THE 1 MILLIONTH SAS (on my 92 runner) - Page 3 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-11-2006, 08:19 PM   #51 (permalink)
4rnr's Avatar
Ok ive got a decient amount done the worst part of this is definatly the grinding.
Heres 924runnersr5 lending a hand
The rear axle all ready to place
Heres where im at with removing the coil brackets I havent made up my mind on whether im going to remove any more, I might just clean up whats there, I dont think it will be in the way. But ill probably remove the drivers coil pad as well I just hate plasmaing that close to the gas tank
Ive still got a long way to go, this is how my front end sits until I finally get my 3rd back!
I got my front and rear kits, and other little things today, so this should continue to pick up pace.
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is online now
Old 01-11-2006, 10:14 PM   #52 (permalink)
4rnr's Avatar
hey what did you guys do about drive shafts, I havent made up my mind on what to use. I have 4 drive shafts in my garage.
1 front with a cv
1 front with u-joints
1 rear with a cv
1 rear with u-joints
I dont want to use straps, I dont want to make a square shaft, dont care if the front has a vibration bc I wont be using 4wd on the road. I am leaning toward a u-joint rear, and im not sure for the front.
I know ill have to do longer splines. Keep in mind I have the auto and one t-case so my front shaft is pretty short
__________________
poop
4rnr is online now
Old 01-12-2006, 11:10 AM   #53 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
i've heard the way to go is a rear with a CV. i'll have to double-check on that though...
__________________
-Mikey-
1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo
Polygoats 4-Wheel Drive Club
Poly Performance
4RunnerKid is offline
Old 01-12-2006, 03:17 PM   #54 (permalink)
4rnr's Avatar
I did alot of research today and I think that im going to use a cv rear shaft with stock splines and extend the shaft. For the front it looks like a u-joint with a 8" spline kit, and extended.
__________________
poop
4rnr is online now
Old 01-12-2006, 03:21 PM   #55 (permalink)
4rnr's Avatar
Ok kids this why you dont make a flexy rear end in these and keep he panhard stock...
notice where the d-shaft had dented and rubbed the crap out of the tank, also the 3rd smashed the crap out of the tank and skid plate
__________________
poop
4rnr is online now
Old 01-12-2006, 10:43 PM   #56 (permalink)
4rnr's Avatar
If any of you swaped coils to leafs in the rear what method did you use to locate the rear axle? Im still not sure how to get the leaf in the right spot so the suspension can properly cycle. Ill probably end up taking apart the leaf and tacking the leaf up and then cyling it to make sure. Then I have to pray the leafs are in the exact same spot on the frame so im not dogalking down the road.
__________________
poop
4rnr is online now
Old 01-13-2006, 11:34 AM   #57 (permalink)
4rnr's Avatar
Man all I can hear on this thread is crickets
__________________
poop
4rnr is online now
Old 01-13-2006, 11:37 AM   #58 (permalink)
FilthyRich's Avatar
I just came inside from unloading my 3rd load of 1.5 tons of gravel.
I am beat....
You ride is coming along FAST. Not sure about the coil buckets, but I like what I see
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 01-13-2006, 11:56 AM   #59 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Quote:
On mine, I used a CV joint on the rear (this will eliminate all the vibrations that the u-joint won't and wouldn't) and an 8" spline on the front w/ the OEM front CV joint.
I had maybe like $100 parts tops going through local sources.
Crickets you say?
waskillywabbit is offline
Old 01-13-2006, 04:12 PM   #60 (permalink)
4rnr's Avatar
Crickets you say?
Do you have a stick and how many t-cases.
Yes crickets
__________________
poop
4rnr is online now
Old 01-13-2006, 04:29 PM   #61 (permalink)
4rnr's Avatar
Quote:
I am beat....
Coil buckets?? what about them
__________________
poop
4rnr is online now
Old 01-13-2006, 04:44 PM   #62 (permalink)
4rnr's Avatar
Ok Ive got one of the front springs mounted and I Think its probably ok but I hope the shackle swings back alot with the wieght of the truck on it. Man its nice cutting those holes with the plasma cutter I dont know what ya'll are whining about
I also had my woman paint my rims black (I hate chrome!!!) I think she did a good job. Ill probably put one more coat on it. Now if I could just paint the white lettering that the PO decided to face out in a 1985 rage
__________________
poop
4rnr is online now
Old 01-13-2006, 05:16 PM   #63 (permalink)
FilthyRich's Avatar
I meant coil brackets. I have been moving gravel all day and I am a zombie.
__________________
Eric
88 4runner
Old 01-13-2006, 09:49 PM   #64 (permalink)
4rnr's Avatar
I know what you meant, I was wondering what you "didnt know about them" or something thats all.
