Thread Tools | Search this Thread | Display Modes |
#276 (permalink) |
Dude I wish I could wheel out by you. The trails look amazing compared to here in Washington. Ill have to make it out there soon someday.
Time to cut those fenders I bet those 37's rub hella. I cut off 1" off the rear then tacked the body back together and bent the fender lip in to the same 90Degree angle as before with a sledge to hold its shape better. I flexed out with no rub front nor back this last weekend perfectly.Looks great ![]()
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
| Sponsored Links |
#277 (permalink) |
thanks man. you should definitely try to make it out here one of these days... hopefully before all the trails are closed. if you do, hit me up and we'll plan a trip.
the 37s only rub up front, so either some firewall work is in order or the front hanger is getting moved forward a bit... or both. 2wd oil pan is on the to-do list as well... the rear tucks pretty good as is, but it'll tuck even more once i redo the bumpstops, hopefully this weekend.
__________________
-Mikey- 1993 4Runner ~ TG 5" HD/RUF front | All Pro ~4" rear | 37" Krawlers | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club -> check it yo |
#278 (permalink) | |
Quote:
Looks good and Ill be sure to hit you up if I make it out there ![]()
__________________
#279 (permalink) |
only update i have...
![]() ![]() picked up another tailgate at the junkyards yesterday and got it installed today though.
__________________
#280 (permalink) |
What happened, Mike? Glad to hear you're in the way of repairing it.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write... |
#281 (permalink) |
Wow what happened to that gate?
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. I'm the yota junk man......PM me for ALL your parts needs NEW or USED Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#282 (permalink) |
ouch...loose sand sucks
__________________
89 4runner 3.0L, 5spd swaped like what ya see...check my build http://www.yotatech.com/f116/my-very...runner-143762/ Don't Follow me, you won't make it "Wheeling the piss out of it" AND "DD"ing it since 2005 |
#283 (permalink) |
long story short, my friend's e-brake didn't quite keep his truck from rolling down a small dune... right after i pulled him out too. what a jerk.
__________________
#284 (permalink) |
Did you air down? Tires look full.
__________________
1994 Toyota 4Runner V6 3.0 5 Speed Conversion Solid Axle Swap Rear Leaf Spring Conversion 1985 Solid Front Axle Bilstein 5150's All Around 35" BFG Mud Terrains Yukon Full Spool in Rear 3" Exhaust w/ Hi-Flo Cat and Magnaflow Muffler Drilled Air Box MY BUILD |
#285 (permalink) |
12 psi all around...
__________________
#286 (permalink) | |
Quote:
had this happen to me once too, not as bad as your damage thanks to my quick maneuvering, but he still hit me... good luck with that, and nice truck! ![]()
__________________
-Jake 1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-33's-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders! SAS Build-Up Old Rigs: '85 4Runner (RIP) '95 4Runner (sold) |
#287 (permalink) |
well i figured it was about time for an update... sadly, there's not really much to report. moved down to LA for the summer, and have been commuting the 4Runner 60 miles a day Mon-Fri.
so far, so good, except for a bad u-joint i found today. making some decent money at my internship, so look for some better updates in the near future... cage, Longs, and a little tweaking of the front suspension are a few items on the list. keep checking back... ![]()
__________________
#288 (permalink) |
Should be sick once you get the time and funds to get some more work done. I know the feeling.
And the smashed tailgate same thing happend to me so then I decided to the roof. Im very glad I did ![]() Keep up the good work!
__________________
#289 (permalink) |
Where are you interning?
__________________
In theory, practice and theory agree. In practice, they don't. |
#290 (permalink) |
i'm interning at ACCO Engineered Systems in glendale.
well i've accumulated some parts over the past few weeks, look for some pics after this weekend... it's time to DW. ![]()
__________________
#291 (permalink) |
first of a few updates...
my old wal mart special rock lights hadn't worked in forever, so an LED underglow kit was in order. the light output is perfect, and they even beat to the music. ![]() ![]() ![]() picked up some Fox 12s for the front. going to test them out next weekend at the MDR night race, so hopefully i can get them dialed in soon. ![]() ![]() ![]() heading out to the garage to do a little work, so i'll have another update tonight for you guys. ![]()
__________________
-Mikey- 1993 4Runner ~ TG 5" HD/RUF front | All Pro ~4" rear | 37" Krawlers | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club -> check it yo Last edited by 4RunnerKid : 08-10-2008 at 05:14 PM. |
#292 (permalink) |
LED underlights... hahaha! I have some of those too - they are 100% BLING BLING! Multi-color, dance to music, strobing, moving, etc. Great for Pismo - they show up really well on the sand and everybody knows where you're at.
You need a Bling gauge in your dash if you don't already have one.
__________________
#293 (permalink) |
you know it Clint, these things are awesome... and definitely perfect for Pismo. good idea on the Bling gauge, might have to look into that.
spent the whole day in the garage working on the Party Wagon... finally did the 2WD oil pan swap. i picked up the pan, tray, pickup, dipstick, and tube from Cal Mini Truck for pretty cheap. i must say, Toyota must have been high when they designed the 4WD pan... the 2WD pan is a MUST for 3.0L SAS rigs. no need to be sky high to clear everything with this pan. install wasn't too bad, aside from a few hiccups i ran into (nothing to do with the pan). everything just bolted up. onto some pics... pickup and tray installed: ![]() pan installed: ![]() new, much-appreciated clearance: ![]() i also picked up some bling for the front-end... in the form of the Marlin UM06 chromoly birfs. i couldn't pass up the deal they had on them this past week. i'll be sure to report back with how they hold up. (i know when i researched them i couldn't find much.) ![]() ![]()
__________________
-Mikey- 1993 4Runner ~ TG 5" HD/RUF front | All Pro ~4" rear | 37" Krawlers | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club -> check it yo Last edited by 4RunnerKid : 08-10-2008 at 06:56 PM. |
