| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2nd gen 3-Link rear with Coilovers
__________________
94 4Runner Truggy 60/14B, 3Link w/18" Air Shox Chopped & Exo'd 42's on H1 Beadlocks Pirate4x4 Build Thread 03 Tundra Crawler Hauler/Baja DD 3" Lift, Fiberglass Fenders Prerunner Bumper, (3) 9" Lights Last edited by customcruiser; 03-02-2006 at 01:08 PM. |
#2 (permalink) |
Talk to adrian and scott about spring rates. I know polyperformance will let you send springs back so you can try them out and find what's best.
__________________
--Brian '94 4Runner SR5 4WD 285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line Stereo CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q |
#3 (permalink) |
x2 on Pig at Poly.
It would probably be helpful if you can find somewhere to weight your rig at all 4 corners. It will help Poly help you with the spring selection.
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#4 (permalink) |
i'm aboiut 5 min from poly performance. next time i am over there i'll ask Dave or Drew what they think and post that info.
__________________
-Mikey- 1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club Poly Performance |
#5 (permalink) |
thanks for the help......
i wanna cut tomorrow but i know i shouldnt
__________________
94 4Runner Truggy 60/14B, 3Link w/18" Air Shox Chopped & Exo'd 42's on H1 Beadlocks Pirate4x4 Build Thread 03 Tundra Crawler Hauler/Baja DD 3" Lift, Fiberglass Fenders Prerunner Bumper, (3) 9" Lights |
#6 (permalink) |
about coilover???????
single rate.... dual rate...... triple rate.....
__________________
#7 (permalink) |
I'd go either single or dual. Depending on the trails you run, the math with a triple rate can be a bit tricky.
__________________
#8 (permalink) |
Didn't Scottz have a custom 3 link?
__________________
#9 (permalink) |
Ya, he used 10'' sway aways he found in a junk yard. The lengths and spring rates would be different. I think adrians new setup is using 14" sway aways so the rates would be more of what he's looking for.
__________________
#10 (permalink) |
i would go with dual rates... as for the spring rates, you'll need something a little on the dtiff side since 4Runners are so heavy in the rear. maybe a 450 over a 650... or even a 550 over a 650... i'll def ask the guys at poly performance next time i'm there.
__________________
#11 (permalink) |
i am planning on lighting up the rear alittle bobbing and chopping....
its trail only built for tellico i hope atleast i will see on may 11 thanks a bunch
__________________
#12 (permalink) |
50 degree angle for 3-link
uppers 40" lowers 54" 9" seperation at axle 4" seperation at frame
__________________
#13 (permalink) |
Spring rate depends on coilover angle.
You are going to need to spring the hell out of it if they are angled like Scott's. He is in the sixes while my verticle ones are in the 2's and 3's. Dual rate, you have to on something that tall. No reason for triple, do some more investigating. Other things of note: 1. Do you know how long a 14" travel coilover is? That is one long SOB. With 12's at verticle, I am still mostly droop. 2. What axle width? I am just shy of 67" WMS to WMS and with coilovers outside of the frame things are tight in those wheel wells. Without cutting frame or getting a wide axle, you are head for disaster.
__________________
Ease on down the road. |
#14 (permalink) |
You mentioned you couldn't find 1" Weld in inserts...
Check these guys out, they might have what your looking for (AED Motorsport Products) http://www.aedmotorsport.com/TubeAda...beAdapters.htm Erich
__________________
99' Black Highlander 4runner / Garage Profile Black powder coated 8x16 Wheeler Off-Road allow wheels / Husky floor liners / Thule MOAB rack / Custom Sub Enclosure / Back-up lights "I don't high-light my hair, I've still got a pair, yeah honey, I'm still a guy. My eye brows aint plucked, there's a gun in my truck, Oh thank GOD, I'm still a guy!" Brad Paisley |
#15 (permalink) |
dual rate
Here is a diagram of how a dual rate coilover works. Notice that the first or primary spring rate is a combination of the two springs working together. The second or secondary spring rate kicks in when the floater engages the lock ring. This eliminates any movement on the part of the top spring and in effect uses only the lower spring. What that means is that your secondary spring rate is your bottom spring. quote from http://www.offroad-engineering.com/howduracoovw.html The King PreRunner 2.0 14" Coilovers are 21.6 compressed to 35.6 extended the Bilstein 5150's are 17.8 compressed to 29.7 extended i am not planning on full widths yet..... i will be running the shocks angled on the inside of the frame, although i dont mind having to cut the floor or even tub the rear frame
__________________
#16 (permalink) |
$$ getting tight not sure on coilovers before Tellico, but will have a new 3-Link
got my joints today......... upper 3-link built - 1.75 x 1/8" DOM lowers links sleeved - 1.5 x 1/4" sleeved 1.75 x 1/8" DOM just gotta put in the bungs and take it to get fully welded. and do my crossmembers 3 - 2.5" Currie 2 - 2.5" Currie Joints 2 - 2.5" Rubicon Express Joints All Hardware pics of my joints
__________________
#17 (permalink) |
1.75" .120 wall DOM is really great material for sliders and cages.
By upper 3-link, I am assuming you mean wishbone. Start with 1/4 wall or sleeve what you have. That is not enough upper beef in a wishbone.
__________________
#18 (permalink) |
the upper will not hit any rocks.... atleast i hope. i think 1/8" is plenty thick
finished links and crossmember for lower links need to mount lowers to axle build bridge for axle 3-link mount and mount the 3-link to frame shocks pics soon
__________________
#19 (permalink) |
the upper might not hit rocks but it will have to deal with all the sideload of keeping the axle centered
#20 (permalink) |
what coilovers should i get and what type of spring rate??
buying them on Wed.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| need link to 2nd gen runner with 1st gen roll bar | jsnby | 86-95 Trucks & 4Runners | 19 | 05-07-2006 03:28 AM |
| 2nd Gen 3 Link/Housing Truss | rock star mike | The Fab Shop | 6 | 10-02-2005 09:27 AM |
| Rear coilovers, 3rd gen? | Mad Chemist | Offroad Tech | 7 | 07-31-2004 05:50 PM |
| Stock 2nd gen. rear lower link length? | 914runner | Offroad Tech | 4 | 05-17-2004 11:01 PM |
| ? about coilovers 2nd gen 4runner | bikerunner | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 01-13-2004 05:24 AM |
