rear axle is rebuilt though... no big deal though. on to some pics:
axle
panhard bracket... or what's left of it
casualties of war... one of many
*EDIT*
can one of the mods rename this thread to a build-up of some sort??? that'd be awesome... thanks.
__________________
-Mikey-
Old 01-12-2007, 04:45 PM   #57 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
I removed the entire crossmember, then used the /\ shockmount as the new structural peice. It doenst need to support any large forces anymore, and I bet the tubing is just as strong or stronger.
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's...
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is online now
Old 01-12-2007, 04:56 PM   #58 (permalink)
4RunnerKid's Avatar
i thought about cutting everything out, but i really don't feel like cutting that much... if i had a plasma, it'd all be off by now. angle grinder is a completely different story...
oh, forgot to mention... the axle is going back 1.5" or so. and i'm using 6" all pro springs with 14" shocks.
__________________
-Mikey-
Old 01-12-2007, 05:10 PM   #59 (permalink)
AH64ID's Avatar
Yeah, I had a plas... it was nice....
I centered my axle in the wheel well, not sure how much it moved but the 33 TSL's I had only had about 3/4" clearance on either side, so I am glad I centerd it.... I used 4" Alcan springs...and 13" Ranchos, with the /\ I never come close to bottoming or over extending the shock...
__________________
-John
Old 01-12-2007, 06:44 PM   #60 (permalink)
Mikronized's Avatar
that's going to be sick mike!!!
__________________
'94 4runner : soon-ish to be V8'd, SAS'd, lock'd and bumper'd
Mikronized is offline
Old 01-13-2007, 12:18 PM   #61 (permalink)
Only 1.5"? Go more! Give yourself enough room for 4Ds.
Did you see the cover 'runner in the December issue of Peterson's? That my friend is where you should be heading! Four tube doors and a chop top looks sick and you can almost mistake it for a 1st gen.
__________________
Old 01-16-2007, 02:57 PM   #62 (permalink)
99_Runner's Avatar
Send a message via MSN to 99_Runner
Looking really good. Can't wait to see it after the rear swap and the 37's. Did you ever get the longfields put in the front so you aren't snapping stockfields any more?
__________________
Drew
99 4Runner SR5, auto, 3.4 V6, factory rear locker, 265/75 Yokohama Geolander AT+II
Stock for now, but hopefully not for long.
99_Runner is offline
Old 01-17-2007, 01:28 PM   #63 (permalink)
Get that thing sprung so we can wheel! Are you gonna build a tractionbar? Did you take any pictures of your front D-shaft? Longfields for the front?
__________________
Old 01-18-2007, 10:49 AM   #64 (permalink)
idayota's Avatar
i'd be really interested in some pictures of your front driveshaft, too. the build looks good. keep the pictures/work coming!
__________________
Wherever, Whenever, However...Tread Lightly!
idayota is offline
Old 01-18-2007, 02:28 PM   #65 (permalink)
4RunnerKid's Avatar
i have some pics of the d-shaft, but my computer is down at the moment. i'll see if i can upload them on my roomie's computer. as for the birf upgrade, i'll be ordering bellfields when i get paid in a couple days. oh, and i'll be sticking with the 35s for a while. either 37s or 40s once these wear out...
__________________
-Mikey-
Old 01-21-2007, 01:43 PM   #66 (permalink)
4RunnerKid's Avatar
finally got my computer working... so d-shaft pics are up:
__________________
-Mikey-
Old 01-21-2007, 03:06 PM   #67 (permalink)
AH64ID's Avatar
Is that full droop? Thats a steep angle...
__________________
-John
Old 01-21-2007, 06:09 PM   #68 (permalink)
4RunnerKid's Avatar
thats drooped out a little, but not full droop. i haven't had any problems with it binding up at droop...
__________________
-Mikey-
Old 01-21-2007, 09:26 PM   #69 (permalink)
Flygtenstein's Avatar
How much does that shaft hate you?
Low pinion, square and single cased. 4wd over 2MPH must be sweet.
That being said, I caught hell picking up a CV core to make a square trail spare front.
__________________
Ease on down the road.
