YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-12-2006, 10:10 AM   #1 (permalink)
Ringmaster's Avatar
3rd gen SAS Speedo/ABS
OK 3rd gen. Guru's,
When you performed the SAS on your rig, how did you go about getting the speedo to work?
I know about discarding the ABS system which is fine with me, it has lousy brakes anyhow, so good old everyday brakes should be fine.
The speedo operates off of the front ABS system, so how do you go about tacking it to the rear axle ABS system just to have a speedo? I plan on keeping the stock rear axle so the ABS sensors, and port's will be there.
Stretch the front ABS lead's to the rear axle?
I also know about Dakota Digital's "Magic Box" to hook things up and get it somewhat close.
Thank's
Don
__________________
99 4Runner, 3.4, 5 spd., Manually shifted E-Locker, 4:30 gears, 285/75/16 MTR's, Airbox mod through the bottom of the inner fender.
Ringmaster is offline
Sponsored Links
To remove this ad, register today!
Old 12-12-2006, 10:17 AM   #2 (permalink)
SteveO's Avatar
Send a message via Yahoo to SteveO
Seems like there are different mods for different vehicles. Being that you have a v6 and a 5spd, you MAY (don't know for sure) have your speedo coming from your transfer case tailhouseing. If not, you may have had it coming from your ABS sensors. I think you are onto the right path with patching into your rear ABS sensors. Then you can patch in the Dakota Digital to correct the Speed sensor.
I'm sure there are others on here who may have done it differently, and hopefully will chime in.
On my '99 Limited with an Auto tranny, I would have patched into the rear ABS sensors. However, I no longer have those, so I use the GPS for now, until I have more time to invest in this issue.
edit: My transfer case is multi-matic transfer case. I don't know if your rig has a mutli-matic, but if so: I used a switch on the side of the transfer case lever that will allow me to shift power to the front wheels up to 62mph. However, now I no longer have a front IFS houseing and switch letting the trasnfer case know that the front IFS half shafts are engage (allowing the full-time 4wd). So, I have closed this loop, using the button on the side of the trasnfer case lever. This cuts power fron the transfer case to the front driveshaft, allowing you to run in 2wd, contrary to what some would say. When I want to send power to the front driveshaft, I can open the switch and shift the transer lever into 4Hi or 4Lo, and I have power to the front driveshaft. So, again, I think it depends on what your setup is. As I stated before, I think you are on the right path with patching into your rear ABS sensors.
SteveO is offline
Old 12-12-2006, 10:58 AM   #3 (permalink)
AxleIke's Avatar
Check out this thread, starting on page 3. Might help some, or at least give you some direction as to questions.
http://www.yotatech.com/showthread.php?t=90965
Seems like so far, people haven't had much luck.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 12-24-2006, 06:36 AM   #4 (permalink)
dragr1's Avatar
I have a '99 SR5 5spd and my signal comes from the front abs sensors. I found this out when trying to install a Superlift Speedo Corrector. I tapped into the signal at the abs ecu-but again the signal was coming from the front wheels.
__________________
1985 4Runner Dual e-lockers, dual cases, yada yada
'00 Suburban 2500 4x4
'07 Tacoma Double Cab 4wd TRD
'02 Lexus IS300
1991 Tiffin Allegro 31' Class A
dragr1 is offline
Old 12-24-2006, 07:49 AM   #5 (permalink)
you can easily run a signal splitter off the rear sensors and tie it into the inputs of the front sensors. No need to run the wiring from the back sensors, just tap into them at the ABS computer. Or you can run a superlift speedo corrector and tap the signal from the rear sensor directly to the lead going into the speedo, bypassing the ABS computer all together.
BruceTS is offline
Old 12-26-2006, 03:30 PM   #6 (permalink)
vegaskurt's Avatar
Well this post ruined my day... Was planning on eliminating ABS when I do the full floater rear setup prior to doing a SAS. Looks like it will be one or the other now.
__________________
1997 Limited 4Runner | Stubbs Sliders | Budbuilt Skid and Belly | Homemade Bumper
vegaskurt is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Dual Batteries in a 3rd Gen with ABS?? ltbulldog23 95.5-2004 Tacomas & 96-2002 4Runners 15 02-21-2007 09:13 PM
3rd Gen speedo gears (transmission) chadbobb 95.5-2004 Tacomas & 96-2002 4Runners 10 11-27-2006 06:40 AM
How to remove - rear axle bearing retainers and ABS rotor (3rd gen) KZN185W 95.5-2004 Tacomas & 96-2002 4Runners 0 05-13-2006 12:35 PM
3rd Gen. CV axle (w/ & w/out ABS??) ASU4runner 95.5-2004 Tacomas & 96-2002 4Runners 6 01-08-2006 07:11 PM
Will 4th Gen rear discs fit a 3rd Gen housing w/ ABS? aowRS 95.5-2004 Tacomas & 96-2002 4Runners 3 11-11-2004 01:52 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