__________________
poop
4rnr is online now
Old 01-14-2006, 06:58 AM   #65 (permalink)
Staff
Yes crickets
Single case for now.
Old 01-14-2006, 08:49 AM   #66 (permalink)
4rnr's Avatar
you must have stick bc everyone I talk to says that the auto and a single case is too short for a cv.
__________________
poop
4rnr is online now
Old 01-14-2006, 09:44 AM   #67 (permalink)
Staff
Yes, I have a 5spd and after the lift the front was so short it wouldn't even engage the splines...rear would still work but would vibrate like crazy...now all is perfectly smooth onroad and off.
Old 01-14-2006, 11:06 AM   #68 (permalink)
Beast's Avatar
good job man
You won't regret a tough solid axle
there is this very washed out road whooped road and muddy a hell
my friend 91 v6 truck was bottoming out at 23mph tops (w/ torsion bars stiffend)
I could take that section at 50 miles per hour!!!!!!!!!!!!!!!
my suspension was bottoming out but it took and I was smiling!!!!!!!!!!!!
I think IFS is good for city driving - softer ride
But if you want to OFF-ROAD solid axle
I
__________________
Beast started out as an 81' now W/ 7mgte, w56, 2nd gen rearend, centerforce DF, FX bucket seats, Beast bumpers front and rear, reinforced frame, custom steel grill, custom quad headlights, four 165 watt KC daylighters on double tube roll bar, eight speaker stereo,
Beast is offline
Old 01-14-2006, 12:11 PM   #69 (permalink)
joebruva25's Avatar
Was wondering how many inches of lift will this add & do you even need to keep the panhard bar?, also what leaf springs did you use? Chevys, yota, etc this is also a mod. I want to do and how did you find the placement of the hangers and shackles in order to keep the thrust angle correct (Did you measure from the rear end of the frame) because I heard if you don't do this right it will throw off the front alignment(if you go to get it done cause they set the front off the rear) & you will wear through tires Quickly(that is if you drive on the street alot).
Pls let me know how this goes cause this mod. is going to be my next project.
joebruva25 is offline
Old 01-14-2006, 01:01 PM   #70 (permalink)
4rnr's Avatar
Its suposed to be a 4'' kit but im afraid im going to be around 6'' :pat:
with leafs you dont use a panhard , you dont have to use anything (unless your afraid of axle wrap)
Im still working on getting the rearend properly placed. not sure exactlly how ill do it, I cant seem to find people who have done a 4'' marlin rear leaf conversion. but ill keep ya updated.
__________________
poop
4rnr is online now
Old 01-14-2006, 01:04 PM   #71 (permalink)
4rnr's Avatar
my dust sheilds are HORRIBLY corroded, and i think im going to eliminate them i know alot of guys have done this. Anyone have an issue with the less 1/8th in. of spacing.
And no i cant just cut the sheilds off the bracket bc the brakets are coming apart.
__________________
poop
4rnr is online now
Old 01-14-2006, 02:20 PM   #72 (permalink)
4rnr's Avatar
http://www.allprooffroad.com/images/...lodeview_l.jpg
this drawing seems wrong it shows large metal, cloth, rubber, small metal, as the order of the knuckle seal. but as i assemble these it works perfectly as large metal, cloth, small steel, rubber.
just a heads up for people relying on this diagram or ive missed someting
__________________
poop
4rnr is online now
Old 01-14-2006, 02:27 PM   #73 (permalink)
Staff
That is straight out of the Toyota FSM I think...better check again.
Old 01-14-2006, 11:03 PM   #74 (permalink)
4rnr's Avatar
Nope I think Ive got it right everything went together perfect, but the way the drawing says nothing fit. Oh well.
__________________
poop
4rnr is online now
Old 01-14-2006, 11:17 PM   #75 (permalink)
4rnr's Avatar
Ahhh a point ive been waiting for about 7 or 8yrs. Its on a solid axle.
However, its taller than a skyscraper. I cant belirve its this tall I hope it settles ALOT, or else im buying 38's.
This is on 35's the same ones from the first post...
Sorry some of the pics are blurry I have VERY little light in my garage and the shutter sometimes stays open for almost a second.
__________________
poop
4rnr is online now
Tags
36x1450x15, gumbo, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
92 SAS 4Runner 4RocRunner92 The Classifieds GraveYard 73 10-11-2007 09:01 AM
92 SAS or hold out for Newer toy fatdudesurfin General Vehicle Related Topics (Non Year Related) 2 10-25-2006 10:11 AM
92-95 runner bumper work on 91 runner? 914runner 95.5-2004 Tacomas & 96-2002 4Runners 1 05-25-2004 11:17 PM
millionth tire question on this site SoCal4runner 95.5-2004 Tacomas & 96-2002 4Runners 4 08-28-2003 01:10 PM
2009 InternetBrands, Inc.
